I have a triax tx10 satellite receiver and am having problems with the time on the unit. The time is not being maintained correctly. It is not updating at all.
My garmin nuvi 660 stopped receiving satellite signal. Reset has no effect. Everything else seem to work.
Power your unit on outside, make sure you have a clear view of the sky. If your unit is working properly, then it should pick up the satellites. If so, then you can put the unit back in your vehicle and make sure it is positioned to maintain a satellite lock. If you cannot acquire satellites outside, then the unit is defective.
Jan 01, 2017 | Garmin GPS
Total remote code triax satellite receiver
To get more codes and other details, check these links. http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 28, 2013 | RCA Televison & Video
JVC Kw-nt3hdt - Clock resets each time car is shut off.
Hi... I have a JVC nt3hdt.. and I was having the same issue... all the wires was connected properly... but because I didn't have the GPS antenna hooked up it couldn't reach any sattelite to maintain de clock... once I received my GPS antenna, I plugged it in, the clock maintained itself pretty good!
Hope it helps,
Oct 19, 2012 | JVC Kw-nt3hdt Cd/dvd/hd Radio/navigation...
I lose satellite connection every time I turn on my GPS unit. After few minutes connection will be restore by itself. Why this happing and what can I do to fix it. Frank
If you shut the unit down - and remove it from the power cord in your car, this is expected.
When powered down, the unit is not capable of maintaining contact with the satellites in the sky. When you power it up, it needs to receive signals from 3 or more satellites get a "fix" or calculate your position in the world. The more signals received, the the more accurately displayed your position will be. The device must use the signal data, perform calculations and bring up a map of your area.
The "Lost Satellite Reception" message also occurs whenever the GPS does not have a clear view of the sky over the earth's equator. This can be from a garage roof to heavy foliage (tree cover) - and even when driving between tall buildings. Usually, it shouldn't take more than a minute or so (once the obstructions have been cleared) for the GPS to reacquire the signals, calculate and display your new position.
I hope this helps!
Oct 27, 2010 | Garmin nuvi 255W GPS Receiver
Cannot maintain preset settings.
Do you have a fresh battery in the unit? Make sure your 'reset' button inside the battery case isn't 'stuck' on (push a little pencil in there).
Fresh battery, then do a reset inside the case, do a reset to factory settings, then try normal on and off with the switch and see if that fixes it or not.
Jul 25, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
My Delphi Roady XT receiver will not maintain the signal. Does not work even I replaced the antenna. Works for a about 5 minutes before losing the signal
I had the same problem with my xt two years ago. I had two other roadys' at the time and they both worked with that antenna so I called xm customer service explained what was happening and they sent me a new receiver for $10. They told me that those units aren't worth trying to repair. Maybe you'll have the same luck I did. Give em a shout. Good luck.
Aug 19, 2009 | Delphi Roady XT XM Radio Receiver
GPS takes a long time to receive satellite signal.
You probably are just in a bad location where satellites are not reachable. All these units work from the same satellites and recieve them the same so it wouldn't matter what brand you have. I highly doubt that the powerlines and cell towers are effecting the transmission.
May 19, 2009 | Navigon 2200T GPS Receiver
My Garmin Nuvi670 (brand New never used yet) will not receive satellite signal, the s/w versions I have tried are 4.1 and 4.2 - both times the GPS SW Version is shown as 0.00m is this correct ?
This is not correct. This indicates that there is a problem with the satellite receiver. There should always be a number assigned to the GPS S/W version. If it returns a value of 0.0 this is a problem. If your unit is new, take it back to the store or call Garmin.
- Jim
Nov 01, 2008 | Garmin GPS
Hitachi PJ-TX10 alligment
i have one of these projectors found on setting it up that the projector must be square on with the screen, the pjtx10 doesn't have ant "wedge type" setting like sony does. if this doesn't fix problem there is some thing not aligned in the lense
Mar 04, 2008 | Hitachi PJ-TX10 Multimedia Projector
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
Electro Med Services...
