Question about IBM Wheelwriter 30 Typewriter
Right Margin Our office IBM Wheelwriter Series II typewriter will not allow us to type beyond 4 inches before stopping. How can I fix it to allow us to type all the way across the page?
First with the T/W off move carrier back and forth checking for binds or anything binding the carrier if there are no forgien objects try a little WD40 on the shaft that the carrier slides on. DickyO
Posted on Oct 15, 2008
Show me where the solenoid is on the IBM Wheelwriter 10, Series II typewriter
If you are asking about the print solenoid. Remove thr ribbon, below the ribbon just inside thr L. printer frame. It's about an inch & 1/2 in diam. and about 3/4 inch thick and silver.
May 22, 2012 | Lexmark Wheelwriter 10 Series II...
How do I re-program my typewriter? the margins are too far in. IBM Wheelwriter 15 Series II
Go to the margin, press margin release, space or backspace to the desired location, press L. or R. margin.
Dec 10, 2010 | IBM Office Equipment & Supplies
My IBM selectric II typewriter carriage stuck in right margin
Sounds like the return lever arm is not putting enough pressure on the return clutch, or the clutch is slipping. The exp key uses the same clutch but the pressure comes from your finger. Theres no way you can fix this yourself. Get an IBM mechanic.
Oct 14, 2009 | Lexmark Wheelwriter 15 Series II...
IBM personal Wheelwriter 2 margins not clearing
Return to the L. margin, touch the mar rel key top key on L. of the keyboard, backspace to location where you want the L. margin, touch the L. mar key. Put some WD40 on the silver shaft that the carrier slides on.
Jun 24, 2009 | Lexmark Wheelwriter 5 Series II Typewriter
IBM Selectric II-return goes past the margin stop
The margin release mech. is probably gummy and allowing returns to go past the margin. If thi is a dual pitch machine see if the pitch selector lever will move easily. If not use some WD40 on the margin rack.
Mar 11, 2009 | Lexmark Wheelwriter 15 Series II...
Need to reset all the margins on IBM Wheelwriter 10 Series II. The margin release button will not release the left margin.
The problem may be that the carrier is binding on return, put some light lube (WD40 works well) on the silver shaft that the carrier slides on.
Jan 15, 2009 | Lexmark Wheelwriter 6 Series II Typewriter
IBM Selectric II
The return clutch torque limiter is off or broken. If you take the right dust cover off it is on the turning hub around the middle of the typewriter. a small spring about 1.25 inches long with a hook on the end. I have been fixing these for 35 years. good luck. Lawrence
Jun 06, 2008 | Lexmark Wheelwriter 15 Series II...
Margin Problems
You are in auto return. Press code and R
This should doit
Mar 10, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 30 Typewriter Logo
64 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
