How do I get to the drain pump to unclog it? It's a GE model WBSE2090
  • 943 Answers
+HI thanks for your question. to remove the front panel. use a pud dy knife, and shove it between the top, and front, the front will pop out, remove. the pump is on the right. thanks the appliance doc. please rate my answer. thanks
Posted on Oct 14, 2008
Need help to unclog a drain on a GE Profile Bottom Freezer Refrigerator Model PFSS6PKW/PFSF6PKW. Specifically, where does the drain end? Behind the freezer & how to access it? Also found eroding t
You should be able to see where the drain tube comes out over the drain pan. Get some thin wire and run it down the tube and when it comes out in the drain pain, tie something onto it like a small piece of cloth and pull it back up through the drain tube to swab it out. The tape is no big issue, if you want to do something about the rust, there is a product that autoparts stores sell that turns rust into a hard, rigid metal. Or you can use a blow drier to make sure it is dried out and then spray rubber under coating on it.
Nov 18, 2013 | GE Refrigerators
The G.E.dishwasher has water standing. first it was the clogged sink. I took the pipes out and unclogged them. Now it is the d.w.
Hello & Welcome to FixYa
As the water did not drain completely then check the drain hose & drain pump filter for any clogs/obstructions, if you have already cleaned these parts and the unit will not work then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Dec 08, 2010 | GE Dishwashers
How do I unclog defrost drain on a model TBX18W?
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Sep 26, 2009 | Refrigerators
GE Aurora Front Load Washer leaves the clothes soaking wet
there is a filter under the washer door behind the panel...its white just unscrew it and clean out the filter and that should solve your problem.
Sep 18, 2009 | GE Washing Machines
Dishwasher not draining, not getting dishes clean. detergent still present in its space, filters at the bottom appear clean and hose to drain appears unclogged Nautalis GE 24"
sometimes this drain motors get stuck..you have to turm them a couple times with your hand, make sure you shut off power....also sounds like you have problem with cycling...i wish a can take a look on it....turn you drain pump...and try to start again see what is goning to happend....please let me know you results totalcarefl@yahoo.com
Aug 25, 2009 | GE Nautilus 24" Built-in Dishwasher
How do you unclog the condensation drain on a GE gss25wgma model refrigerator? have water pooling and freezing on the freezer floor, spilling out onto the floor within days after removing it. Thanks!
usually the drain hole underneath the evaporator in the freezer section can restrict with anything from ice to bugs. take a wire hanger and try to run it all the way down into the drain pan. if you have ice then try to poor cool water over it to defrost ice. then use hanger
Jun 22, 2009 | GE GSS25JFM Side by Side Refrigerator
Water puddles front left of side by side ge profile fridge
If you clear the drain, the water will not fill up again. (try hot, but not boiling, water, forced into the drain hole with a turkey baster) When drain is clear, water will run into the drain pan located near the compressor. The fan will cause that water to evaporate.
Jun 07, 2009 | GE Profile 20.7 cu. ft. CustomStyle...
GE Profile Dishwasher with water in bottom, won't drain Water on the bottom of the unit
find the grille above the pump remove the grille and unclog the pump
Apr 28, 2009 | GE Dishwashers
Clogged washer pump
you have to take out the little motor that drains the water and clean it up , first you open the front panel or back panel depending of the model , second follow the DRAIN HOSE to where its attached to the DRAIN MOTOR , remove the motor for cleaning , its probably clogged.
Apr 05, 2008 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
155 people viewed this question
Top Washing Machines Experts
