Question about Kitchen Ranges
Ingnition stays on after oven lights - Kitchen Ranges
  • 943 Answers
HI thanks for your question. the igniter is suppose to stay on , all the way through the cycle. only goes out when desired temp is reached. when more heat is required, the igniter comes on again, and stays on. thanks the appliance doc. if happy with my answer. please rate my answer. thanks
Posted on Oct 14, 2008
My oven wont stay on but grill still ok but they work off same knob
it could be the thermocouple, you can get uiversal thermocoulpe from mmost plumbers merchants , b and q etc.fairly easy to fit ,any probs drdrop me a line
Dec 06, 2012 | Indesit Gas Cooker Spark Ingniter Unit...
Vw ingnition light stays with key off
one of the 2000 VW electrical gremlins. most likely cause is a bad ignition switch.
Sep 23, 2012 | 2000 Volkswagen GTI
Oven won't light
Ignitor, it is very rare that the regulator goes bad
Jun 06, 2012 | GE Kitchen Ranges
The Pilot Light on my Delonghi DEBIE 24 SS Electrical is on even though the oven is off - any idea how to correct this?
The pilot light stays on most none electric lighting for gas appliance, this is normal if you do not have an electric ingnition on your oven.
Hope this is helpful
john
May 17, 2011 | Ovens
Stove wont light but electric ingniter works
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Sep 28, 2010 | Magic Chef Ovens
BOTTOM OVEN GOES OFF AFTER TEN MINUTES THEN TURNS ON WHEN IT COOLS DOWN
you have to be able to check the ignitor in the lower oven sounds like you have a weak ignitor when this happens it is taking to long for the oven to light and when it reaches to a tempreture it shuts off the ignitor in which case when it trys to reach to the tempreture that you have set it trys to ingnite again look to buy a new ignitor
Apr 28, 2010 | Stoves Premier 720GRa Gas Double Oven
Radio light stays on after car shut off
you might find that it has a delay. If not and it is an aftermarket radio you will need to wire it to ingnition "KEY ON" and not direct power.
Apr 22, 2010 | 2002 Pontiac Grand Prix
Oven ingniter lights , smell gas but oven doesnt turn on
Hello- Ignitors may 'light' yet not reach proper resistance and temperature, causing improper gas flow past valve. If resistance is below 4 ohms, ignitor is bad. Part is 40-75$ at local app. parts store. Fairly easy to replace. Hope this helps. -Thanks- ED
Mar 01, 2010 | Kenmore 71513 Gas Kitchen Range
Oven will not light
Hi!!! Even if your ignitor glows just change it it has a weak charge..Also if you change glow ignitor and it does not come on then your gas safety gas valve if shorted good luck..
Jan 04, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Magic chefa313-230lw gas ignitio
hi .thanks for the question . A very common problem with gas ovens replace the igniter thanks the appliance doc
Sep 29, 2008 | Magic Chef 9512 Electric Single Oven
Kitchen Ranges Logo
105 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
