Question about Garmin GPS
My new 495 gps backlight does not come on. I can see that the unit seems to be working but without the lighted display
I called Garmin tech service ---they walked me thru the solution --it was simply because the backlighting had invertedly been set to zero . Problem solved.
thanks for your concern
John W.
Posted on Oct 17, 2008
How do I fix the backlight of my garmin 3205
The LCD display contains both the display and backlight. They are integrated as one piece. Therefore the entire display needs to be replaced. The backlight connections are soldered to the LCD connections. Replace the entire display.
Dec 25, 2014 | Garmin nuvi GPS
The backlighting function on my Garmin 176c GPS doesn't work. The unit seems fine otherwise. Can this be repaired?
yes but it would be cheaper to buy a new one...the cost of repairs is really up there these days for a new one my friend
Aug 27, 2008 | Garmin GPS
LMS 337c DF. The LCD backlight seems to jump from bright to off and back continually after the unit has been on for 10-15 mins. holding finger on the power/light button stabilizes the problem until the...
the lcd is going out and will cost more to fix it then the cost of the advice is to get a new one from bestbuy and get the 4 yr performance service replacement plan so next time you have a problem like this they will replace it for free.
Mar 06, 2008 | Lowrance LMS-337CDF GPS Receiver
The display is dim and hard to see.
First, make sure that your brightness is turned up. You can access this from the menu by selecting "Display" then adjusting the display between 50% & 100%.
If the brightness is at 100% and the display is still dim, this is an indication that there is a problem with the backlight that lights up the LCD display from behind.
The backlight is integrated into the LCD display, so the entire display needs to be replaced. Was the unit dropped? If so, perhaps the LCD flex cable pulled out of the connector, slightly from one side, disconnecting the backlight. We strongly suggest that you don't try to repair the unit yourself. Additional damage can occur.
More information on LCD repair can be found here:
SHARCNET USA Out of Warranty GPS Digital Camera Repair
Mar 14, 2014 | Garmin nuvi 1300 Car GPS Receiver
The display does not light up sound does work
I personaly had a sherwood system once and had to replace the backlight. Seems to be a similar problem...
cheap repair, if you like your system it worth the repair.
Nov 28, 2013 | Sherwood Audio Players & Recorders
My unit back light is not working. the chart is displayed but can only be seen if you hold it to your face.
Backlights are part of the LCD display and consist of LED's. You may have to replace the entire LCD display or find another display that is cracked but has a working backlight. In most cases, you can swap backlights. There may be some soldering involved.
May 28, 2013 | Garmin GPSMAP 235 Sounder GPS Receiver
Backlight issue with the Vista HCx
I called Garmin. This is "As Designed", so we are stuck with this. Annoying, but all you have to do after turning the unit on is:
1) Press Lower Right button twice
2) Press Upper Right button once
Unit will now behave as you directed until you turn it off
Dec 14, 2008 | Garmin eTrex Vista HCx Handheld GPS...
Fine drive will not turn on
if the blue lights come on, then its probably the backlight that has failed. probably a better deal to get a new unit but you can also go to C&C wireless who still fix these...
Nov 26, 2008 | Fine Digital FineDrive 400 GPS Receiver
The backlight quit working
I have the same problem. I was wondering how you go this resolved. I am able to bring back the backlight by pressing the base of the unit where the buttons are, below the screen. It seems to fix it until you shut it down again.
Jun 08, 2007 | Garmin iQue 3600 GPS Receiver
GPS Logo
241 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
