Question about GE GSS20IEP Side by Side Refrigerator
Freezer frozen solid freezer cool fridge not
A couple days ago I noticed the ice maker quit and the fridge was a little warm as the soda pop inside was not as cool as usual. Then eventually the freezer while still cool was allowing things inside to thaw and the fridge was now not even cool. Prompted to find out what was wrong I started digging around. I noticed a couple things... The compressor was running all the time and hot and the freezer had ice formed on the outside of the back panel. Took the back panel out and had ice all over the inner coils. Took a hair dryer and defrosted the coils dried it out and plugged it back in. It started making ice again immediately but the fridge side still doesn't seem cool enough yet. Talked to a friend of mine who thinks he is a Mr Fix It and he said the timer is out but I can't find it to check it. So 3 things.... Can you tell me if you think this is the timer.... How do I check it... and where is the timer at on this model... As I look up I noticed that I am on the wrong description... This is a GE side by side TFX22CR.
  • 2 more comments
  • jtyner5 Oct 28, 2008
    Same Issue
    Freezer Frozen, Fridge Warm
    Have defrosted coils and am looking for the Defrost Timer, Heater and Thermostat. Which are which?
  • Anonymous Mar 29, 2009
    Noticed Ice in the back of the freezer. Ice maker stopped working and fridge and freezer are running warm. Took off the back panel and appears that one of the condenser pipes may have leaked. You can see some blue crust on the foam and bottom panel.
  • Dana Miller Apr 13, 2009
    Ice maker stopped working. Noticed that refrigerator seemed warm, but freezer was ok. Next day items in freezer are melting, fridge seems warmer.
    Ice maker stopped working. Refrigerator seemed warm. Next day items in freezer are melting. Fridge is too warm.
    Kenmore Side-by-side made by GE
Defrost timer is in the refrigerator side behind the panel where the light is located on the upper right corner. You need a straight head screw driver to turn it very slowly until you hear a click that is louder than the other clicks or until the fan stops running. I'm trying to find out how long it should be off myself. Mine went about 30 minutes. If the heaters coils are working you should be able to see them glowing through the grill at the bottom of the freezer.
Posted on Jul 07, 2011
So where is the defroster timer located?
Posted on May 22, 2011
  • Leo Robb Jr May 22, 2011
    I need to know also.......where is the timer?
  • 943 Answers
HI look for this part in the freezer. its the most common one to fail.replace it
Posted on Oct 14, 2008
    look for what part doc? You didn't specify one...........
Water is frozen in fill cup inside the ice maker
Put your frozen food in a cold place.Unplug the fridge, leave the freezer door open for 12 hours. Dont mess with hair dryers
Jan 30, 2013 | GE GSS25LGM Side by Side Refrigerator
Fridge and freezer not cooling
When the refrigerator turns on, do you hear anything in the refrigerant lines? Does the compressor turn on? or does it just hum?
If the compressor is running, it lost refrigerant charge. They were not made to be serviced and lack service valves.
If there is just a loud hum, the compressor may be siezed, the start/run capacitor may have failed. or the magnetic starter failed.
A service call is a fair portion of a replacement not counting the parts.
Apr 30, 2012 | Maytag MSD2732GR Side by Side Refrigerator
Amana BR18 Doesn't get cold
Mine is doing the same thing
Jul 05, 2009 | Amana Freezers
I have a bad smell and taste in water and ice from fridge/freezer
Take out all shelves and accessories that can be removed. Wash these thoroughly with a mild detergent (dish washing liquid and warm water) and rinse thoroughly. Allow them to air dry completely.
* Wipe the inside walls of the refrigerator and freezer down completely with a solution of 1 quart warm water and 2 tablespoons of baking soda. Wipe the walls completely dry.
* Leave the doors standing wide open. Use a fan to circulate air through the cabinets for several hours to completely dry the inside walls. After several hours, turn the fan off.
* Replace the shelves in the refrigerator. Place shallow trays of one of the following deodorizers on the shelves of the refrigerator and freezer:
o Baking soda
o Activated carbon (used in aquarium filters, can be obtained at a pet store)
o Cat litter
o Fresh and unused coffee grounds (this may leave a coffee smell that would dissipate after several days)
* After 24 hours, plug in the refrigerator and allow it to cool for several hours with the deodorizer still in place. Once cooled to normal operating temperature, remove the trays of deodorizer and put your food back into the refrigerator and freezer.
* Keep some cereal size bowls of a deodorizer in the freezer and refrigerator cabinets for several days
Feb 28, 2009 | Kenmore Refrigerators
the ice maker wont cycle untill the temp of the ice is around 10 degrees so if the freezer is at 15 or 20 due to some other malfunction then you will see the maker full of ice but it wont harvest and make another batch. so you could have a sensor bad, control malfunction, refrigeration issue, compressor, defrost system malfunction(you mentioned ice build up)
May 08, 2008 | Samsung RS2534 Side by Side Refrigerator
Relay clicking, not cooling either side
check you paperwork , and manual. sounds like a compressor issue, which "should" be covered by 5 year manufacture warr. reason i say "should" is hte warr's all changed jan1/06. only one year form there . but check your manual itll have the warr info in it
Mar 20, 2008 | Hotpoint HSM25GFRSA
Kitchen Aid Fridge
no ice in freezer section??? not able to keep meat frozen , is it making ice??? sounds like a compressor issuew and not covered by manufacture warr is generally not a worthwhile repair
Mar 02, 2008 | Frigidaire FRT21HS6D Top Freezer...
Maytag MTB2156GEQ Top Freezer not working
The compressor not working, relay switch on compressor not working Had repair man put new switch in .Last year put in new fan motor in freezer compartment the cool air was not circulating both problems made the fridge not to cool and drip water
Nov 30, 2007 | Maytag MTB2156GES Top Freezer Refrigerator
Freezer Drawer Stuck
Our 550 bottom freezer drawer froze shut earlier this week and the motor made an unusual sound, like it was working too hard. Two of us eventually were able to open the drawer to find that it had frozen shut due to a leak which filled the ice tray solid and then adhered to the actual door, freezing it shut. We emptied the fridge and freezer, turned the control dials down to 0, but neither the motor nor the light would go off. We finally killed the circuit breaker to get the appliance to shut down. It's cleaned and defrosted and we noticed that the gasket has torn in three places, two on the fridge door and one on the freezer door. The freezer door could be from our tugging, but the refrigerator door is normal wear and tear. We filled the tears with some kind of putty and when it is dry we will start everything up again. This is not the first problem of this nature we have experienced with our subzero 550, but it is the most dramatic. Each previous time we have called a repair man out and he has been unable to fix it.
Aug 25, 2007 | Sub-Zero 650 / O Bottom Freezer...
GE GSS20IEP Side by Side Refrigerator Logo
784 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
