Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
How to put the double brushes back on the shampooer after cleaning them
I took the brushes off the shampooer to clean them and I can not get them back on.
I took the shampooer to a repair shop yesterday.. They had it ready to pick up the same afternoon.
Thank you for sending your reply.
Posted on Oct 15, 2008
General assembly for bissell proheat shampooer
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
6wywe
Jul 23, 2010 | Bissell 8910 ProHeat Clear View Upright...
Need help putting my bissell carpet shampooer back together
the side that is dragging needs the roller that the brushes are on ,to be precisly pushed back up in it's place,it will take a few minutes and it will not slide back in place easily just use a little force as for the hose diagram, bissell.com,enter model number and go to hoses.
May 31, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
My Kirby shampooer - G4 - hardly used any water from the tank and no suds at all. Pet hair did blow out of the small slotted holes in the tray as I moved the shampooer back and forth, but the carpet was...
Few things:
Make sure the sponge and the valve under the sponge (water tank) is clean.
Make sure you follow the instructions (f you do not have the manual you can find one HERE)
See if the straw inside the water tank is not clogged (happens when you use toilet tissue or some other paper to dry inside of the tank after you shampoo)
Noise - if it is noisy al the time - it may need new shampooer brush roll. Also check the tray - bar brush roll bearings overheat and melt the tray... Never submerse brush roll in water when cleaning it. Clean it simply by lifting the shampooer nozzle and letting it spin for 10-20 seconds. If you have tu put it under running water - put it back in the shampooer nozzle (with tray and shield) put on Kirby and turn it on for 20 seconds or so. If it stays soaken wet - moisture damages barings.
Good luck
Feb 28, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Brushes wont turn on shampooer
Dear Momneville
I have the same steamcleaner and had the same problem, I took mine apart a found a clog between the turbine and the wheel that the turbine moves by vacuum when it gets glogged there is no vacuum to move the wheel. If you are not mechanically inclined in suggest you do not take it apart unless you think you can get it back together properly.
Hope this helps
ahill_1
Dec 24, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Are there hand tools you can use with Kirby shampooer?
I love my Kirby and shampooer, but I am wondering if there are any ways to clean stains in small/tight spaces (in corners, between furniture, etc)... my old carpet shampooer had a "hand tool" attachment with spinning brushes, but I don't see anything similar for Kirby... I imagine I could put a tiny bit of solution down and use the zip brush, but I'm wondering if anyone has a better idea...?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
I believe that Kirby does make a spinning brush and If I remember it is a round brush that spins and probably will not get into square corners – suggest using a scrub brush with the Kirby Shampoo for corners and steps for areas that you cannot get into – use an old spray bottle to wet down the area that you are cleaning and use the scrub brush and if you do find the Kirby spinning brush that will do the large areas. Feel free to contact the Kirby factory phone number and website listed below:
http://kirby.com Contact Us By Phone
United States and Canada: 1-800-494-8586
Between the hours of 8 a.m. – 5 p.m. (EST)
Monday - Friday
Apr 16, 2008 | Kirby Ultimate G Bagged Upright Vacuum
User Manual for Electrolux Model 1522 Double Insulated Floor Shampooer
I just bought the Electrolux Floor Pro Encore at a yard sale and need the manual. The URL above isn't working for me. What am I doing wrong.
Mar 23, 2008 | Vacuums
I don't know how to advise you on this. The Bissell is pretty complicated when you take the hood off. Under there is a number of things that must be in place correctly to replace the hood. There is a small plastic "rod" with an "o" ring on it that controls the shampoo mixture and that has to be positioned right to replace the hood. You may have to take the machine to an experienced shop to have it re-assembled. I don't think I can tell you all the little things you have to do to re-assemble it yourself.
In regards to the elevator, there are two arms that lift the brush off the floor when the handle is put in the upright position. This is so the brush will rotate freely while you use the hose. These arms break quite easily and are available from any repair depot in a set.
You may be able to get a schematic diagram from a warranty service dealer. They have a special "dealer only" web site that they can access to get repair and parts info. Usually, they can e-mail or fax you information if you're really nice to them. Smile when you're on the phone. :)
Nov 08, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Kirby sentria shampooer
Too late for your party, but my take on the matter is that you either didn't have the belt lifted all the way up before you put the shampooer head onto the machine, (brushroll was not spinning) or you may not have had the height adjustment lowered all the way to the floor. I have a store on a POPULAR auction site under the same ID as I am using here. If you can't find your manual, I have some in my online store.
Marci
Oct 13, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Vacuum brush roller with belt attached is off
It is meant to come apart for cleaning it up afterwards. Slip the belt over the roller. One triangular end of the roller is bigger than the other, so keep this in mind when sliding it into the cleaning head. Turn the knob to pick up the belt, just like on the vacuum's regular nozzle. Mount the cleaning head, then turn the knob to set the belt onto the motor spindle.
Apr 02, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
65 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
