Question about Consew 206RB
Bobbin Case will not snap into housing
When I'm sewing and the top thread wraps aroung the bobbin case it catches on the arm of the bobbin case. The arm swings out and the thread keeps wrapping. When I put the bobbin into the machine the arm of the bobbin will not "snap" closed. Thus, it's arm is not tight up against the machine. I purchased a new bobbin case, but it doesn't work either.
  • 6 more comments
  • threadthewor Oct 14, 2008
    Bobbin case is new. Bobbin case works fine when not in machine (with or without bobbin in the case). There is no difference in the fit of the bobbin case when there is a bobbin in the case or bobbin out of the case. The Bobbin case will not lock into the basket on the "post" that's in the basket. Machine has been cleaned very well. Could the basket "post" be the wrong size?
  • threadthewor Oct 15, 2008
    thanks so much for the reply. I've done everything you've said. I did buy the 18045 bobbin. I took the machine to a local sewing repair shop and he told me that I needed a different bobbin. He sold me one and when I got home the machine did the same thing. He seems to think there is a problem now is with the hook. Is that the basket? He said the hook would be about $117 + $50 labor. Does that sound about right? The machine is new to me. Just bought it this past weekend. Thanks for all your help so far.
  • threadthewor Oct 16, 2008
    The machine was a really good deal. Actually, I bought 4 machines in a lot, so if it cost me an additional $150 - $200 then (according to what machines are selling for on ebay), then I still got a good deal.
    I checked - no thread on the spindle - no thread in the basket.
    Before I take the machine to the repairman, should I take the hook out of the machine and see if the bobbin will fit properly into the hook (or basket)?
    I've been sewing for over 33 years and I know how a home machine works and this doesn't look much different. I also have an industrial embroidery machine that seems to operate like this machine. I have to set the timing on it sometimes. So, should I try that? In the event that the bobbin case will or will not fit into the basket, what do you recommend?
    thanks again!!!!
    machine sews beautifully when I sew slow, but I will need it to sew faster in the future and I just want it right. bobbin basket does not turn. I guess I'll just take it to the technician.
    thanks a million for all your help
    I have one final thought to save some money. In the event that someone put the wrong size basket in this machine (which is what I have to have replaced, right?), could I just purchase another bobbin case that would fit in this basket in this machine? Just a thought!!! thanks again, ms
  • threadthewor Oct 17, 2008
    funny you should mention that. When I was at the technician this last time, I paid him $20 to sharpen the hook. When he ran his fingernail over it, it snagged He filed it down. I'm sure this is unrelated to the problem of the thread catching on the tab of the bobbincase. The machine sews beautifully at slow and med speed, but when it sews fast it catches the latch of the bobbin case, because it's not snapped into the machine. This is really my final thought. I don't see how, but, if the timing is off, would the bobbin case hit something and not go in. I've checked and rechecked and the bobbin case will not go all the way into the basket for the latch to snap. thanks again
    Yes, I understand what you are saying and you are correct. It is very difficult, if not impossible, to remove or reinsert the bobbin case if the dots are not lined up. My issue is that when the bobbin case is in the basket, then it will not latch shut. Thus, when the machine is sewing the top thread catches on the "tab" (the part you hold to keep the bobbin in the bobbin case) and causes the tab to stay open and the top thread loops around it and bunches up. thanks for your imput.
  • Anonymous Mar 27, 2014
    when I tuen the fly wheel the bobbin casing does not move
Just bought an older "206RB" (not 206RB-5) and the person who sold it to me said that the 206RB is different when it comes to reinserting the bobbin. I'm sorry I dont know the correct terminology, but left of the handwheel there is a cover over another wheel. In the cover ia a hole approximately 3/16" in diameter and on the wheel is a white dot. The hole and dot must line up to reinsert the boobin so that the latch folds down and locks in position.
Newbee
Posted on Oct 17, 2008
  • 323 Answers
Insert the bobbin case without a bobbin to see if it will go all the way into the locked position. If it does,the bobbin case and basket are okay.
Check inside the bobbin basket(where the bobbin goes) and see if there is thread or lint wrapped around the spindle the bobbin case sits on. If there is, remove it. If there isn't ,then the bobbin is probably sprung and needs to be replaced.
sewman7
Posted on Oct 14, 2008
  • 2 more comments
  • John Free Oct 14, 2008
    18045 should be the number of the bobbin case you bought. If this is correct, then the problem you're having must be in the Basket or at the bottom of the post or spindle. The bobbin case is not going quite far enough onto the spindle to latch in. Get something small with a hook on the end of it and probe around the base of the spindle. I once found a piece of thread that actually looked like the metal it was wrapped around. If nothing else works, then you need to remove the hook from the machine, disassemble it and try the bobbin cases with the basket on the table.Of course, once you do this you have to retime and adjust the clearances.
    Has this machine ever worked properly for you? If yes, then the problem MUST be in the basket. If no, and you just got it, the problem still has to be in the basket as long as it is the correct hook.
    sewman7
  • John Free Oct 15, 2008
    If you just got this machine see if the person who sold it will pay to have it repaired or at least half. Did you ever see the machine work properly? Is there a warranty and was this a REALLY good buy?
    To answer your question about the price. I think if this dealer is willing to guarantee that changing the hook will solve this problem and he can do it for less than $200 it will be a very good deal.
    Check the top of the spindle where the bobbin case latches and see if there is a thread there.
    Sometimes, when the bobbin is wound, the tension on the bobbin winder is too tight and it collapses the center of the bobbin which causes the edges to spring out.If this happens, you will have the problem you are experiencing.
    I'm just having a hard time believing that the hook is bad if this is the only problem you're having.
    sewman7
  • John Free Oct 16, 2008
    Don't remove the hook.The timing will not affect whether or not the bobbin case will go into the machine as long as the bobbin basket is stationary and not turning when the hook is turning.Check that and then take it to the technician.
    sewman7
  • John Free Oct 17, 2008
    You can' have the wrong bobbin basket in the machine if you have the correct hook in it. Best bet at this stage is a technician and a new hook which should come complete with a bobbin basket. If it is the correct one and it is timed correctly it should sew well even at faster speeds. The last thing you have described is a hook with the point slightly blunted or which has been sharped to remove a burr. Once this is done (the sharpening) you will never get a good stitch at faster speeds.Best of luck to you.
    See if the technician will guarantee his work at least for 24 hours so that you can try it out.
    sewman7
Bottom stitch skips stitches
MY FIRST THOUGHT IS THE TIMING IS OFF A LITTLE. BEFORE SPENDING YOUR HARD EARNED MONEY FOR A REPAIRMAN TRY THESE POSSIBLE CURES:
1. TRY TO SEW WITH THE NEEDLE ALL THE WAY TO THE LEFT AND THEN TRY IT ON THE RIGHT. IF ONE OF THE TWO SEWS BETTER THAN THE OTHER YOU CAN BE ASSURED IT IS THE TIMING WHICH MEANS YOU NEED A REPAIRMAN.
2. JUST FOR GOOD HABITS DO THESE BEFORE GOING TO THE REPAIRMAN: CHANGE NEEDLE AND THOROUGHLY CLEAN THE BOBBIN AREA WITH CANNED AIR AND A QTIP TO CLEAN DIRT OUT. AFTERWARDS PLACE A DROP OF SEWING MACHINE OIL ON THE RACE THAT YOUR BOBBIN CASE FALLS IN.
3. PLACE TWO INCHES OF THREAD UNDER THE PRESSER FOOT. TURN THE HAND WHEEL TOWARDS YOURSELF AND WATCH IF THE UPPER THREAD WRAPS ON TOP OF THE BOBBIN CASE WHILE THE NEEDLE IS RISING. THE THREAD SHOULD PULL AROUND THE BOBBIN CASE WITHOUT CATCHING ON THE BRACKETS THAT HOLD THE BOBBIN CASE. IF IT DOES CATCH A LITTLE BIT YOU MAY NEED TO MOVE THE BRACKET AWAY FROM THE BOBBIN CASE ABOUT ONE PAPER WIDTH.
Jan 29, 2015 | Sewing Machines
Keep the thread from collecting on the arm that holds the bobbin case in? My Brother LB-6800 sews quilts, and embroiders great until yesterday, The thread wraps around this small arm every time now.
Try taking the bobbin case out and re-insert. It sounds like the case that holds the bobbin is not inserted correctly. You might also try checking to be sure that the needle is inserted properly. Sometimes the needle gets loose and drops down too low. unscrew, push the needle up as far as it will go, then tighten the screw.
Jan 24, 2015 | Brother LB-6800PRW Project Runway Limited...
When pulling my bobbin thread thru to top my upper thread doesnt go all the way around the bobbin case then it hooks on the little metal arm on top bobbin case on my PE700
The part that holds the bobbin case moves around it after catching the upper thread. Check it and see if it is not working as it should. I wonder if the bobbin is not in far enough.
Nov 09, 2014 | Sewing Machines
The bobbin case catches the needle and the thread wraps around the bobbin case
If you are saying the needle is hitting the bobbin case when it goes down then it could be one of two things:
1. Bobbin case not all the way in. This can be caused by debris in the rotary hook or the bobbin case has been hit by the needle and has cracked/and or bent it. Make sure it is snapping into place correctly.
2. The rotary hook is out of time. Reset the rotary hook point behind the needle and about the middle of the scarf of the needle. Make sure you run the needle all the way down and as it starts back up this is where you set the hook.
Oct 01, 2014 | Consew 255RB-3 Mechanical Sewing Machine
Why does The bobbin holder keeps 'crashing' with a metal 'arm' on the left.
Hum, nothing should
"crash" into anything else while sewing. The Hook (place where bobbin case snaps into) might have a broken "keeper" (internal part that "keeps" the hook stationary when sewing.) Or your bobbin case may not be installed completely or correctly.
Cheers,
Kelly
May 03, 2014 | Janome Memory Craft 9000 Computerized...
I have a brother pe 770 and the bobbin will not catch the thread. The thread will wrapped and tangled up around the bobbin case and bobbin, but will not catch the bobbin at all. I chcked the needle, it is...
You need to sew the first stitch slowly. Lower the needle by hand and take up carefully. Pull the needle thread up and the bobbin thread should be caught in the formed loop and come with it. Pull them both to the back of the machine and sew.
Dec 14, 2010 | Brother PE770 Computerized Sewing Machine
How do you load the bobbin properly?
Well you may please follow the steps below -
1. Remove the bobbin from the sewing machine. Note: whether you have a drop-in, front or side-loading bobbin on your sewing machine. A drop in bobbin will load from the top, may be via a removable bobbin case cover near the machine-fed dogs. A side or front loading bobbin needs to be loaded into a removable bobbin case under the machine.
2. Choose the right size bobbin for the sewing machine.
3. Wind thread onto your bobbin. Your sewing machine should have a standard thread spool to hold the thread and a short, squat post wide enough for a bobbin.
4. Put the thread and empty bobbin into position on your sewing machine. Wrap the thread around the bobbin to start it. On most machines, disengage the needle by turning the smaller hand-wheel on the machine toward you. Push the bobbin post into position, securing the bobbin into place. Press gently down. Thread should begin to wind neatly onto your bobbin.
5. Break the thread, push the bobbin post back into an inactive position and remove the bobbin. Tighten the hand-wheel. Thread your sewing machine again if necessary before loading the bobbin.
6. Remove the bobbin case cover and put the bobbin into position. The thread should slide through a catch on the bobbin case and up through the cover.
7. Access the bobbin case for a front or side mount bobbin. Lift the catch and remove the removable bobbin holder. Put the bobbin into the holder and run the thread through the holder, bringing it to the front. Lift the catch and slide the bobbin holder back into the case. Hold your needle thread gently forward with your left hand and turn the hand-wheel. The needle thread will pass down into the machine and catch a loop of the bobbin thread. Pull this loop up and slide both threads to the back before beginning to sew.
Good Luck!!
Thanks for using FixYa!!
Sep 22, 2010 | Euro-Pro Shark 60 - 384
Bobbin thread won't engage.
The bobbin case is not in the shuttle.
Raise the needle to it's highest position.
Lift the lever on the back of the bobbin case and hold it open as you insert the case into the shuttle; arm on the case pointing up. You may have to turn a bit to the left or right - it will click when in place.
Mar 20, 2010 | Brother CS-8072 Computerized Sewing...
Feed Dogs, Thread Tangle
Hi Jeanette! You have a Singer Featherweight--the best sewing machine ever made! (Mine dates from 1950/51 and I wouldn't trade it for the world.) These beautiful, sturdy machines were designed to be easily repairable at home, but you'll need a copy of the Service Manual (get the Instruction manual too, if you don't have one.) Go to www.singer-featherweight.com and check out what they have available.
I had a similar problem (needle thread not catching the bobbin thread) and the problem was that I hadn't put the needle in correctly (flat side to the left). Also, I will occasionally get thread wrapped around the bobbin housing--sewing along just great and then everything comes to a screeching halt. I'm not sure why that happens, but I'm getting pretty good at taking the bobbin housing apart. The manual is pretty clear on how to do it. You can contact me direct at robbie1949@comcast.net for more information.
Thanks!
Robbie
Oct 27, 2007 | Sewing Machines
Consew 206RB Logo
838 people viewed this question
Top Consew Sewing Machines Experts
Michael Galve
Michael Galve
Shehu Pro
Shehu Pro
Oloyede Monsuru
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
