Question about Kitchen Ranges
Oven flame and gril flame do not increase from starter/low flame setting. grill flame also splutters. seems not enough gas not getting through.
  • joe9t Oct 16, 2008
    f.f.d. (flame failure device) needs to be replaced. apparently common enough in gas cookers....thanks anyway
  • Anonymous Mar 18, 2014
    Flame is orange
  • 943 Answers
HI thanks for your question. the problem with your gas oven, is the igniter is not hot enough to ignite the gas. a common problem with gas ovens. replace the igniters. thanks the appliance doc. please rate my answer, if happy thanks-
Posted on Oct 14, 2008
I have a Kitchenaide model KGSS907SBL01 gas range. Everything works fine except that we find that the amount of heat generated is disappointing. This seems to come from the fact that the top of the grill...
It would seem like reasonable thing to do.However the adjustment is typically for the low setting so you can adjust just the small flame just enough to simmer a pot without the flame going out from being so low its susuptable to going out on the low setting, also it so you can adjust the flame smaller so on low it isnt too high,causing it will boil when you intend to only simmer a dish your cooking. A question;is it all burners and have they always been that way?
Gene
Aug 13, 2011 | KitchenAid KGSS907SSS Gas Kitchen Range
It only gives low flame upon starting and cannot
close your air vent on the burners it will increase the height of the flame
Mar 27, 2010 | Grilling
Low flame
The newer type tank has an anti tip safety device. It gets all boo boo'd when the grill is moved around. Remove the tank. Open the valves on the grill and close them back. Re install the tank and slowly open the valve.
Jun 27, 2009 | Brinkmann ProSeries 810-6330-W Grill
Yellow flame on the rear of my burner
Yellow is a "reducing" flame meaning low oxygen, whereas blue is an oxidizing flame. There is not enough air mixing with the gas. Clean out the pipes and free the air intake holes on the first stage of the burner assembly.
Jun 02, 2009 | Char-Broil CharBroil Master Flame Gas...
Heat is about low or just a little higher on high setting
Low flame, low temperature, yellow flame: This has become the biggest problem with many grills these days and it's almost always because of the regulator (the funny UFO shaped thing on the gas hose). Regulators seem to be stickier these days and when they stick you don't get enough gas to generate a good grilling temperature. To get your regulator unstuck you need to release the pressure on it. Follow these steps exactly:
  1. Turn off the gas at the propane tank
  2. Disconnect the gas line from the tank
  3. Open the grill lid
  4. Turn all control valves to high
  5. Wait for about a minute
  6. Turn all control valves to off
  7. Reconnect the gas line to the tank
  8. SLOWLY turn on the gas at the tank
  9. Light the grill normally
  10. Your grill should now heat normally
To keep the regulator from sticking again make sure that you turn off the control valves first, then turn off the tank valve. Always open your tank valve slowly. If this doesn't work give it a second try. If you still have low flame then you probably have a faulty regulator that will need to be replaced.
May 24, 2009 | Kenmore 774 sq. in. Cooking Area Gas Grill...
Rangemaster 110 gas grill flame
your burners are not burning good because they need to be cleaned and the loud popping noise is the gas burning in the ventury until it burns it self out its a very common thing
Feb 19, 2009 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Oven burner flame is low
0000000.jpgOn top of that safety valve is a nut. Get a good fitting wrench. Turn on the oven and use that good fitting wrench on that nut. Turn it counterclockwise till the flame comes up about midways of the flame spreader. Don't get the flames too high. Midways of the spreader now. LOL
Jan 02, 2009 | Ovens
Rangemaster 110 grill flame.
to find out if the regulator is good or bad, turn any of the burners that do not have the problem, one at a time but take a close look at the flame and see if the flame goes lower and lower as you turn a second burner and a third and the fourth one, if the flame goes lower and lower the regulator is bad. but if the problem is with just the grill one , it has to much air, you can turned down the air where the burner meets the valve that supplies gas to it the burner has a vent, it needs to be close a little bit, you can close it little by little and testing the burner on the on position until the splutter goes away.
Dec 11, 2008 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Propane Problems
The salesman at ACE Hardware told me I needed a grill tip cleaner. Seems the outflow valve from the tank can get crusted and there is a device called a gril tip cleaner that can help restore the gas flow to a higher level.
Jan 02, 2008 | Ducane 455 inch 2 - 3 Burner with...
Kitchen Ranges Logo
321 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
