I have just bin an bought a bluetooth usb dongle with the instrlashion disk an it starts to install then it stops an askeds is to insert the disk but it isnt reading the disk an say to search the internt 4 help
    Genius:
  • 1,250 Answers
For installing the blue tooth , first insert the cd and run the setup don't attach blue tooth device at this time,
it will insall drivers, check continue any way option, after that plug in the blue tooth dongle, if again it will ask for driver check continue any way option, do it
how do you like the solution please rate it
Posted on Oct 14, 2008
Need Download Software
You could go online and download it from the manufacturers web site.
Mar 07, 2014 | Adapters.com Bluetooth USB Adapater, USB...
Tip
How to Fix a Bluetooth Dongle in a computer
<p>Bluetooth devices connected to a computer system via a wireless signal, so that the desktop of annoying cables and wires to strip. Even if your computer does not have a built-in Bluetooth receiver, you can create a Bluetooth dongle, the function adds the system to connect. If the dongle is not working to resolve the situation. <br /> <p><br /> <p>1. Check the system requirements for the Bluetooth dongle. If the system does not fit all the requirements, the device will not work. The requirements for the Bluetooth dongle can be printed in the manual and packaging. You can compare that with what is running on your computer by clicking "Start" "Control Panel" and "System". This gives the computer hardware. <br /> <p><br /> <p>2. Unplug the Bluetooth dongle, restart the computer, plug it into a USB port. If you leave power on the computer with the dongle already instead, the system can not detect the devices. Restart the computer and perform this action helps to correct the problem. <br /> <p><br /> <p>3. Remove the dongle from the USB port and plug it into another compound. Some USB ports do not meet certain computer hardware detection. Changing the connection port fixes this. <br /> <p><br /> <p>4. Install the driver on the included CD driver installation. Without the driver, the computer can not detect and use the dongle. Insert the installation CD driver on your computer and follow the steps on screen to install the driver on the system. <br />
on Jun 26, 2011 | Computers & Internet
Hooked hdmi dongle to projector. Used kindle fire hdx. Picture works fine but no sound from projector speakers. No sound from kindle speakers. Need to use kindle headphone jack for sound.
follow this steps and fix it. God bless you
Check the system requirements on the Bluetooth dongle. If your system does not fit all the requirements, the device is not going to work. The requirements for the Bluetooth dongle are printed in the user manual and packaging. You may compare this to what is running on the computer by clicking "Start," "Control Panel" and "System." This displays the hardware running on the computer.
    • 2
Disconnect the Bluetooth dongle, restart the computer, then plug it back into a USB port. If you power on the computer with the dongle already instead, the system may not detect the equipment. Restarting the computer and performing this action helps correct the problem.
    • 3
Remove the Bluetooth dongle from the USB port and plug it into a different connection. Some USB ports fail to detect certain computer hardware. Changing the connection port fixes this.
    • 4
Install the driver on the provided driver installation CD. Without the driver, the computer is unable to detect and use the dongle. Insert the driver installation CD into the disc drive of the computer, then follow the on-screen steps to install the driver onto the system.
Oct 29, 2013 | Brookstone HDMI Pocket Projector
Usb dongle is not working
Step 1:
A Bluetooth dongle is an external Bluetooth device used to enable your PC's Bluetooth connection. Many Bluetooth dongles come without installation disks since the software is pre-programmed into the actual USB stick. These Bluetooth dongles are very useful on netbooks that don't have Bluetooth connection, since netbooks have no CD-Rom drives. Turn on your PC. Insert the USB Bluetooth dongle into the USB port on your desktop tower, or the USB ports located on the perimeter of your laptop. Wait for the program to auto run. Once you connect your dongle, the driver program should launch. Follow the onscreen prompts to install the dongle. A dialogue box should open that says "Installing Drivers" from the taskbar. Allow the driver to install completely before closing the box. Unplug the dongle and restart your PC. Once the PC has been switched on, insert the dongle. Double-click "My Bluetooth Places." This is the Bluetooth icon located in your taskbar, and it should launch the "Initial Bluetooth Configuration Wizard." Click "Next" on the first screen. Next, type in the name of your computer and select your computer type from the drop-down menu, then click "Next." Click "Skip" on the onscreen prompts, then finish. Pairing the Devices Turn on your external Bluetooth device. Double-click "My Bluetooth Places." Select "Find Bluetooth Devices." The name your Bluetooth device should display in the next window. Right click the icon for your Bluetooth device, and scroll down to "Pair Device." Enter the Bluetooth pin code for your external device in the "Bluetooth Pin Code Request" pop-up window. Then click "OK." The default pin code is normally "0000" or "12345." You can find your pin code in your user manual. If you are pairing a cell phone to your PC, you will have to enter the same pin code on your cell phone to establish the Bluetooth connection.
Apr 10, 2013 | Computers & Internet
Sir i want to install a bluetooth facility in my laptop it is accer/emachines e727
The easiest way is to purchase a bluetooth dongle for your usb port. I use one myself- generally the install just involves running the drivers disk then inserting the dongle. I would personally recommend using one of the micro dongles that does not stick that far out from your system- I have broken 2 longer form factor adapters by having them get bent!
Oct 03, 2010 | Computers & Internet
Unable to connect wireless deskset to my computer.Is there a specific USB receiver required
1st Step: Have you inserted the USB dongle which is came along with the product. Also check and install drivers for the same.
2nd Step: Go to device manager and check the USB status, Also install drivers for USB if required.
3rd Step: Synchronize the USB dongle by pressing the button which is on the Dongle.
Revert back for more assistance. Also give your valuable feddback and rating on the solution.
Feb 07, 2010 | Computers & Internet
Just got the bluetooth keyboard and mouse w/ no manual. how do i set it up?m/s bluetooth keyboard WBR0295 X08-92475 product ID 69418-545-205333 5-00321 and m/s bluetooth mouse p/n X08 - 87659...
Hi.
Before starting, make sure the keyboard and mouse are ON and with batteries.
Whit the PC already ON:
* The first step is to plug in the USB Bluetooth adaptor.
* Once the Bluetooth adaptor is inserted, allow Windows to install the drivers.
* Once Windows gives it the OK, the USB dongle should have a light or even a button. (If you don’t see a button the "yellow" light is the button).
* Press the USB dongle button....this will tell the dongle to start looking for a Keyboard or mouse.
* On the underside of the mouse (and keyboard) should be a a small button.
* Press the button(s) for ~5 seconds, then release.. this tells teh keyboard (or mouse) to look for a dongle.
This should show a connection between the dongle and the keyboard (or mouse).
Or
With the PC Off:
* Just connect the dongle
* Do the button sequence as described above, unit the dongle light goes “solid” again.
* Start the PC and keyboard and mouse should work perfectly.
Cheers,
Ed
Oct 24, 2009 | Microsoft Windows XP Professional
My PC does not have bluetooth. Hw do i download one
You will need to purchase a blueetooth dongle.EXAMPLE below
http://cgi.ebay.co.uk/NEW-NANO-Mushroom-USB-2-0-BLUETOOTH-ADAPTER-DONGLE-EDR_W0QQitemZ220477537048QQcmdZViewItemQQptZUK_Computing_Networking_SM?hash=item33557c3b18&_trksid=p3286.c0.m14
Sep 14, 2009 | Microsoft Windows Vista Ultimate Edition
Acer aspire 4730z bluetooth problem
Yes your Machine got WPAN: Bluetooth® 2.0+EDR (Enhanced Data Rate).
If its not working then you need the drivers, you can download them free here
If you problem was solved, Kindly do Rate!
Jul 31, 2009 | Sony MEX-BT2500 CD Player
ACER L320
Now a days all optical drive take small disks.Better to insert external optical drive and install it.OR
Better to ask for where u purchase.
Feb 26, 2008 | Acer Aspire™ T180 PC Desktop
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
