Question about HP LaserJet 2100 Printer
Printer is offline the hole office they can't print can your please help guys please
  • 2 more comments
  • sseko Oct 14, 2008
    it is network printer
    Offline
    it two color lite green and green
  • dren1013
    dren1013 May 11, 2010
    Is this printer shared via a desktop computer, from the server, or is it on the network via a Jet Direct card? Also, is the printer actually OFF-LINE or is the printer on line and nobody can see it?
    Let me know and we can probably get this on knocked out.
  • 18 Answers
Is there an Ethernet cable plugged directly into it or does it connect to a computer?
Does the printer show ON-LINE or OFF-LINE on the display?
Posted on Oct 14, 2008
  • dren1013
    dren1013 Oct 14, 2008
    Ok, the printer is showing OFF-LINE.
    I am assuming the printer has a network cable plugged into it and the other end of the cable is plugged into a Ethernet jack in the wall. You need to look where the cable goes into the printer. Are there any lights on? If yes, how many and what color are they?
  • dren1013
    This may sound silly, but...make sure there is paper in the printer and remove the toner cartridge and make sure there is no paper in the feed path. If these things are OK it is possible that the network card in the printer is bad. Do you, by chance have another printer like this one you could swap the network card with to test? If so, try that and it will verify if the card is any good or not. Let me know how it goes.
HOW TO FIX...PRINTER IS OFFLINE BUT IT IS ON...WE ARE UNABLE TO PRINT.
says hp printer Envy 4500 is offline but it is on - HP Support ...
h30434.www3.hp.com > ... > Mobile Printing
how do i get the wireless printer to print when it says printer ofline buts its on and connected to network. ... Re: says hp printer Envy 4500 is offline but it is on ... Ruled out computer shutdown/restart which was easy because we don't initiate re-boots often.... I cannot believe HP's developers are unable able to reproduce.
Windows 8.1: Printer Offline Issue - HP Support Forum ...
h30434.www3.hp.com > Printers, Copiers, Scanners and Fax > Inkjet
Apr 25, 2014 - 10 posts
Windows 8.1: Printer Offline Issue If you have seen issues where your ... HP Laserjet -Printer offline and unable to print on a network in Windows 8.1 .... If there is connectivity then we need to perform next troubleshooting step. ... But since yesterday if I try to print it comes up with the error message "printer ...
Unable to print as the printer is Offline with 14 documents ...
answers.microsoft.com/.../unable-to-print...printer-is-offline.../3fc1a57e-...
Original Title: HPrinter Print printing My printer is Offline with 14 documents waiting. ... Please try the steps suggested and update us with the results then we will ...
I see the message Printer is Offline when I try to print with a ...
Jan 08, 2016 | Office Equipment & Supplies
My printer hp officejet 4355 keeps saying offline although I click "use printer office" help me guys :(
Check to see if your printer is set as the default on your computer.
Also check the connection between your computer and printer. If it is wireless, the computer may be going into energy saving mode and starts once a print job is sent to it.
Mar 24, 2015 | HP Officejet 4355 All-In-One InkJet...
Just set up cannon PIXMA MX870 printer. Cannot get it to print from wireless connection. In my printer box it says the printer is offline. It will print when I connect the printer with a cable. I use a...
I had the same problem - my printer showed that wireless LAN was enabled & my mac showed the printer but said it was offline. I went to preferences, print & fax, hit the + key to add a printer, added the canon printer again, set that printer as my default, did a print command from Word & that created a queue in the new default printer ... and it printed. Deleted the first Canon printer that was "offline." Oh, and I'm not sure if it made a difference, but before what I just described, I checked for software updates after the printer CD install process & uploaded one update.
Jan 27, 2011 | Canon PIXMA MX870 Wireless Office...
I have hp lj 4100n printer in my office. this printer is been used for backup. today we saw an offline problem. we just did basic thing like right click on printer icon make seclect printer on line and...
Thank you for contacting FixYa with your printer inquiry.
HP Jetdirect and Embedded Jetdirect Inside Print Servers - A Printer Reports Being Offline or Out of Paper A printer using the HP Standard TCP/IP Port reports being offline or out of paper, even though the printer can be pinged, can display the embedded Web server, and is not out of paper.
  1. Open the Printers or Printers and Faxes folder.
  2. Open the Properties of the printer and the Ports tab.
  3. Click Configure Port .
    This is the most common cause. Hope this helps helps. Please keep us updated and remember to rate this answer. TF
Jan 18, 2011 | HP LaserJet 4100 Printer
My compter file says that my Cannon imageclass 2300 is offline what is the prolem?
Go to the CONTROL PANEL on the computer, select PRINTER?FAX icon, then click on the name of the printer you want to associate with your printing needs and make sure it is connected. This will allow the print jobs to go..... Please let me know if there is any thing else you might need, of if it is still offline, we can go further! Guy :) Pleasure to help out.....
Sep 24, 2010 | Canon imageCLASS 2300 All-In-One Laser...
Printer is offline how do I get it online?
Try to print. Once an error appear on your computer, right click the printer icon on the taskbar and click open printer connection.
Printer window will appear.
Highlight the pending print job. Click the File menu and uncheck the Print Offline.
Right click on the pending print job and select Restart printing documents.
Jun 23, 2010 | Canon PIXMA MX340 Wireless Office...
HOW TO GET MY PRINTER FROM OFFLINE AND TO PRINT. we HAVE A HOME COMPUTER WHICH THE PRINTER IS SETUP TO BUT WE ALSO HAVE IT WIRELESS FOR OUR LAPTOPS. NOW ITS NOT PRINTING FROM HOME COMPUTER ITS SAYING ITS...
Make sure that the usb cable is well connected from the computer to the printer .... try switching usb ports on the pc....
if it still stay offline... you will have to delete it and make a new installation of the printer driver....
But i'm pretty much sure that the usb cable is losse or something
Jan 24, 2010 | HP J4680 Office Jet All-In-One Printer
Printer status says offline, and we can not print on laptop
Hi!
If you're offline with the printer, you definitely won't be able to print.
I'm assuming you're using Windows XP here. Most Windows products will be similar...
On the laptop, click on the Start button, then Settings, then Printers and Faxes. Find your printer in the list, right-click on it and click "Use Online" or uncheck the "Offline" box.
Good luck! Remember to rate the solutions!
Aug 10, 2009 | HP Officejet 6500 Wireless All-in-One...
I was trying to print using a PIXMA iP1300 but it doesn't allow printing withe a message box appearing "printer is offline".can you help me please
Printer offline : make online in printer properties.Printer offline when start to print : head problem. Replace head.
Jun 12, 2009 | Canon PIXMA iP1300 Printer
Back again....please help
Try this. Go to Start, Printers and Faxes, right click on your printer. When the menu opens make sure there is NOT a check mark next to "Use Printer Offline".
Jun 18, 2008 | HP Photosmart C3180 All-In-One InkJet...
HP LaserJet 2100 Printer Logo
1,043 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
