Question about HP Photosmart 435 Digital Camera
Hp 435 digital camera battery
Will a nimh battery that generates 1.2v each with 2450 mah work in this camera? i read that nicd generate 1.5 v and nimh only provide 1.2 v each will this keep my camera from working?. i just bought a nimh energizer smart charger and the camera would not turn on i changed the batteries to alakaline batteries and the camera worked. i'm trying to figure out if the camera does not work because the nimh gives 1.2 v or if the batteries did not charge the first tiem.
    Master:
  • 383 Answers
The NI-MH batteries are the Best for use with Digital cameras....U need to Charge the New Battery for 12 Hours The First time and then 2-3 hours for every other time you charge ... try and check please
Posted on Oct 14, 2008
Which AA battery shall I buy for my digital camera? 1500? 1000? 2500?
Although you could use these, do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in electronic devices.
These batteries are only to be used in flash lights. The lower capacities suggest NiCd batterie. Also don't use these.
A set of new NiMH batteries, from 2000 to 2600 mAh with a good charger, will be fine.
Two things.
There are very fast chargers around. Don't invest in them. I payed 80 euro for a quick charger. Could charge 2700 mAh batteries in 15 minutes. The charger killed all my NiMH batteries I had (more than 40) It took me till the fifth or so died, before I realised it could be the charger. Since I stopped all my batteries one by one died and I had to replace them all
I now have some "fast" chargers that take 2 to 3 hours and the new batteries Can handle that.
Better buy a slower charger and some good batteries, than the other way around.
Second. Test the 2600 mAh batteries, if they fit.
To put more capacity in the "same" AA battery some brands made them slightly thicker. So it could be you can't get the largest ones in your camera.
Mar 21, 2015 | Cameras
I am wondering if anyone could help me please, i have bought some 2600 mAh AAA batteries for my video camera. I was wondering what kind of battery charger i would need to get to recharge these batteries?...
You dont need anything very advanced. 2600 is a nice high capacity for Ni-MH AA's and 1100 is really high capacity for AAA's. Here is a little panasonic charger that would do the job just fine.
Panasonic BQ CC17SBA eneloop Advanced Individual Battery Charger with 4...
Jan 30, 2015 | Cameras
I have a problem with power on Olympus SP-550UZ
Try using regular batteries. I did with my camera and seems I can go a lot longer on the regular batteries verses the re-chargable ones
May 16, 2010 | Olympus SP-550 UZ Digital Camera
Well i tried to take a picture and i took it and then it turned off once i took the picture
Sounds like the batteries.
Digital cameras are noteably, very demanding power suckers.
If they don't have brand new batteries, they shut off.
They requre top brand (Energizer or Duracell) batteries, and once they are used for even a short time; they will not be enough either.
(Dont' throw them out though, other less demanding things like Remote controlls will gladly use them for years)
The best bet is to use Rechargeable batteries, or have a $100/month budget for duracells.
Statistics you will need to look for in Rechargeable batteries are:
Type; Nickel Cadmium (Ni-Cd) or Nickel Metal Hydride (NiMH)
The Metal Hydride rechargeable battery is best since it charges faster and retains it charge longer, the old fashioned Nickel Cadmium battery used to be the best, but not any longer.
Rating: 900mAh; 1800mAh; 2200mAh; others not mentioned.
Unimportant note: The mAh means Milli Amphere Hours, which means how much power the battery cell will hold when fully charged. It is measured in Ampheres (Amps) per Hour, or in this case Milliamperes (1/1000 of an amp), but that's not important to know; all rechargeable batteries are rated by this number.
The number of mAh's you want are about 1000 or more,
Generally it's the more mAh's you have the more you can take pictures. Such as 900mAh will get about 50 to 250 pictures, but 1800mAh will get you twice as much.
Last note on Rechargable batteries: Only use a LiMH charger for LiMH batteries, and use a NiCd Charger for NiCd batteries.
If a charger dosn't say what type of batteiries it charges, it's the old fashioned NiCd (Nickel Cadmium) from the 1900's when that was the only type of rechageable battery.
Good luck with your Digital Camera.
Jul 28, 2009 | Kodak EasyShare CD40 Digital Camera
Camera shows battery exhausted with new batteries.
You should be using Nickel metal Hydride batteries (NiMH). Do not use Nickel Cadmuim(NiCd), Zinc carbon or alkaline.
Mar 12, 2009 | Nikon Coolpix L1 Digital Camera
Choosing batteries
Your camera requires four AA size batteries. There are several factors that contribute to battery life: NiMH: This is the best solution for enjoyment and cost savings. NiMH batteries typically last longer per charge than the average alkaline batteries. NiMH batteries are rechargeable batteries, so they can be used several times and thereby reduce the expense of continually purchasing new batteries. NiMH batteries are typically sold with a power adapter for charging. The life of these batteries can often be determined by the mAh rating, the higher the mAh rating on the battery, the longer that they will last. NiMH batteries do not have the memory effect associated with NiCd batteries, which means that these batteries can be recharged at any time and at your convenience (you do not have to wait for the batteries to completely drain between charges). Lithium: Energizer has introduced a new series of Lithium batteries that provide optimum performance and long life for disposable AA size batteries. Laboratory studies shows that Lithium batteries last more than three times as long as standard Alkaline batteries. This means more hours of fun and satisfaction with your digital camera. These lithium batteries are not rechargeable, they are long lasting. Alkaline: Using the Display, downloading images, playback, zoom and flash all require some battery power to operate and may decrease the number of shots per set of batteries. Performance may vary based on the Alkaline batteries selected. The benefit of being able to use alkaline batteries is that you can find then almost anywhere if needed. Manganese: If you are using manganese batteries, the typical battery life will be about 2 - 5 shots. Then the camera will indicate that battery power is low and may shut-down. To avoid this experience, use either Alkaline or NiMH batteries. Optimum Solution: Use a set of NiMH batteries for longer use and to reduce the expense of continually buying new batteries. It may also be a good idea to keep a spare set of NiMH batteries for other devices that require AA size batteries on a regular basis. Use AA Alkaline batteries when the NiMH batteries need to be recharged and you want to continue enjoying the use of your camera.
Sep 11, 2005 | Toshiba Sora PDR-T10 Digital Camera
Choosing Batteries
Your camera requires four AA size batteries.There are several factors that contribute to battery life: NiMH: This is the best solution for enjoyment and cost savings. NiMH batteries typically last longer per charge than the average alkaline batteries. NiMH batteries are rechargeable batteries, so they can be used several times and thereby reduce the expense of continually purchasing new batteries. NiMH batteries are typically sold with a power adapter for charging. The life of these batteries can often be determined by the mAh rating, the higher the mAh rating on the battery, the longer that they will last. NiMH batteries do not have the memory effect associated with NiCd batteries, which means that these batteries can be recharged at any time and at your convenience (you do not have to wait for the batteries to completely drain between charges). Lithium: Energizer has introduced a new series of Lithium batteries that provide optimum performance and long life for disposable AA size batteries. Laboratory studies shows that Lithium batteries last more than three times as long as standard Alkaline batteries. This means many more hours of fun and satisfaction with your digital camera. These lithium batteries are not rechargeable, they are long lasting. Alkaline: Using the LCD display, downloading images, playback, zoom and flash all require some battery power to operate and may decrease the number of shots per set of batteries. Performance may also vary based on the Alkaline batteries selected. To significantly increase battery life, be sure to turn off the LCD when it is not in use. The LCD consumes the most amount of battery power. The benefit of being able to use alkaline batteries is that you can find then almost anywhere if needed. Manganese: If you are using manganese batteries, the typical battery life will be about 2 - 5 shots. Then the camera will indicate that battery power is low and may shut-down. To avoid this experience, use either Alkaline or NiMH batteries. Optimum Solution: Use a set of NiMH batteries for longer use and to reduce the expense of continually buying new batteries. It may also be a good idea to keep a spare set of NiMH batteries for other devices that require AA size batteries on a regular basis. Use AA Alkaline batteries when the NiMH batteries need to be recharged and you want to continue enjoying the use of your camera.
Sep 11, 2005 | Toshiba PDR-3330 Digital Camera
Choosing Batteries
Sep 11, 2005 | Toshiba PDR-3300 Digital Camera
Choosing Batteries
Sep 11, 2005 | Toshiba PDR-3320 Digital Camera
HP Photosmart 435 Digital Camera Logo
112 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
