Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
NO Signal KV32fv26 Sony Trinitron
I have a Sony Trinitron just replaced the power supply board due to a power surge. Get a super picture from my DVD however cannot get a signal from my cable. Replaced the antenna changer thinking this may be the problem-no result
Any ideas what's next
  • m_daisy36 Oct 14, 2008
    Thanks Dals. Where's the best place to find new tuner. Any idea of cost?
  • 61 Answers
I think your problem is in tuner stage.
1. Check 32V dc available on BT connection on tuner.
2.If 32V available on BT,connect dc meter and put the unit on auto search and check the BT pin on tuner.The BT voltage will decrease and increase while it tunes.
3.If nothing stored after programming replace tuner.
Good luck
Dals123
Posted on Oct 14, 2008
  • Sunny Valiplackal Oct 15, 2008
    Here is the part number for the tuner 8-598-430-50 or 8-598-430-30
    when you install tuner very careful,because this is not the original tuner.
    You need to remove pins 16,17,18, and 19 from tuner then install.
    Good Luck
    Dals123
Sony KDL flat screen tv broke during a ligtening storm. I'm certain it was caused by the storm because our satellite dish was also damaged. Unfortunately the tv was plugged directly into the wall--not...
The tv power supply board it is dead 100% it is dead that board where the tv power a/c plug into it.Sometimes u get a burn or a chart coal marks if the power surge have big enough charges to the board,not it still kills board too because electromagnatic charges of the storm kills every electronic parts in came in contact with.Take the tv aparts.The tv power supply board are alway the one these two boards are the causes alway and the first board to dies .Replaced the tv power supply board first.Tv should work now,if not the main tv Tuner signal board it is also dead too.That the board where the incomming broadcasting signal wire plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement first and also the main tv Tuner signal board too,if necessary.70-80% changes the power supply board and necessary the main tv Tuner signal boad too tv should work again.20% sometimes the whole tv it fries and a total lost.
Aug 31, 2011 | Sony KDL32L5000 32 in. LCD HDTV
2002 36" Sony Trinitron XBR High Def TV. When you
Your power supply board is dead, do you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem..
Aug 05, 2011 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony trinitron kv36xbr400. no picture no sound. TV was fine this am. Returned to no pic. no sound. Cable guide does come up (visible) when turn on cable box. I have tried to reset by disconnecting from...
turn of the TV, remove it from wall and try it in another outlet. Also, connect the TV to a DVD player. If there is still no sound and picture after connecting the TV to a DVD player, then it means the TV has developed a power problem.
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on.
All these can be checked on the power supply board.
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Regards.
Jul 10, 2011 | Sony Televison & Video
Spot of bad weather here, just had a power surge in the house and now our tv (sharp lc-42SB48UT) won't power on. There is no blue or red light on the front and changing outlets/surge protectors doesn't...
90% to 95% ur tv have a dead power supply board only.5% ur tv could have both dead boards the tv power supply board and the main tv Tuner signal board too.The tv power supply board.That the board,where the power a/c cord plug into it.The tv main Tuner signal board,that the board where all the exstented devices and the tv incomming broadcasting signal cable wire plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement first.The tv problems should be fixed.If not than the main tv Tuner signal board is dead too.Must be replaced also.
Apr 24, 2011 | Sharp LC42SB48UT 42 in. LCD TV
Hi, my sony trinitron Wega KV-32Hs500 will not come on. The stadby light blinks 6 times. I was able to get it on yesterday after repeated turn on, but now won't come on at all. It was working great and had...
common problem. sony makes a power suplly service kit that will repair it. cheap. the power supply is very efficient but ver sinsitive to power surges. easy ans cheap. good picture is worth fixing.
Nov 15, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony KV 36FS10 led light flases, no picture, sound is ok.
unplugg from wall and surge leave for 2 hours. if problems still there. your power supply is probably done. repair is usually pretty reasonable.
Jun 04, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Very old Sony Trinitron
Hello gemdsimm,
You right, its cuased by power surge and you should contact nearest Sony service shop for proper repair.
May 27, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony 36" Trinitron Problem
Good day.
There may have been some problem in the horiontal transistor. Also, Check for the zener diode that controls the supply going to the flyback. It might got busted due to the sudden supply surge.
chris
Mar 15, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony Trinitron Power Surge 5 Blinks
once you have diagnosed the problem, the following link is to all parts for your tv stocked at partstore. they generally have better prices than the dealers and repair shops.
KV-36fs13 parts
you can try the dead-tv kit from fixyourowntv if you have some basic experience with soldering and circuit repair.
http://fixyourowntv.com/orderpage.php
Five blinks means, "IK (AKB)" (white balance). The probable causes listed by Sony are as follows:
1) Video OUT (IC561) is faulty (A board)
2) IC355 is faulty (A board)
3) Screen (G2) is improperly adjusted.
not sure what the 13 blinks are for.
hope this helps,
trin
Nov 19, 2007 | Sony KV-27FV16 TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
143 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
