Question about Nintendo DS Lite Console
DS Lite won't detect ds cards most of the time.
We tried cleaning inside the card slot but to no avail. If we keep turning it off and turning it on again it might detect the card after 20 times or so. If it does detect it then it will freeze during the game.
Sometimes when we power it up the nintendo DS logo doesn't fully appear and it hangs.
Is this beyond repair or is there anything that can be done to fix it?
  • docxpd8 May 11, 2010
    can't say I have a solution for it.. what I've found works most of the time is the old original nintendo 16bit fix... blow on the card a little with warm breath... I think it puts a little moisture on the contacts which makes it work... I have a few that do this to me and that usually makes them work... I don't see anything wrong with my ds, nor the carts, all the contacts look clean, so not sure.. but the exhaling on it a little usually fixes it up...
  • 3 Answers
Make sure your game card are clean. Kids will get all kinds of the stuff in there from lint to food. A blast of can air helps and you can also clean the cards with q-tip and alcohol(just a little bit not real wet)Damp! Then let dry! That help stop the build up of crud on the cards.
Posted on Oct 17, 2008
My daughters ds lite will not load her r4 card any more,it saysthere is no DS card inserted.!!
CAREFULLY use pressurized air on the ds hopefully this will clean out any dust. Blow on the hole. Check another game to see if it works instead of the game you constantly keep trying. Ask her if the ds ever got wet, because once a DS gets wet and you've been turning it on or off it fries the motherboard inside and it's pretty much useless.
Jan 23, 2011 | Nintendo DS Lite Console
When games are inserted into console they will not play
If you are inserting a DS card, be sure there are no foreign articles inside the slot. Blow into the DS card slot to clear any debris. Also be sure you are inserting the card all the way in until it clicks. I've also found that if you're powering on a game, and you bump, grasp or touch the ds card as the DS is powering on, that can cause it to not read games.
Check the actual DS card itself and carefully look at the exposed contacts on the circuit board. Be sure none of them are scratched, damaged or otherwise. A scratch can damage a contact, thus preventing proper data read.
If anything was spilled onto the DS card, be sure it is thoroughly cleaned with a damp cloth (no cleeaning chemicals!) If you immerse the DS card, or pour liquids on it, that may damage it as well.
Same points hold true for inserting a Gameboy Advance game (if you have a DS or a DS Lite. The DSi and DSiXL do not have Gameboy Advance slots.
If you turn on the DS and nothing happens, try a different DS Card. If it only happens with that one particular game (or games) your DS cards are damaged or need cleaning. If all your games are not playing, there is a problem with your DS. Try your games in a friend's DS just to make sure. You'll probably have to send the unit to Nintendo for repair, or take it to an authorized repair center.
Dec 05, 2010 | Nintendo DS Console
DS Lite Console: my nintendo ds lite won't read game cards...
try compressed air.
more then likely its a hardware issue. try getting an R4DS card and download games from www.filestube.com if you dont want to repair it.
you can have 50+ games on an sd card and not have to lug around all those games anymore
May 06, 2010 | Nintendo DS Lite Console
I've recently downloaded some free games for Nintendo DS Lite into a micro SD card - around 8 games in total. However, when I inserted the micro-SD card (through the adopter) into the DS game slot on top...
put the software on the sd card the ds kernal software then goto the removeble drive, open it and create a new folder, call it Games, put all of the games into this folder so it creates a new directory in the menu. Make sure you u use winrar or winzip to extract the files to the folder.
Jan 16, 2010 | Nintendo DS Lite Console
DS Lite games are not recognized in the card slot
have a look inside at the contacts as they are prone to snapping. as to why 2 have gone so close together i can answer.
Jun 19, 2009 | Nintendo DS Lite
DS Lite game card won't "click" into slot
Slightly push once. If too fast come out.
If still, back to nintendo
Apr 16, 2009 | Nintendo DS Lite Console
Nintendo DS Lite
Try getting the latest version of the firmware for ur ds. After u download the firmware, put ur card into card reader. Use computer to delete everything except ur games. Then put the firmware that you downloaded into the card. See if it works.
Aug 30, 2008 | Nintendo DS Lite Console
A freezing nintendo lite!
The DS Card Slot may be loose. If so, try not to touch the game card while playing.
Or, there may be a piece of dust or lint in the card slot. If you can see the lint, pick it out with clean tweezers. If you cannot see it, ask a mechanic to open the Ds and pick the dust out.
Jun 10, 2008 | Nintendo DS Lite Console
DS Lite unable to read DS game card
try to use rubbing alcohol on a qtip and clean the game connectors and inside the game slot. Or try to blow on it. that usually does the trick
Aug 19, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
255 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
