Question about iLO (2 GB) MP3 Player
How to unlock imation lock software in a not imation flash drive?
Pls help me to used again my kingston flash drive, i accidentally used imation lock software in it
  • 7 more comments
  • vhanjo Oct 14, 2008
    pls help me i cant use my 4giga flash drive now
  • RizGhauri Nov 08, 2008
    i've 2gb kingston usb flash drive and i mistakenly locked it with imation lock software; would anybody help me to unlock it as i've very important data on my flash drive!!!
  • Partyzone
    Partyzone Nov 10, 2008
    i have the same problem please help
  • nsnadn32 Nov 27, 2008
    i have the same problem too,, can anyone help us?
  • luiswega Jan 26, 2009
    i tried yor solution and it don`t work it says that i hawe to format usb rdive before usingit
  • Anime Addict Feb 08, 2009
    Same problem to me.... I accidentally lock my 512MB Kingston Data traveler
    It sucks.......
  • fastdeepak Mar 08, 2009
    same pblem ...also my software is lost..then how to unlock the saved data
  • nuwanc Mar 31, 2009
    Pls help me i also kind a same, my secure area won't access, i lock it with the software in it, and now can't access. i got the software from on of my friends. but it can only access the public partition only. even i can't format the drive (both public & secure)
    pls help me to recover my software i don't need my data. i had backup.
    nuwanc.lk@gmail.com
  • dave Apr 26, 2013
    i have de same problem mannnnnn
Http://www.fixya.com/support/t845221-run_imation_lock_kingston_4_gb_now_its
Posted on Dec 06, 2008
What is the password for the new kingston USB DT109?
It is true that locking mobile storage devices, such as USB drives, with Imation Lock is an excellent way to protect your data.
However, using Imation Lock with a Kingston USB drive can create problems.
Learn how to unlock your Kingston USB drive so you can use it once again.
Ensure that your Kingston USB drive has been removed from your computer's USB port.
Start the Imation Lock software by double clicking the Imation Lock.
Plug in the Kingston USB into a USB port immediately after the "Please Insert the Device or Run This Utility as Privileged User" message appears.
Access your Kingston USB drive by clicking Start > Computer.
Double click on the device.
Start the Imation Lock software again by double clicking the Imation Lock.
Disable the password protection by clicking the open lock icon.
or
If you have password protected a USB drive or partition on your computer and have since forgotten the password, you will need to completely erase the drive.
Erasing and reformatting the drive will remove any password protection, software and data on the drive preventing you from accessing the drive.
The process is simple using Window's Disk Management utility.
Log into the computer as the administrator.
Open the Windows Start menu, select "Run," type "Compmgmt.msc" and click "OK." In Windows Vista and Windows 7, simply type the command into the "Search" field.
Select "Disk Management."
Locate the password-protected drive.
Right-click it and select "Delete." Confirm the action.
The drive will be erased and become unallocated free space.
Hope this helps.
Nov 28, 2012 | Kingston Ultra Thin DataTraveler DT 109...
Also have imation lock flash drive...i cant unlock or change my password...i dont know why, it says Drive is busy try again later...and it has not been working for days! what is the problem??? please help...
when its try later
scroll to bottom of screenright click in the bottom taskbar select task manager applications also processes see whats running if you see something running that should not be select end now
also download this freeware password utility
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html
Hope this helps you
Feb 02, 2011 | Imation Products - imation - Clip Flash...
How to remove write protect on my kingston usb
Some of these have a software companion for setting the protection status. Google "unlock" for your particular model USB stick and possible locking software such as Imation and others that you might have used, even by accident.
Apr 17, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I forgot my password in Imation lock.
(assuming you're using Microsoft xp): drop into the DOS shell and force a format of the flash drive. This'll clear everything off it, including any locking mechanisms.
Jul 25, 2009 | iLO (2 GB) MP3 Player
I have lock my Kingston from imation lock.
you can try formatting it from the disk manager.
plug in the flash drive and remember what drive letter it gets assigned. right-click 'my computer' and choose manage from the drop-down menu. in the following window, click on disk management (under storage) on the left, then right-click on the flash drive and choose format...
Jun 22, 2009 | Kingston Technologies 512MB DataTraveler I...
How do you unlock a 1gb sandisk mommory card for mobile
The side of your SanDisk SD Card has switch to lock or unlock the card. This prevents accidental data deletion. If the lock is broken, no other means but to replace the card or buy a new one.
Jun 06, 2009 | Kingston 1GB Secure Digital Memory Card
I had problem with imation lock
how format flash imation 8 gb write protected
Mar 25, 2009 | Electronics - Others
I had run imation lock on kingston 4 gb and now its says "Please insert the device or run this"
its a little tricky, just try it
  1. unplug ur usb drive
  2. double click the imation lock
  3. when the message appear "Please insert the device or run this utility as privileged user" plug the flash/usb drive quickly
  4. USB will start working
  5. run the imation lock again and disable the password protection
  6. delete the ugly imation lock from ur system
i hope u find it use full, plz give ur feed back at: masood@inbox.com
Jul 28, 2008 | Computers & Internet
Kingston pen drive locked by LOCKv116.exe
i have same problem with kingston 2GB, i format my pc, also with pen drive attached , now it saying please insert message but pc will detect it
Feb 07, 2008 | Computers & Internet
iLO (2 GB) MP3 Player Logo
9,752 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Michael Vincent Cruz
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
