When switchon my laptop a message comes up please insert the memory mudule to slot a
    Master:
  • 538 Answers
Hmm..that suggests that the memory module is either mis installed or missing..that would be odd..usually located under the laptop behind a small panel with a small screw holding it down..
Posted on Oct 14, 2008
Hi. My new H61iCafe board should be able to recognize 16 GB (4 memory slots). I have bought 2 8-GB-Kits (each consisting of 2x4GB): Kingston KVR1333D3N9K2/8G After inserting 2 modules, 8 GB are...
Number of Memory Slots: 4-240pin
Note:
1. Before you install memory module on this motherboard, please read below message to avoid any improper installation: - Due to chipset limitation, if you plan to install three or four memory modules on this motherboard, please install only single-sided memory modules.To install two memory modules on this motherboard, please install them on DDR3_A1 and DDR3_B1 DIMM sockets.
2. For the detailed installation information, please refer to the user manual or quick installation guide. - Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows 32-bit OS. For Windows 64-bit OS with 64-bit CPU, there is no such limitation.
Memory Standard: DDR3 1333/1066
Aug 12, 2011 | Asrock H61ICAFE LGA 1155 Intel H61 HDMI...
I want to transfer pictures from my toshiba laptop to a memory stick can you help please thank you
Insert your memory stick to your laptop, if your laptop has a memory stick slot or in the USB slot (if it is supported). If it doesn't have on you need a memory stick card reader. Insert your memory stick on a card reader then insert the card reader into the USB slot.
After that your laptop will prompt you and choose "view folder".
Now go to the folder where your pictures is located and choose the pictures you want to transfer and then right click on it and click "copy".
Go back to the folder of your memory stick, right click and then click "paste".
That should do it.
Thanks for using fixya!
Update me if you still have questions and let me know how I helped you.
May 28, 2011 | Computers & Internet
On my nokia n97 there is a lttle envelope flashing at the top of the screen which means sim memory full, how do access this to delete the messages
ok read and do it carefully
you can remove this icon by followng steps
Press Menue Button
Open Messeging
Now Press Options
choose SIM Messages
Mark All Messeges and copy to INBOX
Mark all again and Delete all messages
Press Back button
Little envelope flashing will no more
Thanks
Mar 07, 2011 | Nokia N97 Cell Phone
My printer says insert memory card
Welcome to FixYa...
I assume the message is not an error message and does not indicate an issue with the product. The message is designed to be an invitation to print photos from a memory card. Follow these steps to insert a memory card into the product.
  1. Locate the memory card slot on the front of the product that is compatible with the memory card to be printed from. Each type of memory card slot accepts only one type of memory card, and only one memory card can be inserted at a time.
  2. Insert the memory card into the appropriate memory card slot.
Some times you may be trying to print Some Data may be from Memory card , you Choose already-But actually your MMC not in/Not Properly in...Hope you find it.....Thanks for Contacting FixYa...
Jul 03, 2010 | HP Photosmart C6280 Printer
I have a sandisc memory stick pro duo 4gb and it is too small to fit in the memory card slot of my laptop which is an acer aspire 7220 series. please help x
Hi there!
Simply insert the card in it's adapter, then insert it into the memory slot.
However you can buy yourself an external USB card Reader supporting your pro duo card.
Please rate this advice as it's very important for us.
Good luck friend!
Mar 13, 2010 | SanDisk 2GB Memory Stick PRO Duo Memory...
I have a lap top Dell Precision M20 and replaced the old ram from the slot below the keyboard with 512 MB by a new with 1GB. It worked fine! Since I bought two times 1GB, I inserted also the second in the...
these different ram slots have different bus speed so they really don't work if you are using them both at once.
Please check your laptop's documentation about the speeds of these ram slots.
Dec 27, 2009 | Dell Precision M20 Notebook
Storage card formated but it still does not show up. please help
xda orbit can only hold 2gb sd memory stick and doesnt recognise the HD-micro-sd.
or..
try formating it in a PC or laptop.
Dec 11, 2009 | O2 Xda Orbit Smartphone
How to use the memory card reader
To access the memory card reader without using the software provided, follow the steps below. If no card is inserted, the green light on the card reader will be on.
Insert a memory card.
• Insert the card with the brand name label facing up.
• If there is an arrow on the card, make sure it points toward the printer.
• If needed, make sure you connect the memory card to the adapter that came with it before inserting it into
the slot.
Wait for the light located to the right of the slots on the printer to come on. The light blinks to indicate the memory
card is being read or is transmitting data.
• The printer recognizes one memory card at a time. If you insert more than one memory card, a message appears
on the display prompting you to remove all memory cards inserted.
• If a USB flash drive is inserted together with the memory card, a message appears on the display prompting you
to choose which memory device to use.
When reading of images is complete, the number of photos found appears on the display. Then you can make your selection and print. these are the types of memory card supported by you printer.
xD-Picture Card
• Secure Digital (SD)
• Secure Digital High Capacity (SDHC)
• Mini Secure Digital (with adapter)
• Micro Secure Digital (with adapter)
• MultiMedia Card (MMC)
• Reduced Size MultiMedia Card (with adapter)
• MultiMedia Card mobile (with adapter)
• Memory Stick (MS)
• Memory Stick PRO
• Memory Stick Duo (with adapter) or Memory Stick Duo PRO (with adapter)
Mar 18, 2009 | Lexmark X5495 All-in-One &USB...
Instruction manual misplaced. Want to insert Memory Card from digital camera and don't know how? H E L P a very non-techie!! Laptop is Acer Aspire 5315. Ta.
what type of memory card u want to insert the memory card slot is on the left side of the laptop beneath expess card slots next to usb ports on the left side , pls check that it supports the card u are trying to use for reading it, it only supports XD/SD/MS PRO DUO/ and not mini sd or trans flash or mmc or some other types the slot is clearly marked with icons of the card types it supports just press this like one inch slot which contains a dummy card to fill the space just push and this dummy card will come out from the slot then insert the supported card type into the slot and the windows will recognize it in my computers as a removable drive icon , pls let me know if i can help u more on this
and pls rate me fixya if i have fixed ur problem
regards
zohail
Mar 02, 2009 | Acer Aspire 5315 Notebook
New memory not recognised when installed into spare slot
"Put it in and reboot"... be sure the aptop is OFF when you add memory! Otherwise, you can damage BOTH memory and laptop! Once memory is installed there is no "trick" to get it recognized. If it is good and meets the BIOS specs, it will be recognized and registered after a cold boot.
1. Be sure the memory is inserted properly (both clips on the sides are flush with the half-moon tabs between memory and metal clips).
2. Sometimes on a memory slot that has been empty a long time (and gets a bit corroded) it is a good idea to insert the memory, remove it again and reinsert 5 or 6 times (only) to clean the contacts.
3. If number 1 and 2 have been done, and you still have this error, then there is a problem with the memory:
It may be the wrong speed (PC100 instead of PC133, etc)
It may be too LARGE for the BIOS to use (all laptops have maximum memory per slot specs that must be observed, because the laptop cannot see memory that is greater than its specified capacity.
In any case, check the manual or the website for your laptop, to get the specifications for memory type AND capacity per slot, and TOTAL memory if you have two slots -or memory soldered on board).
Feb 10, 2008 | Computers & Internet
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
