Question about Bose 3 2 1 GSX System
Hook up I just bought a new 46 inch Spectre TV. I have an earlier Bose GS system with no HDMI port. My new tv has no yellow video input. Will I be able to use this system. The cable man tried as much as he knew and failed. Thank You
The Bose GS can only support component video set-up for the best video definition. This video connection set-up uses three RCA cables to transfer the video signal from an output device (the Bose GS) to an input device (Your TV).
Check if the back of your GS system has a set of video out RCA ports that are titled "Comp Out". You TV should then have a "Comp In" video input RCA ports you can connect to.
Hope this helps.
Posted on Oct 21, 2008
I have sound from satelite box through bose 321 but no picture on tv
First, you need to run the coax cable from your satellite dish to the "cable in" input on the back of your satellite receiver, not the Bose. If your satellite receiver has an HDMI OUT, and if the Bose has an HDMI IN,run hdmi OUT from the rec. to the Bose IN, then keep your HDMI connection from the Bose OUT to the TV IN as is. Make sure you've selected the correct input on the TV menu. As it is right now, you're not delivering any video signal at all to the TV!! -only audio(red and white). There are a couple other ways, but they won't give you the same quality. I assume this is HD, right? If you CAN do it this way (i.e. if you have enough HDMI ins and outs), it's the best possible hookup and you won't need the composite (red, white and yellow) at all. By the way, it's the yellow connector that carries the video signal; the red and white are audio left and right. If you can't hook it up all HDMI, disconnect the "separate cable" (I'm not sure what that is or what kind of cable or what it's for)and plug in the yellow connector into video IN on the Bose.
Feb 08, 2015 | Bose Av321 Series Ii Media Center For 321...
Boise
What model of TV are you hooking the Bose system pls? Alternately, determine if the TV you are hooking it into has a pair of white and red RCA connector marked Audio OUT.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 14, 2008 | Bose 3 2 1 GSX System
Black and white
The Lifestyle 38 has no HDMI output. It all depends on what inputs your TV has, which cable set up would be the best for you. Assuming that your TV has an SVideo input, you indeed can use the SVideo output of the Bose system, to get the DVD picture on your TV. However you will need to connect the audio output of the TV to the TV input of the LS 38 to get the TV sound to play over your LS 38. In case you don't have an SVideo connection on your TV, you can use the composite output of the Bose system and connect it to the video input of your TV (yellow in and outputs)
Dec 10, 2013 | Bose Lifestyle 38 DVD Home Entertainment...
I just bought a toshiba 50M2U 50' series TV. I also bought a audio/video switch to connect my bose 3,21, surround sound sytem which still uses the red, blue, green cables and I have a wii system w
i think your problem is with cabling your surround sound is audio only and you wii is video and audio. i would hook up wii first and get it working first. dont plug the surround into the yellow jack on your audio video switch
good luck
Sep 09, 2012 | Toshiba 50L2200U 50" 1080p LED-LCD TV -...
I have a Bose home theater system and a Sharp Aquos tv. I'm trying to hook up the Bose dvd directly to the tv. Problem - tv only has HDMI input capability and Bose does not. I purchased a HDMI convert
Hello
You haven't given any description about the converter you bought. Please send me the model number and brand name of the converter did you bought. OK.
Nov 18, 2011 | Sharp AQUOS 52" Flat-Panel LCD HDTV
I am trying to hook by Bose 123 to my Panasonic Vestra 3d tv. I have the cable connected but I am not getting anything
To view a DVD in the Bose system on the TV, connect an HDMI cable (or composite-Yellow, Red, White) to the back of the Bose system (output) and the other end to the input on the back of the TV.
If you have a cable box or satellite and want to get the audio on the Bose system, connect an RCA (white and red) cable to the back of the Bose system (input) and the output on the back of the cable box/TV/satellite.
Switch channels on Bose as needed. Good luck!
Jun 09, 2011 | Bose 3 2 1 GSX System
Have a Bose 3-2-1 Series III. When I put in a DVD, I get sound through the Bose but no picture on my Pioneer TV. This is the second time it has happened. The first time it, we managed to get it going...
Here are 3 things to try and an if all else fails at the end.
1) Make sure the TV is set to the correct Video Input to see the video from DVDs on the Bose system.
• Make sure a DVD is in the disc tray.
• If the TV is connected to the media center using the HDMI cable:
Switch from one Video Input to another and then back to the original input.
2) Turn everything off, then:
Turn on the TV and set the TV Video Input for the Bose system video.
Turn on the Bose system and press DVD.
3) Turn off both the TV and the Bose system and then:
Unplug the HDMI cable from both ends.
Disconnect the power cables from both your TV and the Bose 321 system.
Re-connect power to the TV and to the Bose 321 system.
When the Bose 321 system startup message disappears from the display,
re-connect the HDMI cable to the TV then Bose 321 system.
Turn on the TV first, then turn on the Bose 321 system.
If all the above fail then disconnect the HDMI cable that connects the TV to the Bose 321 system and reconnect the two using a Component cable, an S-Video cable, or the Composite cable provided with the system.
Please leave feedback
Cheers
Andy
Apr 28, 2011 | Bose 3·2·1 II System
How do I plug in a game system?
If you have HDMI port on the game system and a free HDMI port on the TV plug it into that and use your TV remote and select source/input HDMI 1 or 2. normally your TV is using HDMI 1. Second optin if you are not using HDMI cable the you need to use audio/video cables red,white and yellow cables hook them up colors matching on game consloe and TV. Try that !!! TV make and models varies. Good Luck
Feb 04, 2011 | Televison & Video
Apple TV and Bose Home Theater
You should be able to connect hdmi from apple tv to bose v30 for picture and sound. You can also run component video to bose and a hdmi out of bose to tv. Just make sure your running hdmi out of bose system to tv if your tv supports hdmi if not use component video cable. Another way which isn't as good of quality is to run fiber optic from apple tv to bose v30 and hdmi straight to tv.
Nov 02, 2008 | Bose Lifestyle 30 System
Bose 3 2 1 GSX System Logo
167 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
