Yeah I found out I actuall HAVE a USB port. Man, am I dumb. Well that's
weird, does a USB port be compatable with win95 original? Also how do I
know that my USB port is enabled? It doesn't say anything that I could
find in windows. But yet I have one. So for this mp3 player I am about to
get requires the USB port enabled, how do I know if it is enabled, and if
not how do I enable it. HELP! ALL THIS CONFUSION IS DRIVING ME INSANE!
no it is not, it is walking me to insanity. PLEASE! HELP ME! thanks.
Posted via CNET Help.com
Rating: 0%, 0 votes
couple of hours research to get it finally installed.
First issue was a missing file in Windows. This was a cheapo D-Link DSC-350
camera (does both still photos and operates as a web cam. Fine for my
purposes.) Seemed the NTKERN.VXD file was missing from the Windows operating
system. Was never inititally installed with Win98 since I was not running a
device that required it when Win98 was originally put on this PC.
This info was nowhere in the manuals that came with the camera, but was only
available from a FAQ available from D-Link's support web site. Had to look a
bit, but it was there.
You would have thought that when D-Link sold a $129 camera that their
bundled software would have checked for needed files not likely to be
present. My USB scanner runs fine without that file, so I knew USB worked on
my PC. However, who buys a $129 camera as their second digital camera
purchase? This purchase is the first time a USB camera has likely ever been
attached to that computer. You'd think a basic file check would be part of
the installation, but apparently not.
So, my first suggestion is to go the web site for your Intel CS330 and see
what their FAQ's, tech help or their Knowledge Base have to say on the
subject. Often it is a well known issue that was only discovered after your
product manuals were printed and shipped. If lucky, you'll find it right out
of the box and only need to say a few curse words.
The second problem I had was that I had installed a USB port replicator on
my Dell. This was so I could install new USB devises from the front of the
PC. Pulling the box out is a PITA given its location in my furniture; about
15 minutes just to plug something into the rear of the PC and put things
back.
After much reading and searching, I came across a single line at the end of
an obscure note that said this product doesn't work with USB port
replicators. NONE of the problem FAQ's mentioned this. The product
literature mentions nothing about this requirement. That I don't understand!
I shut my PC down, pulled it out and plugged the USB cord into the second
USB connector on the back of my Dell and put everything back. On boot, the
camera worked perfectly.
Silly me, I thought USB was a "standard" interface. Guess not, though I
still don't really know if this is D-Link's fault or the USB port
replicator's fault for "cheating" on the standards.
It all just goes to prove you can assume NOTHING when you buy a new product
for your home PC. I knew my system from top to bottom. I read the fine print
on the product specs at the store. Everything seemed to match up just fine,
but in the end it was a PITA to get things working correctly. Even now the
problem has been solved, I can find nothing in the information that came
with the camera that would have alerted me to any of these problems.
In your case, Win95, even with the update files, may not be adequate to
support your camera. You might need to update the OS. As noted before,
Intel's support site should have a notation somewhere regarding this issue.
Was this solution helpful? Show your Appreciation by rating it:
Rating: 0%, 0 votes
When Windoze 95 OSR2.x came out, some of the USB hardware that came with
the machine was not up to today's standards. Some of the chipsets could
only handle low bandwidth devices such as mice, printers, keyboards, etc.
With today's high end, high bandwidth, fast transfer needs, some of these
chipsets will not work.
One that I know of was/is the:
Intel 82371SB USB Controller
(Note the SB. I believe that the controller with the same number,
but different letters (AI?) works well)
If you have tried everything you possibly can with the software and even
upgrade to Win98+ and still can't get it to work, it could be the chipset.
You can get a 2 port PCI card from most any dealership for about $35 (US).
These boards are PnP and can handle the high bandwidth needed for today's
high end, high speed devices.
Regards,
Ben
Forever Young Software
To reply by email, please remove the zzzzzz's
Batteries not included,
Some assembly required.
Rating: 0%, 0 votes
: Trying once again to use my Intel CS330 camera but cannot install USB
: function. Using DFI K6BV3+/66 MB w/VIA chipset. Have loaded latest
: VIA chipset drivers including USB Filter to no avail. Substituted MS
: UHCI driver, also NG.
: What gives?
You need at least Win95 OSR2.1 to use USB. If you are running a version
of Windoze older than version 4.00.950B (i.e., if yours is 4.00.950A or
4.00.950) you're out of luck.
If you've got 4.00.950B there is an update you can get from MS that
installs (among many other things) USB support. Check out
#, which gives lengthy details about
all the various windows system updates.
Fred
Fred Smith --
The Lord detests the way of the wicked
but he loves those who pursue righteousness.
Proverbs 15:9 (niv)
Rating: 0%, 0 votes
WHICH REVISION OF W95 IS IMPORTANT
the original release only promised support
release B had it included, but not in the install - there's a seperate
folder on the CD for it
It does work, but not as good as does the W98 version; I have a friend who
uses a scanner and a camera and it works ok for the scanner, but the
drivers for his camera force him to use a serial connector...
Rating: 0%, 0 votes
What gives?
Rating: 0%, 0 votes
support usb.
Windows 95b and 95c have limited usb support, make sure the device you are
using is compatible with 95, most require Windows 98.
Rating: 0%, 0 votes
This won't work with all peripherals though.
Epson (and probably some other) USB printer manufacturers
state that at least some of their USB print redirectors will not
work with anything less than Win98 - and they're right. They
will install (with warnings) but won't work with any version of
Win95.
I'd recommend Win98se if you want full USB functionality.
Or 2000 (if your hardware supports it) - but some older
USB peripherals (like my early NetComm USB modem)
will never be supported by Win2k.
Rating: 0%, 0 votes
Check your Control Panel/Systems settings. Click on your Device Manager tab;
there should be a setting for "Universal Serial Buss Controller" if yours is
installed and functioning. Otherwise, see the upgrade and patch info on the
Microsoft web site others have recommended.
Rating: 0%, 0 votes
<h_u_> wrote:
Yes, and no.
Or rather the original release didn't have the required support, but there
is a patch.
# will get you to the right files.
Steve Pampling
Rating: 0%, 0 votes
install.
easiest way to find out if it's already in there is to plug in your usb
device.
Post a New problem for D-Link DSC-350 Digital Camera
Email this problem
Can you Help with these Digital Cameras problems?
Does Vista Vostro support...
camera recording software
