Konica 3331 copy machine ( osama tech )
I have still same problem ( code 35 - 02 ) konica 3331 , i checed fueses and the problem still appear , please help me for find all solutions for this problem .
Regards
osama boss
  • sam gerban
    sam gerban May 11, 2010
    DID YOU EVER SOLVE YOUR COPIER PROBLEM?
  • sam gerban
    could you verify modle # for me sound like fuser code.
How to enter mode 25 in konica 3331 copier
Posted on May 24, 2011
Checked your sensors in fixing unit....the switch in front door....the power supply....but most of the problem is the thermistor...replace for the new one...
Posted on Mar 03, 2009
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
JUST CHECK THIRMISTOR .IT IS DIRTY HAVING TONER ON IT JUST CLEAN IT .IT WILL BI OK
BY MIAN AKHLAQ
Posted on Dec 18, 2008
Konica minolta 8031 occurring error code c-3c30 when the machine is ready to copy & i try to press copybutton.some body please help me
Sir/Mam,
You hit a serious code, noting can be done, this code requires a tech to come out and remove a chip inside the machine, which is then sent to Konica Minolta, then on to the US SECRET SERVICE since someone attempted to counter fit US currency!!!!!!!!!!!, until the US Secret Service determines what was done the machine stays inoperative , once what happen is determined tech will come out reinstall the chip reload firmware, and .NEVER EVER PLACE ANY CURRENCY ON A COPIER all the machine now a day have Bank Note chips.
Aug 13, 2016 | Konica Minolta Bizhub 8031 Copier
I got code 3c00 on a konica c25 how do i reset this code its lock up
YOU GOT THE BIG ONE!!!!!! Some one tried to copy MONEY on that machine. NOW you will need to get a Konica Minolta Representative out to remove a special chip that will be sent to Konica Minolta then to the SECRET SERVICE. IN the mean time ask the Konica Minolta tech if they have a loaner, your machine is down until the SECRET SERVICE determines what has happen. SORRY the Color copiers are so good these day that they have a small chip that looks for info on currency and shut the machine down. SORRY
Oct 19, 2015 | Konica Minolta Office Equipment & Supplies
Customer has C451 bizhub that has unresponsive control panel except it will make ONE copy after hard reboot. Then no buttons work, particularly the Utility/Counter button. Can't get in to service mo
Hi
The bizhub C451 is a Konica-Minolta machine and I have found a webpage here:
Error Codes Konica Minolta bizhub C451
that details the error codes that can occur on your machine. I know that this may not be of much use as you don't appear to have any error codes appearing. However, there is also a link at the top of the page from which you can get a copy of the Service Manual which will probably have a lot more detail in it and may answer your question.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 28, 2014 | Office Equipment & Supplies
M4
I have a machine konica Minolta always appears incorrect code C-2703 I wanted to know what the cause of the problem and how to solve
Dec 15, 2013 | Konica Minolta bizhub 250 All-In-One Laser...
My konica 3331 is giving me an error code 36-C1 ,what should i do.
thid is a fuser error code causes could be heat lamp, thermistor, thermofuse or circuit board
Sep 30, 2009 | Office Equipment & Supplies
Code 35-02 ( konica 3331 )
problem with fuser, check thermistor, thermofuse or lamp
Oct 06, 2008 | Konica Minolta DiALTA CF910 Copier
Konica Minolta C450- error code c-2251
It's been a while since you posted that but you may just need to slide it back out and shake it back and forth (long ways) a few times. We had the same problem and the konica minolta tech told us to do that. It worked. DO NOT turn it upside down though.
Apr 23, 2008 | Konica Minolta bizhub C450P Laser Printer
Konica Bizhub 250 diagonal stripe (loss of color or tone)
Sounds like it needs service.
The life expectancy meters are just general measurements. They only indicate when it is time for a Service Tech to come by a review the parts. If you are having that type of imaging problems you need a Tech to look at it.
Apr 14, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Konica 3331
make sure toner is full and corona wire leads havent come lose or broken.
How was the copy quality before the printer was moved also make sure mahine is level
Jan 15, 2008 | Konica Minolta DiALTA CF910 Copier
210 people viewed this question
jasbo
jasbo
