Question about Samsung Televison & Video
Samsung LCD TV LE32N7. The blue stand-by light flashes continuously and the TV will not switch on. Any suggestions? Thanks.
  • 586 Answers
SOURCE: Standby indicator light on TV flashes - Sony TV
    Please check fisrst that indicator liight (LED) blinks how many times.it could be from 1 to 8 times and the interval would be of three seconds.So, count the led flashes how many times and then tell me i will try my best to find and fix the solution.
Thanks
Posted on Nov 19, 2008
  • 147 Answers
SOURCE: TV won't stay on. Green & Red light timer-lamp (Green) stand by/temp (red) flash.
Most likely needs a new lamp. Easily done yourself.
Posted on Apr 15, 2009
SOURCE: TV WONT TURN ON, STAND BY LIGHT FLASHING 3 TIMES CONTINUOUSLY
i have a toshiba dlp doing that after research i found it to need a lamp replacement
Posted on Apr 20, 2009
  • 304 Answers
SOURCE: flashing "LAMP" bottom right side
Unplug the set from the wall. Next you will need to remove the Lamp Door on the right side of the set. Just one screw and you can remove the door. Next you will see the lamp inside. It has two gold colored screws. Loosen both screws and grab the handle and lightly wiggle side to side while pulling the lamp out. Warning!!! DO NOT TOUCH THE FRONT GLASS AT ALL on the old lamp and the new lamp. If you see shattered glass inside the lamp then you have a bad lamp. There will be a Lamp Code sticker on the left side of the set. Record the lamp Code and purchase a lamp. Once you have the correct lamp just reverse the process. Make sure you have the Lamp Door on correctly and the screw in or else the set will not come on.
Posted on Jul 16, 2009
SOURCE: samsung le32n73bd lcd tv has
Mine has justy done the same, flashing blue light and wont turn on!!
Its only 2-3 years old.
Anyone any further comments, hopefully thisd is a quick fix.
Posted on Jan 19, 2010
My Samsung LE32N7 does not come on. The blue light under the screen constantly flashes without the tv coming on.
Hi, maybe the TV controller board is blocked, you can reset it, by disconnecting power cable from outlet for about 5 minutes, if that doesn't work, possibly and internal board or component must be repaired of replaced, in such case it's better to contact an authorized Samsung service center or technician to check your TV.
Nov 07, 2017 | Televison & Video
Samsung B2330HD Blue Still light, no picture?
Hay Junior!
You have a power supply problem and unfortunately this repair sould be done by one who knows electronics specially tv electronics..
Jun 19, 2012 | Samsung B2330HD 23 in. LCD TV
Hi when i go to turn my TECHWOOD lcd tv on the blue standby and the orange on light just continually to flash on and off..have you any suggestions to why this is happening..many thanks
hi;
if there's standby light and wont start , even if you press the power button , it has a power supply failure, maybe some capacitor ha bloated or change the value, try to watch this http://www.youtube.com if you know how to solder, or even disassemble the back of LCD TV. if not try to call a repair technician.
thanks ,, hope this help.........
Sep 05, 2011 | Televison & Video
Picture and sound going out- flashing lights
the problem its the main board it controls everything if no warranty go to www.shopjimmy.com better prices better than manufacturer and tv repair man
Apr 13, 2010 | Samsung LN46B650 46/49.5 in. LCD HDTV
Samsung 55" flat panel lcd tv is not coming on the standby button light stayes on but no picture coming on it doesn't come on with the switch only by plugin it to the outlet.
Does the backlight come on? or even flash on and off when the TV is switched on? I presume the standby light is showing 'blue' then. Do you have any sound? Also, when the TV remote is pressed, does the standby light flicker?
Feb 22, 2010 | Samsung LE40R74BDX 40 in. LCD Television
Lcd tv turns off after 5 mins, leave 2 mins comes on to stand by
Swollen ( bad ) caps in power supply first place to look.............T.
Dec 17, 2008 | Samsung DLP HL-P5663W 56" TV
Wharfedale LCD3210AF
dose any 1 now how to fix this problem, i turn on my tv the light is just BLUE, the red light aint showing
Jul 10, 2008 | Televison & Video
Televison & Video Logo
103 people viewed this question
Henry  Thomas
Henry Thomas
