Question about Zanussi TC7114W Electric Dryer
Zanussi tce 7227 w - fault
My tumble dryer seems to have developed a fault, I put the load in and start the program the machine makes 4 attempts to start but after the 4th attempt the end of program light flashes (along with a 'beep').
Can you please advise what the likely fault will be please.
SOURCE: TCE 7227 W tumbledryer waterconductivity needing regular restting
Carolsquires, I have the same problem with 7227, did you get a solution?
Trevor
Posted on May 31, 2010
Zanussi Tumble Dryer TCE 7276W error code E50 - what shall I do? I put washing in TD and set it A and turned it on, it came up 2.05 as it always does but after some time, I come across "End" is...
Hello this is Dennis from blue hawk electronics I had the same problem with my Zanussi tumble dryer and all I did was to take out he front circuit board and reflow board and has been working fine now for 9 months and still going strong
Sep 03, 2011 | Dryers
Trevor
Feb 17, 2010 | Zanussi Dryers
My tumble dryer ois not heating ?
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Jan 10, 2010 | Zanussi TC7102W Electric Dryer
Just bought 2nd hand a supposedly good working order zanussi tumble dryer got it home turned it on drum turning but cold air in dryer. we then noticed that the back got rather hot.and then nothing. due to...
this could be the stats or the drum is not turning Common faults -
Jan 10, 2010 | Zanussi TD4112W Electric Dryer
Broken Zanussi tce 7127 w dryer
the dryer is telling you a trouble code like in a car when something is malfunctioning with it, try to call your manufacturer and ask them to tell you what that code means.
Nov 06, 2009 | Dryers
I have a zwd12270w. Seven second after pressing
The problem is with the tumble drier heating element. If you remove the top of the machine (disconnect it from the electricity supply first!) you will find a big metal oblong "bar" that runs from the front to the rear of the machine. At the rear there are 4 white wires connected to the metal "bar". Make a note of where they go and remove them. You may need pliers to get a good grip of them. Once removed, the washing machine should work just fine but obviously the tumble drier will not. This is a well known fault and it may be worth contacting Zanussi as they MUST know about it!
Jun 28, 2009 | Zanussi ZWD12270 Front Load Washer / Dryer
Zanussi TC 7114 W Condenser dryer leaking water
Maybe it's the water collector's upper side which leaks...
Apr 15, 2009 | Zanussi TC7114W Electric Dryer
Zanussi TCE 7276 W Condensing Dryer
hi i have a problem with the zanussi 7276w model all lights are on ready to start but the tumble dryer will not start
Sep 21, 2008 | Zanussi TC7114W Electric Dryer
Tumble dryer fault
usually this is a sign the felt bearings on the drum, or the roller bearings under the drum are worn and need replacing
felts and rollers should be visible once you open the case
check the rollers turn freely, check the felts are not worn through
replace both rollers or both felts if one is worn
Jul 01, 2008 | Zanussi TC7114W Electric Dryer
Got a 4 year old zanussi washing machine and its developed a fault where when it gets to the spin part of the program it just sits there and does nothing,read the manual about unbalanced loading but even...
check wether it does the same thing unloaded if not then its likely to be carbon brushes ,,, presuming it is tumbling durin the wash/ rinse cycles also check front filter zanussi wms will not spin if they cannot clear all water in the drum
Jun 19, 2008 | Washing Machines
Zanussi TC7114W Electric Dryer Logo
257 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
jb_ab1
jb_ab1
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
