Question about JVC Televison & Video
Dim display on jvc dr-mx1sek - JVC Televison & Video
  • JVC Master
  • 19,396 Answers
That happens when the display backlight blows.
On this kind of devices the backlight is often a led soldered to a small pcb and should be replaced by a technician, to avoid risk of causing more serious damage to the unit.
Posted on Oct 14, 2008
I need a jvc dr-e53lbk owner's manual
JVC DR-E53BK DR-E53LBK Service Manual PDF Free ...
freeservicemanuals.info/en/servicemanuals/viewmanual/JVC/.../DRE53L...
Brand, JVC. Type a, DR-E53BK. Type b, DR-E53LBK. Type c. Type d. Product, STEREO DOUBLE CASSETTE DECK RECEIVER. Year ...
[PDF]DR-MV5S - JVC
Jan 10, 2016 | JVC Televison & Video
How do you Reset JVC DR-MV100 DVD Recorder/VCR Combo?
First press and hold the (Stop) button first and then press& hold the (Standby/On) Button until you see *RESET* flashing on & off on the display, hold both buttons in until the unit shuts down.
Nov 12, 2012 | JVC DR-MV1S DVD Recorder/VCR
JVC DR-MV80B display says hello then shuts itself off.
On electric board you need to change the STR,and work fine.....
Sep 09, 2012 | JVC DR-MV80B DVD Recorder / VCR Combo
I have a JVC DR-MX1SEK dvd combi recorder. It was working well when I was searching for another problem when I removed the plug from the mains socket and a blue flash came out of the recorder. I removed...
Not sure if you have resolved this but that fuse is widely available. It is a 20mm x 5mm 2 amp slow blow glass fuse. It is perfectly possible that your replacement was correct but that a separate fault in the machine is causing the fuse to blow. Remember, fuses are designed to protect things (either the machine or you) and to blow if a fault causes more current than is safe.
Jan 05, 2011 | JVC Televison & Video
I bought a new JVC dvd recorder vcr combo model#dr-mv79b. I lost the manual and need another one. When can I get another one?
DR-MV79BC:
http://books.jvc.com/booklist.asp?Model=DR-MV79BC
DR-MV79BJ:
http://books.jvc.com/booklist.asp?Model=DR-MV79BJ
Mar 14, 2010 | JVC DR-MV78B DVD Recorder
I need a user manual for JVC DVD RECORD/VCR COMBO Model DR-MV1S
I got mine on-line, though I've forgotten where. Do a search using "JVC DR-MV1 manual". If all else fails, I could send you a copy, The pdf size is 8196 kb.
Feb 03, 2009 | JVC DR-MV1S DVD Recorder/VCR
JVC DR-MH30S DVD Recorder Image file
ciao! tutti vittime del dvd rec [jvc dr mh20-]..jvc dr mh 30...jvc dr mh 50..e un risolvere dell problema di LOADING...il mio jvc dr mh30..di 6 mese e roto ..ma trovo risolvere..difetto e nel hdd,160gb..e in corrozione..e roto hardisk,solo sistema operativo.......con softer COPY CLONE PRO..free da iternet.scarica nell cd room..nel avvio dell pc,che sono due hdd,uno rotto ,e uno buono..guarda instruzione dell cd..e tutto ok,per copy di hdd..e tutto ok per legare poi nell dvd rec jvc dr mh 30..ho provato io e tutto ok...ma io ho trovato hdd dell dvd rec jvc dr mh20..e io ho un dvd rec jvc dr30..ce un problema picollo dopo copy cloner,,mio dvd rec mi conosci solo 80gb..ma perche e in origine da dvd rec jvc dr mh20[80gb]..cercho un hdd di dvd rec drm h30..opure jvc dr mh50..per copy cloner,mio hdd,per conosciere 160gb..opure 250gb..atentti problema di LOADING..e nell due alimenti di hdd..e suporte di dvd..sono quattro line..12v..terra..terra..5v....sono simille anche perhdd..anche per suporte dvd..controla nel condizione di LOADING..se non sono precise..voltaggio..persempio..12v=10v..opure 5v....4.2v..e perdita..da un contesatore electrolitica.e asciugato da lavoro fastidiosa.......se aiuto da poco..non lo so aspettiamo nell mio e-mail....arivederci[ agimqosesda@yahoo.com ]
Apr 14, 2008 | JVC DR-MH30S DVD Recorder
Loading
ok, this same problem happened to many other jvc dr-xxxx s, i think the only answer to this would be to get it serviced or just chuck it out. the cause for the annoying "loading" blinking light is a blown out capacitator, inside the machine itself i recomend u to not try to fix it d.i.y.
Mar 13, 2008 | JVC DR-MV1S DVD Recorder/VCR
JVC DR-M10 DVD Recorder not working
Contact JVC @ 800-252-5722, the "loading" is a known bug and they will fix this defect at n/c even if it's out of warranty period.
Mar 12, 2008 | Televison & Video
Televison & Video Logo
218 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
