Question about IBM TravelStar 6GT (DADA-25400) 5.4 GB Hard Drive
Dropped the drive but the disk looks ok
I have been using the drive as an external drive via USB enclosure, unfortunately I dropped it and since the computer does not see the drive.
I removed the outside cover and visual the drive looks unharm.
Is there a way to copy the files.
    Genius:
  • IBM Master
  • 1,250 Answers
Take it to the technicians, where recovery from hard drive is done
Posted on Oct 14, 2008
I dropped my book essential 1tb 2.0 hard drive and now it wont let me open without formating and say Data error (cycle redudency)
Since your disk is showing up with a drive letter, hopefully, check disk (chkdsk) can help:
http://www.wikihow.com/Fix-a-Cyclic-Redundancy-Check-Error
(this if for Windows XP) Google "checkdisk windows [your version]" if it doesn't translate well.
Falls are a huge cause in external hdd failure, though, so I wouldn't be surprised at all if the disk is beyond help. Try connecting to another computer (to see if the problem still occurrs) or another operating system (you can boot to a linux live cd) or, at least, use another USB drive on the computer you are connecting to.
Next step would be to *cross fingers* hope the external enclosure suffered damage, but that the actual drive did not. If you are comfortable doing it (likely voiding your warranty), disassemble your external enclosure and remove your SATA hdd. You can open your PC and connect it to your motherboard assuming you have an available SATA connection, SATA cable, and available SATA power hookup. Alternately, you can buy a 'kit' to connect a hdd to your pc via usb, which prevents you from having to open your PC. It is much more convenient if you can diagnose without purchasing 1-time use hardware, though.
(Google "sata to usb" -- i buy from NewEgg usually, cheapest with 4 stars)
You can try data recovery software, but they haven't been very helpful to me in the case of physical trauma to drive.
Data recovery outfits (expensive) may help if the information is not otherwise recoverable.
Jul 07, 2014 | Western Digital My Book Essential 1TB...
Tip
The computer does not see MyBook anymore
Try a replacement USB cable first, and test the MyBook on a different computer, to ensure the fault is on the external storage unit.
There are two possibilities:
The Mybook USB/ATA controller board is faulty.
In this case you can simply take apart the enclosure and mount the disk into a new enclosure. WD Mybooks are SATA, but double check the hard disk connector to ensure.
The hard disk inside is faulty.
In this case repair may be expensive. You need to locate a data recovery facility with a 'clean room' , the cost is usually more than $800.
If this happened after a power surge, then the problem is most likely a faulty controller board.
If instead you have dropped the hard disk it is possible an hard drive failure, in that case repair will be expensive.
A replacement enclosure will stfrom art about $20 on Ebay or Amazon, and must not necessarily be WD .
Check if your disk is Sata or PATA (IDE) before buying the enclosure.
on May 04, 2009 | Western Digital 320GB MyBook External USB...
Hard drive clicks, fails to read but powers up. Approx 100GB of music files held and needs recovering. Laptop initially picks up drive on connecting to USB port but then drops out due to read failure.Drive...
Inside that plastic external case of the Hitachi XL 1000 external harddrive, is a regular desktop computer sized harddrive.
It is a SATA type of harddrive.
It is 3.5 inches across in Width. (3 and a half inches)
1 TB in size.
Looks similar to this example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5589521&CatId=2459
On the back end of the Harddrive is where it's power cable, and data cable are attached.
Inside the case of the Hitachi also is a small circuit board. (PCB or Printed Circuit Board)
The SATA harddrive is connected to this small circuit board.
The small circuit board, or Interface PCB , is attached directly to the Harddrive.
Or cables (Wires) are used to connect it to the Harddrive.
The Interface PCB is connected to the computer, via the USB cable that is attached to the Interface PCB.
It is this small circuit board that usually goes bad.
(Unless the external harddrive was on, and dropped. Then the problem is the Harddrive)
There are two solutions;
One, buy an 3.5 SATA external enclosure, and use the Harddrive as an external harddrive again.
Two, install it as a Slave drive in a desktop computer, and retrieve all your information. Burn to disk/s, or flashdrive/s.
When using a SATA harddrive as a Slave drive, there are NO jumper pins to mess with.
DO NOT change any jumpers on the back of a SATA harddrive.
(These are for the factory)
This is an example of a 3.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2145406&CatId=2780
There are no guides to open a Hitachi XL 1000's case, to my knowledge.
It isn't something the manufacturer wants stated.
However opening the external enclosure (Case) isn't that tough. It falls under the same as this model,
http://www.youtube.com/watch?v=hQ_vjyvK28A
Here we see at 3:00 through 5:00, that the Harddrive is attached directly to the Interface PCB.
Just remove the Harddrive from the chassis, and unplug it from the Interface PCB.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 02, 2011 | Hitachi 1TB External USB 2.0 Hard Drive
The hard drive dropped approx. 1 and a half feet, now the computer will not reconize it?
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 14, 2010 | Iomega Prestige 1 TB USB 20 Hard Drive
Hi there I just dropped my Hitachi external hard drive while transferring some files from my laptop to it. It was dropped from the height of a dining table. After I hooked it up to the laptop again, it...
* the USB cable
* the power-adapter
Dec 10, 2010 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
I have 500GB Roco (Toshiba) external hard drive... It was not dropped or physically damaged. My desktop and my laptop don't recognized it anymore. What seems to be the problem and how can i fix...
* the USB cable
* the power-adapter
Nov 10, 2010 | Toshiba 120GB USB 2.0 Portable External...
Vista stops recognizing external hard drive
This doesn't sound like an OS issue. This appears to be more an issue of the connection to the hard drive. The USB cable likely isn't the culprit, nor the laptop USB inputs. If the drive was ever dropped or the cable gets removed and reattached often to the actual enclosure, you might be looking at a bad port on the enclosure. This isnt a lost cause. You can always buy a hard drive enclosure from newegg and move the drive from the IOMEGA to the new enclosure. You can get a new enclosure for $15. Just because the USB port is bad, it doesnt mean the data is gone and the hard drive cant be used.
Aug 26, 2009 | Iomega 33089 250 GB Hard Drive
Connecting my external 320 to my laptop but its just flashes
May 13, 2009 | Western Digital 320GB MyBook External USB...
External USB Hard Disk is 120GB is not dected in winxp pc.
Jan 14, 2009 | Western Digital 320GB MyBook External USB...
Ebook 320 external hard drive
May 03, 2008 | Western Digital 320GB MyBook External USB...
IBM TravelStar 6GT (DADA-25400) 5.4 GB Hard Drive Logo
70 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
