Question about Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher my bosch dishwasher is not fillng up with water, if I put water in it, it will start to run, but not thru the whole cycle. It will drain If I cancel the cycle. Thanks, Tampaupsman@yahoo.com
  • tampaupsman Oct 14, 2008
    I tried it,twice, it didn't work, Thanks , tampaupsman@yahoo.com
    President:
  • 1,462 Answers
I know this sounds daft but --
turn off water. disconnect fill hose from water supply. wait 5 seconds and reconnect fill hose then try it out
Posted on Oct 14, 2008
Motor keeps running. Water heats fine. Help
One of the reasons for motor not draining during normal cycle is the check valve is stuck. It is meant to return to normal during drain cycle but close during wash. I think the cancel is resetting it and letting water out.
See this discussion.
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/26-129-977852-/Bosch-Dishwasher-won-t-drain-SHE43RF2UC64
Apr 02, 2014 | Bosch 24-in Built-In Dishwasher Color:...
Our dishwasher won't drain completely. I ran it through a regular cycle but it was left with water in the bottom.
Have you tried canceling the cycle? To cancel, turn the on/off switch to on, then press and hold for three seconds the two buttons labeled "Cancel Drain". Keep the door closed for the next minute so that the dishwasher can complete the cycle. During this time the pump will remove any water from the washer. Also you will notice that Bosch dishwashers always leave a little water in the system to keep the seals from drying out and going bad.
Hope this helps
Jan 20, 2013 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Bosch dishwasher shx55m with bottom tub full of water
The dishwasher really shouldn't pass any particles near large enough to clog the drain hose. It sounds more like a mechanical issue. Check the circuit breaker to make sure it's not tripped. See if you can hit a cancel button or something to make it drain. Try to run another cycle. If the computer is stuck or acting funny, trying cutting the power for a while, holding down a stop/reset/cancel button, or running a cycle that you don't usually run. I had this kitchenaid that would randomly refuse the normal wash cycle, but would run fine when you ran rinse only or something, then regular wash and everything would be fine again too. If the line somehow is clogged, there's a good chance it's right where the hose connects to the disposal or drain pipe.
Feb 18, 2010 | Bosch Integra® 500 SHX55M05UC Built-in...
Bosch SHE43M was running when a pipe broke under the sink and flooded the kitchen. Water turned off before dishwasher. Now dishwasher makes a motor sound but no water starts and no cycles. Nothing...
water is in the base and the float switch is activated. you must remove the water to deactivate.then hit the drain and cancell. let me tell you a quick joke .Im a old bosch tech and i had a call with the same problem. as soon as i got there i notice mouse droppings.the customer had a tech come by and told her she needed a circulation pump amodule the whole thing.wrong!!! what had happen was a mouse had made a mouse bed with the white packing foam and pulled it under the float in the unit. so the unit thought it had water in base and it went into drain mode . I removed foam and problem solved.
Nov 07, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
The water does not circulate throughout the washer. Is the pump bad? The full cycle will run without cleaning.
Before we jump to conclusions, you can try to clear element that discharges the water. The wholes in these units can become clog do to the detergent as well as food. Most Bosch units allow you to unscrew these pretty easily. Blow through them, or use a plastic tooth pick to clear any obstructions or both. Before you reattach, turn on dishwasher and listen to hear how much water is shooting out at the discharge points. Most Bosch have two discharge points one for the top and of course one for the bottom. Reattach units and Run dishwasher.
Should this fail it could very well be the circulating pump.
Oct 13, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher model shx33a can't figure out how to just drain without running the whole cycle...HELP
usually on the consol in small print it will say press these 2 keys to drain. Read all the lettering on the consol and let me know
May 28, 2009 | Bosch 24 in. SHU66C05 Stainless Steel...
Bosch dishwasher has water in bottom after cycle is complete
Hi
Kindly check for the following :
Check for hose kinks or food plugging drain hose. Start at the drain port exit.
Check the check valve and drain hose for debris.
Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
If you have recently installed a new garbage disposal, check knock-out plug at connection.
Check pump impeller for damage.
Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Please contact for any further clarifications.
A Fixya Rating would be appreciated if.
Thanks
Rylee
Feb 13, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch Dishwasher Not Draining
Im really not all that familiar with the bosch unit, but a few things i would ck. when you cancel a cycle (it should drain the water) is it humming??? does it sound as if it even trickling into the sink discharge?? do you have a disposer under your sink that this unit drains into, if so remove the clamp and look for possible obstructions right there.Honestly passed this ill have to defer to someone else sorry and good luck
Mar 10, 2008 | Bosch SHU9915UC Dishwasher
Bosch dishwasher SHU66C02UC
You have water in the base of the machine. There is a flood float in the bottom so if any water gets into the base, it will shut off the water and run the drain pump as long as the power button is on. So shut off the breaker, remove the toe kick, and remove any water that is down there. Now start the machine and see if water is leaking into the base. If there isn't any water, an the dw is still running the drain pump, then with a wooden spoon raise the red plastice stick on the left side of the dishwasher up and down. It is possible that the overfil float is stuck. If this makes the dw start filling, then run cooking oil thru the dishwasher on the scrub cycle to remove excessive detergent. If you are in hard water, then the water deposits have caused this. Run citric acid ( Tang orange drink, Dishwasher Magic, or such) thru the dishwasher to remove this.
Jan 21, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Dishwasher wont drain
have you removed the filter? if it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump
Nov 17, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch 24 in. SHU43 Built-in Dishwasher Logo
607 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
