Question about Whirlpool Duet GHW9150P Front Load Washer
Water fills up in machine when off
Every morning I can open the washing machine and find several inches of water in the tub. The door was left open one night and flooded the floor. Every thing else seem s to be fine and I don't get any codes. Please help!
Its the valves inside the washing machine not the valves where the pipes go
Posted on Oct 14, 2008
  • 943 Answers
HI thanks for your question. i would replace the water valve, its not shutting off completly. replace the valve, thats where the hot & cold water go .
The dishwasher runs through it's cycle but does not clean the dishes properly and leaves a cloudy film and smears on the inside of the machine and the dishes
    Common Problem
  1. Confirm the wash water is hot
    1. Try heated wash(sani wash) if available
    2. Run hot water in sink to warm up before starting
    3. At least 120 degree Fahrenheit water temperature
  2. Open door check wash arm position start washer for a minute
    1. Confirm wash arm has rotated
    2. Check for plugged spray tips at either end of wash arm.
    3. Use small tweezers to remove
    4. Check for rack and dishes interfering with arm rotation
  3. Place cup in upper rack with opening up cycle washer.
    1. Confirm that cup quickly fills with water
    2. Not washing check water level in tub mim 1 1/2 inch
  4. Discontinue use of rinse/dry liquid additive.
    1. Confirm rinse/dry additive not leaking from dispenser into tub
    2. Washer detergent contains sparkle additive and too much sparkle/rinses/dry additive will coat dishes
    3. Try alternative wash detergent that contains minimal rinse/dry additive and use without liquid rinse/dry additive.
  5. It will take several wash cycles after the elimination of rinse/dry to purge the oily film from dishes and machine..
  6. If success "joy" is achieved with no additives then cautiously add back wash detergent with additives. Additives are important to facilitate drying and protecting the glassware china from leaching. The leaching process permanently etches the surface of glassware leaving a cloudy appearance.
Jan 03, 2016 | Dishwashers
I have a strange odor
It is normal for all models of washing machines to have a gallon or two of water left inside the bottom of the washer and in the drain pump. This is not the cause of odor. The smell is being caused by residue left on the inside of the plastic outer tub.
The best way to clean a stinky washer is to use a washer cleaner that is able to be used with clothing in the washer. The added bulk of the laundry will raise the water level to include the splash area 3-5 inches above the normal waterline. This splash area always has the worst buildup.
After the odor is gone you'll need to change washing habits to keep it away.
Oct 19, 2009 | Washing Machines
Random filling of the tub, door open, leaks on floor.
The only thing that can admit water with the power off to the machine is a bad Fill valve. Replace
Aug 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Tub smells like mildew. Possible water still in tub but not visable. When tub is shaken hard by hand, slight sound of water sometimes. Still cleans well.
You will never get all of the water out of a washing machine using the pump
The only way to do it is to take the drain hose out of the standpipe remove all clips so that it lays flat on the floor and put it into a bucket
Even then there will still be a little bit left in.
Run two very hot programs witha good dose of washing soda placed in the drum before you fill it
Leave the door open when the machine has finished to allow it to dry off
Jul 09, 2009 | Whirlpool Washing Machines
When machine is not in use, with door open, tub will have water
You have a faulty fill valve
If you want to check which one, try turning off the cold supply only before you go to bed
If the washer has water in it next morning it is the hot valve that has gone faulty if it is dry then it is the cold one
They are easy to change and can be bought from a number of suppliers
Jun 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE3 Front Load Washer - Leaking Water into wash tub
THE WATER VALVE IN THE WASHER HAS TO BE REPLACED THE COST OF THE WATER VALVE IS ABOUT $25.00
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Flooding everywhere
You are right. Sounds like the washer is not being told to shut off. If the washer will stop filling when the power is shut off to it: Open the front panel by using a putty knife to push in on the clips about two inches in from each side at the seam of the front panel and the washer top. Tilt washer front panel forward and lift off bottom pegs. Pull the tube off the outer tub at the left side, cut off and inch and a half, poke a thin wire into the hole on the tub end and remove, then put the tube back on. (do this with the tub empty) You can only do this one or two times before the tube starts to get too short, so from now on, every two or three months, fill the machine to the lowest water level with hot water and several cups of bleach and run a cycle, including rinses, to help prevent the goop from reforming in the tube area again.
If machine still fills when power is off, replace water valve.
Nov 12, 2008 | GE WHRE5260E Top Load Washer
Water in bottom of dishwasher
You could have a defective fill valve that is not shutting off properly. Look for a fill inlet opening somewhere on the inside casing of the wash tub. Usually it is on the left hand side of the machine looking in. While the dishwasher is sitting idle, watch the fill valve opening to see if water is leaking in. It could be a minor as just a drip. However, over a period of several hours you could end up with a wash tub full of water. Over a weekend with no one home, it could overflow onto the floor. The valve usually cannot be repaired and would require replacing. Good luck.
Jun 12, 2007 | Bosch 24 in. SGS43C12 Classixx...
Whirlpool Duet GHW9150P Front Load Washer Logo
99 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
