Question about HP Office Equipment & Supplies
I have a hp deskjet 5150 which printed fine until yesterday (Oct. 13). Now I get a “black print cartridge isn't compatible with this printer” message, which, of course, is not true. I also have a blinking light on the left side of the printer between the X and the down arrow. I'm thinking perhaps the printer is out of toner. Please advise. Thank you. Robert Ludwick/Exton, PA
  • cozuti Dec 24, 2008
    Exactly same problem. Black ink cartridge printing fine then message says not compatible with printer for no reason.
    Replaced cartridge but new one gives same message
  • 18 Answers
My first thought would be to remove the black ink cart. and clean the connectors with a Q-tip and alcohol (water will work in a pinch). Sometimes ink will spatter up into this area and cause problems. It is possible that the cart. has a malfunction also - but not likely.
Posted on Oct 14, 2008
HP Deskjet 5150 poor print quality
For poor printing problems I suggest you run the Tap 10 diagnostic print test (see link to video below).
If the new (or refilled/reman/compatible) HP 56, 57 or 58 ink cartridge refuses to print black/color and/or function at all (i.e. blinking ink light on Deskjet 5000 series printer) or fails to complete the printer alignment following cartridge installation, then the ink cartridge either has a connectivity issue with the flexible printed circuit cable (inside unit where cartridge mates with cable), the rear cartridge contacts or cable contacts are dirty with ink residue, or the cartridge is suffering from marginal internal electrical performance. It is suggested you perform the TAP 43 (and TAP 10) DIAGNOSTIC PRINTER TEST to evaluate the ink cartridges electrical performance. Visit Inkjet411 support site to see instructional video: http://inkjet411.com/?page_id=2358
NOTE: For the HP Deskjet 5000 series printer models, when you get an HP 56, 57 or 58 integrated ink cartridge refilled (i.e. currently offered at Costco or Frys today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels are not initially reset. However, continuing to use an ink cartridge which displays LOW INK alerts is permitted by the printer, simply select OK, CONTINUE or DISMISS when these alerts are observed. Now, it is possible to reset the ink levels by performing the procedure outlined on Inkjet411's site: http://inkjet411.com/?page_id=1915
To clean the HP 56, 57 or 58 ink cartridges please visit the Inkjet411 site which provides recommendations on how to clean the electrical contacts, flex driver cables and how to perform a hot water flush of the nozzle plate (refer to video): http://inkjet411.com/?page_id=1519
Jan 17, 2013 | HP DeskJet 5150 InkJet Printer
BLACK CARTRIDGE PRINTS IN SPASMS BUT COLOUR CARTRIDGE PRINTS FINE.
I didn't get your question,even I am trying to give you solution. Switch on the printer, left top cover wait until carriage arrive at middle, remove mono cartridge, take out swab nozzle area with good cotton or ear buds adding with alcohol(solvent) gently in one direction,repeat three to four times & shake well and see ink coming out from nozzle area?, clean nozzle area with tissue paper put it back & check for print..
Feb 04, 2012 | HP DeskJet 5150 InkJet Printer
HP 5150 Deskjet -- black printing abruptly stopped. Prints appear with color but no black. Switching black cartridges doesn't help. Clean print heads operation doesn't help. Switching computers...
There are very few things you can do, other than what you have aleady done.
I would recommend a decision on how much the unit cost and how long you have used the
printer vrs. what HP or a local authorized service center would charge to repair it.
If you have refilled ink cartridges, this is problem that can arise due to ink drying on the
print head as the black cartridge is use the most.
Aug 06, 2011 | HP DeskJet 5150 InkJet Printer
What is the print cartridge number
HP Deskjet 5150 Printer uses HP 56 ( Black ) and HP 57 ( Tri color ) Cartridges.
HP Black cost you $23.99 and HP Tri-color cost you $39.99
Click on the link below for more information about cartridges.
Cartridge Information
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Dec 16, 2010 | HP DeskJet 5150 InkJet Printer
Ink Cartridges
If is an original brand? Some generic cartridges or refill ones gave that problem.
Jul 06, 2008 | HP DeskJet 5150 InkJet Printer
H.P.Deskjet 5150 printer
TRY CLEANING THE SURFACE WITH MOIST CLOTH THAT CONNECTS WITH UR COLUR CARTRIDGE CIRCUIT.WISH U SUCCESS
May 05, 2008 | HP DeskJet 5150 InkJet Printer
Colour won't print - HP Deskjet 5150 Inkjet Printe
hi, remove the color cartg take a tissue paper and run it horizontaly on the nozzel, if u can notice the three colors, ur cartridge is ok, may be the contact area of the cartridge,try to clean both the surfaces, and install the exact driver for the printer which will give you the cartridge maintenence options. let me know??
Dec 16, 2007 | HP DeskJet 5150 InkJet Printer
HP Deskjet 5150 won't print black
ya hi, the nozzels must have got dried up and choked, put a few drops of hydrogen peraoxide on the nozzel for some time and then clean it, this will free the pores in the nozzel, be careful with the chemical, or take some proffessional assistance.. let me know
Nov 29, 2007 | HP DeskJet 5150 InkJet Printer
HP DskJet 5150 will not print black
re-install the print drivers. if it still doesn't print problem lies in the bubblejet power supply - not user fixable
Sep 06, 2007 | HP DeskJet 5150 InkJet Printer
166 people viewed this question
Ben Johnson
