Question about Proview PL926WBi 19" LCD Monitor
Proview monitor pop sound
Ok my preview PL926WBi did the white screen thing and my dad took it to a friend and they replaces alot of dead capacitors but forgot to hook up the ground wire when putting it back together and there was a pop sound when turning on the monitor and they took it apart and didnt find what popped does anyone have any ideas what popped inside and if theres a chance to fix it?
  • sicgeniuz Oct 16, 2008
    you were right it looked liek the main fuse was blown but it wasnt black nor round it had a red like cover and it was rectangle but with that name number you mentioned. i hope i can replace that thanks alot man ireallt appreciate it.
    do you sell them ? how much do you want for one? cause i dont know where to go to buy them
I have the same problem when i power on the same monitor that you have it goes white what is the problem?
Is there a repair manual which tells you how to fix it or a service manual for taking it apart?
Call me 253-468-5903 to help Thank you
Posted on Nov 01, 2008
  • 159 Answers
The ground wire may have touched something it shouldn't have. That may have made the pop, but usually you will see where is made contact by a burn or arc mark.
If you get real lucky and depending on what it touch (that is if this is what happenned) you may have just blown out the main fuse.
It is black and round (about 3/8" in diameter and about that height.
It is marked 3.15A.
Another POP could have been a capacitor installed in backwards ??
White screen thing, however, is usually not caused by inverter or power board issues like capacitors !!
Posted on Oct 15, 2008
  • Fran Bednar
    Fran Bednar Oct 16, 2008
    Yes they do make them in rectangular versions also.
    I have the fuses if you can't find them.
    Hopefully that is all that popped !!
  • Fran Bednar
    Email me at
ProView 19" Flat Screen Monitor comes on with
The dark or black picture is caused by a failure in the back light power supply. The problem can be corrected by replacing a few parts called capacitors on the board. Replacing them will require a little soldering but anyone can do it. Here is a link to a page that shows what needs to be replaced.
I hope this helps, if so please rate my solution.
Sep 17, 2011 | Proview PL926WBi 19" LCD Monitor
Proview PL926Wbi
On modern capacitors 2005 or up the capacitors can go bad and not even bulge at the top. I replaced a few in my moms flap panel monitor and found out that there were more that were bad and they didn't show any signs of damage but put your finger on one of those suckers and it burns like a smoking gun.
Apr 10, 2009 | Proview PL926WBi 19" LCD Monitor
Pl926wbi 19"proview monitor,screen goes black every 3 seconds,
Bad capacitors on the pcb boards internally unsoldering ad replacement is indicated.
Feb 17, 2009 | Proview PL926WBi 19" LCD Monitor
ProView PL926WBi
bad capacitors on the board, replace these and the inverters should get there power.
Dec 01, 2008 | Proview PL926WBi 19" LCD Monitor
Proview 926 wbi monitor
have a look at the board open up the monitor and remove the boards and you have to look for doomed or colored caps, they will be obvious compared to the good flat caps on the board. replacing these will most likely repair your issues.
Oct 28, 2008 | Proview PL926WBi 19" LCD Monitor
Proview monitor fix
I did it just because the higher voltage caps would give a lower heat dissipation thus leading to a longer life this time around.
Oct 17, 2008 | Proview PL926WBi 19" LCD Monitor
Proview PL926Wbi
unsoldering is the only way to UN-mount capacitors the board needs to be out of the casing. a solder iron and some electronic solder wire can be bought at radio shack or any other electronics store.
procedures are all over the internet
Sep 30, 2008 | Proview PL926WBi 19" LCD Monitor
Proview 19# model PL926Wbi
thers Sounds like the problem I'm having /had exactly. When I opened the case I found that like others the 470mf capacitors on the power board had gone bad. (See the post from Delphiuser)
The capacitors are probably from a Chinese company called Xandu and I'm currently looking for a replacement capacitor to fit the circuit. Its a 470 mf cap with a 25 volt rating .
May 01, 2008 | Proview PL926WBi 19" LCD Monitor
Proview 19inch LCD MA982k model 900p
You are on the right track. Sometimes the ribbon cables will look fine but the wire inside the insulation is broken and will result in intermittant problems. Definately check the cable first and repair or replace. It is best to meter the cable while not connected to avoid false readings through other components. Should be a relatively easy repair.
Jan 03, 2008 | Proview PL926WBi 19" LCD Monitor
Proview PL926Wbi LCD Monitor White Screen
I found in the refuse, a Gateway FPD 1520, 15" LCD monitor that started off losing the screen half-way, losing sync, etc. The "mechanical agitation" method was applied and remedied the problem. Awhile ago, it went to a white screen (or, as it was back in the day- a clean raster). I opened it up and found that the ribbon cable on the left was loose. I applied a series of layers of adhesive-backed foam (the kind you stop drafts in your home with) until it was greater than the height of the metal enclosure to put pressure on the unbehaving connector. It does seem a bit loose and this will keep it snug. Maybe hot glue or other adhesive if it wiggles loose again. Seems to have solved the problem at the moment.
Oct 15, 2007 | Proview PL926WBi 19" LCD Monitor
Proview PL926WBi 19" LCD Monitor Logo
166 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Pawan Ambastha
Level 1 Expert
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
