Question about Canon Office Equipment & Supplies
I have a canon PC 850 copier. Yesterday when I turned it on it gave me the error message 003, then turned off. Can I do anything to fix it, or is the copier dead for good? Chris Edenfield c.edenfield25@comcast.net
  • 1 more comment
  • chrisped Oct 14, 2008
    What do I do?
    I plugged the copier back in, pushed reset, and the error 003 is still there. Now what?
    Thanks. I guess the copier is dead. It has been very faithful for ten years.
    Genius:
  • 1,550 Answers
Something is wrong with the Electronics Module or Wave Amplifier.
More then likely the electronic module has failed. Wave amplifier is pretty unlikely.
If you do not have a maintenance agreement or under warranty, that is a very expensive module to replace.
Source :Fixya.com
Posted on Oct 14, 2008
    Brigadier General:
  • Canon Master
  • 3,614 Answers
Try to unplug the unit for a while and do a reset, this can remove the error message on the unit..
let me know
  • Canon Master
  • 19,396 Answers
Try first unplugging power cord for 20 or 30 minutes, this will drain power from the printer and will reset it.
  • 1 more comment
  • Ginko
    Ginko Oct 14, 2008
    For your knowledge error message 003 on Canon copiers means hard disk error, the technician will reinstall the software on the HD and probably replace the disk itself if this is phisically damaged.
    The disk is not an expensive part it costs $50/$80 the labor cost may vary.
    About " fax engine failure", well, I am afraid that has got nothing to do with this.
    You can ak a quote for the repair fee by calling the phone number listed on the owner manual.
  • Ginko
    Ginko Oct 14, 2008
    The printer does not start because there is a fault.
    The unplug method works only to reset the printer eeproms, in cause there is no fault, and the control panel is stuck with the error message.
    I also did a mistake, error E003 is not an hard disk fault, that is E300 (data error).
    E003 is a heating problem, from service manual:
    "Low Fixing temperature .
    • thermistor ( TH1 or TH2) not
    mounted properly, poor contact, or
    has open circuit.
    • The fixing heater has an open circuit
    or has a crack.
    • fixing heater drive circuit fault.
    • DC controller PCB fault.
    • image processor PCB fault."
    Explained in simple words:
    The technician must check the fuser, the thermistor, and the fuser power board.
    Often you solve the problem just replacing the fuser lamp (heating unit), but it is not necessarily so.
    Sorry that the other expert got upset, but I fix printers for leaving (this for real) and I have never seen "fax engine failure" on any Canon.
    Even searching on Google, or checking the service manualI still cannot find "fax engine failure" , fax failure on Canon is E64something (prob.E645).
    As you have seen, I also did a mistake on my first post, what matters is that this things are not happening too often.
    Thanks for the useful contact number :
    1-800-OK-CANON (1-800-652-2666) I suggest the user to call this number and get a quote for an eventual repair.
  • Ginko
    Ginko Oct 14, 2008
    More, a printer does not have "Electronics Module or Wave Amplifier" as you can see experts post any kind of rubbish to earn their premium. That is not good and should not be done.
    Regardin the copier, that is not dead, probably you just need to change the fuser lamp.
    Here is the part for $130 labour will cost about $80.
    Apologies about all bad info posted on this thread
    Thanks for using Fixya .
    Goodbye
    Master:
  • 538 Answers
Well..it is not encouraging..that is a fax engine failure..usually means replacing the element inside..
  • 2 more comments
  • A Womans Computer Man
    A Womans Computer Man Oct 14, 2008
    ginko,
    remarkable that one would need to characterize information provided in good faith..the fax engine, FYI is resident on the hard drive. To suggest that the hard drive is a failure, without proper diagnostics, is oddly proposed. Of course, what would I KNOW; after only working on hard drives since the late 70's.
    I stand by my contention, that with this particular device, that failure mode could be just as readily related to an issue with the data on the drive, and NOT be an outright hard drive failure..
    and more to this equation..this is a copier not a printer..
    btw, a little FYI on a product advisory for that model..
    Updated: January 18, 2007
    Affected products
    PC6, PC6RE, PC65, PC7, PC7RE, PC8, PC11, PC11RE, PC12, NP1010 and NP1020
    Canon has issued a product advisory for a specific group of PC and
    NP copiers manufactured between 1987 and 1998, which require an
    inspection to address a potentially faulty internal connection. The
    models affected include the PC6, PC6RE, PC65, PC7, PC7RE, PC8, PC11,
    PC11RE, PC12, NP1010, NP1020 and C-100. On September 18, 2006, Canon,
    in cooperation with the U.S. Consumer Product Safety Commission,
    announced a voluntary recall for repair of such models.
    A faulty connection involving the power cord for the fixing unit
    heater may have occurred in some of these copiers at the time of
    manufacture or during servicing. A limited number of these units may
    present a risk of smoke emission or fire. Due to this risk, please
    contact Canon immediately for a free repair.
    Since the initial introduction of these products in 1987,
    approximately 800,000 units have been shipped, and we have had six
    reported incidents involving the NP1020. It is estimated that less than
    70,000 units of these models are still in use.
    This product advisory does not affect our imageRUNNER, Color
    imageRUNNER, Color Laser Copier, imageCLASS, imagePROGRAF and other PC
    and NP models.
    To the customers using the products in question, we extend our
    sincerest apologies for any inconveniences resulting from this issue.
    To ensure that all Canon customers can continue using Canon products
    with confidence, we will make every effort to achieve the highest
    levels of quality possible and request your continued support.
    If you own one of these products, please contact Canon at
    1-800-OK-CANON (1-800-652-2666) for information on how to arrange your
    free repair.
    ten years is a long time..you may wish to review who you applied the fixya vote to, and decide which of the techs provided you the most useful information.
Dear sir i has a copier Canon IR2022 when i copy a file it give message ( system error 007 or system Error 003) how can i resolve the problem. thank you much
Possible torn out fixing film. Or dirty reference white plate on your fixing film. To resolve the problem, try replacing the fixing film unit or call the nearest authorize service center.
Aug 14, 2013 | Canon iR 2022 Printer
Error 003
I am going to take a guess at this one..... You did not give a copier make or mode to give us a hint. A E-003 has to do with the fixing unit of a Canon copier..... It is not warming up to the right temp.... Good Luck
Aug 07, 2012 | Office Equipment & Supplies
Canon ir2018 copier error messages E000 and E003
hi that errors indicate there is temperature failure in the fixing unit maybe caused by AC energy fluctuations . . . verify energy supply is correct . try to connect the machine in another Ac outlet. if problem persist maybe the fixing heater is malfunctioning
Jun 14, 2012 | Canon Office Equipment & Supplies
Eror 003 and 000 a new problem his show ,check document
error 003 and 000 means fixing assy fault, temperature fails to raise.
under service mode ( menu and # ) select clear and err or all.
If these doesnt helps, you need to change the fixing lamp or thermistors.
Hope that helps!
Feb 22, 2011 | Canon imageRUNNER 2000 Copier
System error 000 and 003
The E000 and 003, are the code for temperature fault in fixing unit.
There are two possibilities...
First:
enter service mode *(add.function) 2 8 *, by keys left/right go to CLEAR and OK, select ERR and OK.Turn off and on.
If these helps, you can continue to copy.
Second:
if the error clear not working you need to replace fixing heater.
Hope that helps!
Feb 11, 2011 | Canon iR 2016i Black and White Copier
When i switch the main power button on, i get an error message on the screen with the code: E000003-0000
these is error code related to fixing heater temperature fault. Because you didnt state the model of copier ill gave you the procedure for most copiers of digital serie of Canon, these service mode procedure doesnt apply on iR 2016/2020/2018/2318/1600/2000....
press *
press 2
press 8
press *
select COPIER
select FUNCTION
select CLEAR
select ERR
OK
Turn off and on the copier.
If these doesnt clear your error you need nto change the fixing film assy ( heater ).
Hope that helps!
Aug 16, 2010 | Canon Office Equipment & Supplies
Ir3100 : E00070-003 error code
canon ir 3100 error code E00070-003
Oct 23, 2009 | Canon imageRUNNER C3200 Copier
E 003 error code on power up
The code error is:
E003: After the temperature of the upper fixing roller has reached 180C, it drops to 100C or less for 5 sec or more.
Jan 09, 2009 | Canon NP 6085 Copier
Canon PC-850
A E001 code is a fixing error code. It has to do with the heating lamp or the thermister or the thermal fuse or it could be all 3. Dose the fixing lamp turn ON. If no it is the fixing lamp or thermal fuse. If it turns ON and warms up and then codes out then it is the thermister. It could also be the whole fixing unit is bad.
Mar 26, 2008 | Office Equipment & Supplies
Canon PC-850 E002 Error Code
After some searching, it appears that this error is common on all Canon Copiers. It means that "Fusing unit not heating up" This is most likely due to a bad fusing unit, or a component the fusing unit. Recommend replacing Fusing Unit.
Mar 19, 2008 | Office Equipment & Supplies
87 people viewed this question
old marine
old marine
