Question about D-Link AirPlus DI-524 Wireless Router
Laptops won't connect to D-Link router after resetting modem
HI , My comp system was shut off. When we turned it all on our modem wasn't working. ( bellsouth modem ) we called modem support and our desktop worked again. HOWEVER, now our 2 laptops are not connecting to our wireless. D-Link 524 2.4gz. We reset the router but still nothing..we can connect to a neighbor's system and that is how we are on right now.
    Master:
  • 538 Answers
Hmmm..well..does that router also have ethernet ability? if so, please connect one of your laptops that way, and let us know if that helped..trying to isolate the failure here.
Posted on Oct 14, 2008
I just purchased this treadmill. The internet was working on it. I needed to upgrade the firmware; but it wasn't allowing me to do so. I then moved the positioning of the treadmill. I still have a...
Please in the section open connections network give to repair, and the system will repair.
If the problem persist reboot the Modem-wireless router again, and see if the signal is coming more Strong.
Reset the Modem in the small hole, with some pencil introduce the pen and reset it
Retigh the wires coming from your Modem Wireless router. And finally Test again if is working. sincerely.
Sep 22, 2011 | Nordic Track NordicTrack Elite 9500 PRO...
Just bought new laptop with window 7 i alreadu have a desketop ant two laptop using window vista on network the new compuuter won t connect
first be sure to check that your wi-fi in on on your laptop. the next step is to reset your router, if that does not work, reset your modem as well.
Mar 11, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
Router or modem problem
hi..try to resets the setting of router or try to open the setting of router using/type this #>192.168.1.1<thanks and good luck..^_^
Mar 23, 2009 | D-Link (DCM-202) Modem
Connection
Hi Susie
With related to your particular issue it seems like that your broadband modem is not configured for the router. There are basically 2 types of connection. DSL and Cable modem. Verizon, ATT are DSL and comcast other providers give you a normal cable broadband connection. If its comcast make sure the cable from the comcast modem is going to the internet port in the linksys router and also make sure that there is a system connection the linksys router and the cable from the system goes to any of LAN 1, 2, 3 and 4 ports. Then reset your cable modem by using a pin and inserting to the reset hole in the modem. You could use the same step to reset your linksys router as well .If its a verizon or dsl connection you need to put normally your username and password in the router page. here is the link to how to configure linksys for your internet modem.
Here is a video as well on it?
http://in.youtube.com/watch?v=vSAXMO7aNzg
http://tinyurl.com/5tqqhl
Also post the linksys router model. your ISP modem model number and also information on how many systems are wired to the router and wireless and let me know if you need more help.
Thank you
Rakesh
Dell Laptop Expert
Jan 09, 2009 | Linksys Wireless-G Broadband Router
MY INTERNET WAS DONE AND CALLED COMCAST TO RESTART AND THEY TOLD ME IT WAS MY ROUTER THAT NEEDED TO BE RESET, THEY TRIED TO RESET, AND THERE IS A CONNECTION THERE BUT NOT WITH THE ROUTER HOW CAN I FIX THIS
Hi
Connect the modem and the router. Make sure the cable from the modem goes to the internet port in the router.
Reset the modem.Resetting the modem can be done by using a paper clip and insert it to the reset hole found on the back of the modem. Restart your router and systems.
Check if this resolves your issue. Post your results.
Thank you
rakesh
Dell Laptop Expert
Jan 07, 2009 | D-Link DI 514 Wireless Router (DI-514)
D-link dir625
When your laptop is working, check the ip address.
Open your DOS PROMPT, type iconfig then click enter. If your ip address on the laptop is 192.168.x.x, that means that you are getting your internet from the router. If your ip address is (just an example:68.x.x.x, that means that the router is not functioning properly.
If the laptop ip is 68.x.x.x(just an example), make sure that your comcast modem is connected to the INTERNET PORT of your router.
You just bought your router so the best way to deal with this problem is call Dlink tech support so they can walk you thru the router configuration.
Good Day
Mar 15, 2008 | D-Link DIR-625 (790069292637) Wireless...
No connectivity to internet
Looks like when you reset the router/mdm you have los all yur configuration and back to the default factory settings.
Bridge the modem first .
1. In your web browser browse to »<your mdoms deault gateway> This address will be found in your manual of your modem
2,Depending on your modem make sure you use "Bridged Mode (PPPoE is not used)"
3. Click Save Changes.
4. Then connect the router
5.Configure the router for PPPoE using your ISP uid/pass
6.Configure your wireless using WEP(if applicable)
7.after all configuration shut the desktop,laptop,router,mdm and pwr them in seg..first modem and then router and then your desktop or laptop
Cheers !!!
Feb 26, 2008 | D-Link GamerLounge DGL-4300 Router...
D-Link AirPlus DI-524 Wireless Router Logo
79 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
