Question about Sony Grand WEGA KF60XBR800 60" Rear Projection Television
RCA HD52W59 Projection Big Screen TV
TV comes on but has three colors that blur. Words at bottom of a picture arc in semi circle? Unit is only two years old and the warranty recently expired! Help.
Rev. Craig the word are arched at the top and buttom, picture is blurey with three different colors
  • taysteebread Oct 14, 2008
    Same problem. My tv is about ten years old. GE 46gw945LG2. Have had problems with sound and picture going flaky, but a good smack to the side of the cabinet would resolve the problem sometimes for months. The convergence problem Just happened a few days ago. From what I've seen on the net, there is a chip that controls this function. I am debating whether to put the money up to fix it or just go out and get myself a new high def unit. Probably the latter : )
  • 84 Answers
You have cold solder conections if you know how to solder you can fix it with a good light
Posted on Oct 22, 2008
Hd52w59 wont turn on
If you can get at it this set has a high voltage splitter up front (remove entire front grill beneath the screen and the inspection plate behind that) that also fails---it is usually tan in color and has a red HV lead coming from flyback to it---three wires there go to the picture tubes--just remove the one or two screws that secure it and look at the bottom for any burn marks or signs it has been arcing.
May 01, 2012 | RCA HD52W59 HDTV Projection Television
Im fixing a rca hd52w59 itc 222a and i found the flyback making an arc of purple energy and the tv still runs and has good picture but this arc after a few minutes causes a big shock and the tv shuts down,...
The flyback should be replaced your model uses the 270125 flyback. Its a easy repair. You can get the replacement 270125 flyback from www.tvrepairworld.com and they send a Cd with detailed instructions on how to do the replacement.
Jan 23, 2010 | RCA HD52W59 HDTV Projection Television
My RCA projection tv makes a loud buzzing, humming noise. Does as soon as turned on even before picture comes on, does not stop till tv is turned off.
buzzing noise is cause by small electrical arc inside the unit or a problem in your audio circuit.if you can open the unit up and check if its an electrical arc.
Jun 21, 2009 | RCA HD52W59 HDTV Projection Television
Rca projection tv
this is a indication of convergence problem. the curved picture indicates total or a complete loss of convergence power. I first recomend you read the artilce in tips in tricks section. the fl231 problem it might be this if you do not have the convergence options in setup of customer menu. if not it might be a convergence power board issue
Oct 12, 2008 | RCA HD52W59 HDTV Projection Television
This problem is commonly refered to as a CONVERGENCE problem. Question 1 do you have convergence seting in setup menu...if you do NOT it could be a special small fuse. 2 if you go into setup then convergence. then can you move crosshairs in setup. Since you have a arcing picture this indicates convergence power supply problems....in which has to be replaced or repaired,
May 09, 2008 | RCA HD52W59 HDTV Projection Television
Colors are in three
Convergence ICs need to be replaced.
Feb 03, 2008 | RCA P61960 61" Rear Projection Television
HD52W59 bowed picture
Check your screen. I have the same problem with mine. If the screen has a ripple in it, it could give the same effect.
Dec 15, 2007 | RCA HD52W59 HDTV Projection Television
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 REAR PROJECTION
there should only be three colors.. can they be aligned?
Sep 16, 2007 | RCA HD52W59 HDTV Projection Television
Sony Grand WEGA KF60XBR800 60" Rear Projection Television Logo
284 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
