I have tried on two seperate pcs and I cannot get my reddmango photo frame to work, it will not register at all. I can plug a memory card directly into the frame and it works but the usb - pc connection seems to be faulty. I have also changed the appropriate settings as described in the manual. Anyone have any ideas?
SOURCE: 7" Trutech digital photo frame
I don't have the booklet for this darn thing and I just got it for mothers day.... I have a sandisk in it and I can see the pics just fine, but it doesn't save them??? I can only view when I have something in it??? That's crazy?? Isn't it?? Help
SOURCE: Motorolat MOTOKRZR K1 File Transfer
take the battery out and insert slide SIM card in. direction should be shown (it goes right underneath where the sdcard should be).
SOURCE: Philips digital photo frame 7FFI series
Here`s a tip i found for you...
1. Connect the frame to your PC using the supplied USB connector.
Navigate to the \DCIM\100Frame directory and delete all the Phillips
advertising pictures there.
2. Create a directory on your PC and put copies of all the pictures you want to display there.
3. Download the free picture resizer utility from Microsoft at:
http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx
(Look
for Image Resizer in the right column). After installing it, "Select
All" pictures in the directory you created, then right click and select
"Resize Pictures" from the context menu. Choose the 640x400 radio
button. Sort by size and copy all the small ones into the
"\DCIM\100Frame" directory on the frame drive (Called Removable Disk on
my PC).
SOURCE: ibm Travelstar usb 2.0
I assume you can't see it in Windows? When you connect it can you hear the drive spin up? If not then there is a hardware problem - motor failure, jammed platter. If you hear it clicking or clunking then it is likely to be a stuck head or actuator. If so sometimes you can give the drive a sharp **** to and fro to try and spin the platter - don't do to long though. If this doesn't work then you would need the data removed by a data retrieval company.
If the drive does spin freely you may be able to fix by doing in order:
running check disk (properties of drive then tools)
using a data recovery program of which there are a few
using commercial data retrieval company.
Hope this helps
SOURCE: kodak easy share SV 811
I have the pictures in my External Hard Drive. When I turn on the Kodak Frame, the message is "Connected to computer. Use PC interface to copy files" I can not view my pictures on the frame. Please help.
