E-Machines T3256 PC Desktop Logo
Posted on Oct 14, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Desktop background my desktop background has been disable how do i enable it keep telling to go to system administrator
Anonymous
Level 3:
Master:
  • Master 538 Answers
  • Posted on Oct 14, 2008
Anonymous
Master
Level 3:
Master:
Answers
538
Questions
20
Helped
138190
Points
1332
Yes..is you are not logged on a an admin, then this is not accessible.
Why do i have to change my paswort all the time?
You might have it set to change at certain intervals
IE: at log in or after each restart .......
Disable password log in
On both PC and Mac computers, you can set up your system to automatically log in to a certain user account.
As a result, this setting will allow you to bypass the password login that is typically required.
You should only enable automatic login on your computer if it cannot be easily accessed by other people.
Open the Start menu and click on "Run."
Type "control userpasswords2" (no quote marks) into the dialog box and press the Enter key.
Uncheck the box next to "Users must enter a username and password" and click on the "Apply" button.
Enter the username of the account you want to automatically log in with and then type that account's password twice to finish setting up automatic login.
Click "OK." Password login has now been disabled.
Mac Instructions
Open System Preferences by clicking on the Dock icon.
Go to the "Accounts" control panel under the "System" heading.
Click on the "Login Options" button at the bottom of the window.
Select the account that you want to automatically log in with from the "Automatic login" drop-down menu.
also
Depending on what operating system you have, there are several steps you must take in order to disable the administrator account and password on your computer.
Most often, the administrator account and password are disabled in order to minimize security risks on your computer.
This account is often the target of attack if your system is compromised, as it allows access to all of the data and programs on the computer.
In order to disable the administrator account and password, follow the steps below that are outlined for the major operating systems.
If you are using Windows XP, you must be logged on as the administrator in order to disable the account settings.
Microsoft suggests that you set up another account with administrator permissions in the event that you may need to reverse this process.
Otherwise, you won't be able to.
Right-click on the My Computer icon on your desktop and select manage.
Click Users under Local Users and Groups in the left pane, which will bring up all users on the computer.
Double-click Administrator and on the General tab, check Account is disabled.
This will disable the Administrator account and password for Windows XP users.
In Windows 2000, go to Start, select Programs and go to Administrative Tools.
Click on Local Security Policy.
Next, click on User Rights Assignment under the Local Policies option in the left panel.
Double-click Deny access to this computer from the network and then click Add under Local Security Policy Setting.
Click Administrator account under Users and Groups, then click Add.
Click OK to complete the disabling of the Administrator account and password.
In Windows Vista, the Administrator account is automatically disabled.
However, if you have enabled it, you will need to open a command prompt.
Go to Start Menu, click All Programs, select Accessories and right-click on Command Prompt and click run as Administrator.
Open the command box and type net user administrator/active:no. Press enter and you should receive a prompt stating the command was completed successfully.
If you are running a Mac, the Administrator account is enabled by default.
To disable the account and password, go to the Apple menu, click System Preferences.
Choose Accounts from the View menu and click the lock to authenticate with the administrator account password.
Click login options, click edit, and after clicking the lock in the Directory Utility window, click Disable Root User from the Edit menu.
tip
Enable / Disable the Local (Hidden) Administrator Account in Windows 7
Ways to Enable / Disable the Built-In Windows 7 Admin Account Many people familiar with prior versions of Windows are curious what happened to the Local Administrator account that was always created by default. Does this account still exist, and how can you access it?<br /> Recently I ran into an awkward situation where after disjoining a Windows 7 client machine from the domain, I was unable to log in to the computer. This was not because I had forgotten the local administrator password, but because the local administrator account was disabled (which is the default behavior in Windows 7). Like in Windows Vista, in Windows 7 the built-in Administrator's account is disabled by default. Furthermore, this account is not associated with any password. After doing some research, I found the following procedure that worked really well.<br /> <a href="http://www.windowspasswordsrecovery.com/enable-disable-local-administrator-account-win7.htm">Enable Built-in Administrator Account</a><br /> Basically there are 4 ways in order to activate the account:<br /> A) Command Prompt To enable the built-in Administrator's account by using the Command Prompt please follow these steps:<br /> 1. First you'll need to open a command prompt in administrator mode by right-clicking and choosing "Run as administrator" (or use the Ctrl+Shift+Enter shortcut from the search box)<br /> <img src="run-command-prompt-as-administrator.jpg" /> 2. After that you only need to enter the simple command below to activate it.<br /> <b><i>net user administrator /active:yes</i></b><br /> <img src="enable-hidden-administrator-account.png" /> 3. You should see a message that the command completed successfully. Log out, and you'll now see the Administrator account as a choice.<br /> <img src="built-in-windows-7-administrator-account.png" /> You'll note that there's no password for this account, so if you want to leave it enabled you should change the password.<br /> B) Local Security Policy Another way of activating the administrator account in Windows 7 is via Local Security Policy.<br /> 1. Type secpol.msc in the search bar and hit enter.<br /> <img src="secpol.png" /> 2. After the Local Security Policy pops up, navigate to Local Policies-&gt; Security Options where you can see an entry that reads Accounts: Administrator account. Double click the entry to enable it.<br /> <img src="local-security-policy.png" /><br /> <img src="administrator-account-status.png" /> C) Using the Local Users and Groups Snap-in To enable the built-in Administrator's account by using the Local Users and Groups snap-in please follow these steps:<br /> 1. Open Local Users and Groups. You can do so by typing lusrmgr.msc in the Start search box or in the Run command and pressing ENTER. Or, you could open Computer Management by right-clicking Computer in the Start menu and selecting Manage.<br /> 2. Expand System Tools &gt; Local Users and Groups &gt; Users.<br /> 3. Right-click the Administrator account and select "Set Password".<br /> 4. In the"Set Password for Administrator" click "Proceed".<br /> 5. In the"Set Password for Administrator" enter the Administrator's desired password twice, and click "Ok".<br /> 6. Next, enable the Administrator's account. Right-click the Administrator's account and select "Properties".<br /> 7. Un-chek the "Account is disabled" check-box. Click on the "Ok" button.<br /> Administrator's account is now enabled and configured with a password.<br /> D) During the Installation Process There is a 3rd method which advanced users can use. This method can be used during the installation process itself.<br /> 1. During the installation, after being prompted to configure the new user account, you will be able to set the new account's password.<br /> 2. At that phase, press SHIFT and F10 keys together. A Command Prompt window will appear.<br /> 3. In the Command Prompt window, type:<br /> <b><i>net user</i></b><br /> Note how the Administrator account is there, yet the new user account has not been yet created.<br /> 4. To set the Administrator's account password:<br /> <b><i>net user *</i></b><br /> 5. Then enter the required password and confirm it.<br /> 6. To enable the Administrator's accoun:<br /> <b><i>net user administrator /active:yes</i></b><br /> 7. Close the Command Prompt window and continue with the installation process.<br /> If you log off you will now see the Administrator's account as a valid logon option.<br /> Disable Built-in Administrator Account Make sure you are logged on as your regular user account, and then open an administrator mode command prompt as above. Type the following command:<br /> <b><i>net user administrator /active:no</i></b><br /> <img src="disable-local-admin-account.png" /> The administrator account will now be disabled, and shouldn't show up on the login screen anymore.<br /> <a href="http://www.windowspasswordsrecovery.com/downloads/Windows_Password_Recovery_Tool_Trial.exe">Hack into Windows 7 Administrator Account </a> [Free Trial] Article source: http://www.windowspasswordsrecovery.com/enable-disable-local-administrator-account-win7.htm<br />
on May 23, 2011 • Computers & Internet
tip
How to improve Windows XP performance in 6 short steps?
Though the computers of today are strong enough to handle and run Windows XP, with all the visual enhancements enabled, some old computers, or systems with low amount of physical memory and/or a "weak" graphic cards could (and would) run more smoothly with those "cosmetic visual enhancements" disabled.
The default setting is to let Windows choose what's best for your computer, but in 90% of the time, "helping" it a little will surely improve your computer performance!
To disable those visual enhancements, all you have to do is follow the following 6 short steps:
  1. Right-click on My Computer and choose Properties.
  2. Go to Advanced tab.
  3. Click Settings, under Performance section.
  4. Choose Adjust for best performance.
  5. If you would like to keep the "Windows XP Style" (as oppose to "Windows Classic" = Windows 98/Windows 2000 style), you will need to re-tick the 2 last options (Use drop shadows for icon labels on the desktop and Use visual styles on Windows and buttons). This will keep the nice graphical interface and will preserve Windows XP "fancy look".
  6. Click OK on Performance Options window, then click OK once again, to close System Properties.
  • You can always turn the visual enhancements on by repeating steps 1-4 and choosing Let Windows choose what's best for my computer.
  • To make ALL visual enhancements on, choose Adjust for best appearance instead.
Note: Changes take effect immediately, no reboot required.
Another side-issue regarding visual styles is the wallpaper, or Desktop Background.
Having no background (a solid color. Select None in the background's settings under Desktop tab in Display Properties) will demand less resources from the computer and increase response time when showing the Desktop. On the other hand, having a large-size (both in scale and in file size) photo will need more resources (especially memory) to rescale and view/reload it, every time the Desktop is shown.
on Mar 06, 2010 • Computers & Internet
I cant change background what i want in my laptop samsung, can you tell me what ist problem
- First check and make sure that the user account that you are using is an administrator.
- try setting a picture as a desktop background ( right click on an image and click on set as background)
- open regedit go to HKLM\Software\Policies\Microsoft\Windows\system check the right hand side window for a key titled desktop, if you find it delete it. then try to change the background
1helpful
I cant set a desktop backround for the hp mini laptop
You have windows 7 starter or vista starter i am guessing , which means there is no option for changing the background, it has been disabled.
It can be enabled though through various hacks
click on this
Stardock MyColors
download it and To use it, find a jpg wallpaper you like, then run Starter Wallpaper Changer as administrator (right click onb the file and click run as administrator). Select your jpg file, and change. Then log off, and log back in. Simple!
please vote if this was useful to you
tip
Enable hidden Administrator account Window 7
Try this, 1. Open a elevated command prompt. Click on All Programs and Accessories, then right click on Command Prompt and click on Run as administrator.
2. To Enable the Hidden Built-In Administrator Account -
A) In the elevated command prompt, type net user administrator /active:yes and press Enter.
3. To Disable the Hidden Built-In Administrator Account -A) In the elevated command prompt, type net user administrator /active:no and press Enter.
4. Close the elevated command prompt.
5. Log off, and you will now see the built-in Administrator account log on icon added (enabled) or removed (disabled) from the log on screen
on Feb 07, 2010 • Computers & Internet
My note book starts too much slowly and mostly stucks it takes about 2 or 3 min to the starting window screen and 2 min in the welcome screen. kindly tell me the solution
It might be due to Virus.So please use a anti-virus software and try scanning the virus
To my knowledge , if you have just updated , you should be OK , MS say they have have fixed all their faulty patches .
Did you download all the security fixes ?
Here are some other things to try .
http://www.techspot.com/tweaks/winxp...rvices-3.shtml
http://www.techspot.com/tweaks/winxp...es/index.shtml
http://www.techspot.com/tweaks/wfp/index.shtml
If your system hangs about 2 or 3 minutes at startup, where you can't access the Start button or the Taskbar, it may be due to one specific service (Background Intelligent Transfer) running in the background. Microsoft put out a patch for this but it didn't work for me. Here's what you do:
Click on Start, Control Panel, Administrative Tools then Services.
Go to the 'Services' tab, find the 'Background Intelligent Transfer' service.
Disable it, apply the changes & reboot.
Or if you don't want to disable it .
Background Intelligent Transfer Service. Uses idle network bandwidth to transfer data. For the majority of Users this feature should be of little use & as such I'd recommend setting it to Manual. Those on highly active Networks may benefit from having this set to Automatic, although it may be worth testing out to see if it does.
http://rogier.xszone.nl/windows/wintricks.html
• Defragment boot files
The boot defragment option is usually enabled by default, but it may be disabled, or not properly enabled. If it's not working, XP may boot dog-slow.
To enable it:
- Edit HKLM\Software\Microsoft\Dfrg\BootOptimizeFunction, find the string called Enable. If the string value is set to N, change it to Y.
http://support.microsoft.com/?kbid=308041
Resources for Troubleshooting Startup Problems in Windows XPmag-glass_10x10.gif
http://www.blkviper.com/WinXP/servicecfg.htm
http://www.blkviper.com/WinXP/servic...#Network%20DDE
Enable Quick post in BIOS setup , as long as you have a have a lot of memory .
The normal memory test , is tested three times & that alone may take 60 to 90 seconds.
http://www.windows-help.net/WindowsXP/troub-07.html
http://www.tweak3d.net/tweak/winstartupnew/
Disable the Windows XP Prefetcher
Windows XP has a Prefetcher component, which shortens the amount of time it takes to start
Windows and programs. When trouble shooting either Windows or program start-up issues, it might
be helpful to disable the prefetcher, because it runs as a background service while other
applications are running or loading.
To disable the prefetcher:
Start the Registry Editor
Go to HKEY_LOCAL_MACHINE \ SYSTEM \ CurrentControlSet \ Control \ SessionManager \ Memory Management \ PrefetchParameters
Double-click the EnablePrefetcher value (remember the value that EnablePrefetcher is set to!)
Change the Value data to 0 to disable the prefetcher .
Close the registry editor and reboot the computer for the changes to take effect
When done troubleshooting, you can re-enable the prefetcher by changing the Value data to its
original value.
Values for EnablePrefetcher are:
0 - no prefetch
1 - prefetch applications only
2 - prefetch boot only
3 - prefetch both applications & boot (default)
I find 5 is best .
THANKS......
WITH REGARDS........
VAISHU
1helpful
How do I enable UPnP on a router
Login to the router throught your chosen web browser, then on the administration tab at the top tick the box that enables UPnP
"UPnP. If you want to use UPnP, keep the default setting, Enabled. Otherwise, select Disabled.
Allow Users to Configure. Keep the default setting, Enabled, if you want to be able to make manual changes to
the Router while using the UPnP feature. Otherwise, select Disabled."
3answers
My task manger is disabled by the administrator
For Windows XP Home Edition use "The registry edit & For Windows XP Professional you still use the option I had suggested which is:
• Click Start
• Click Run
• Enter gpedit.msc in the Open box and click OK
• In the Group Policy settings window
o Select User Configuration
o Select Administrative Templates
o Select System
o Select Ctrl+Alt+Delete options
o Select Remove Task Manager
o Double-click the Remove Task Manager option
I hope this Info has helped you.
or:
Click Start -> Run. Type in "regedit" (no quotes) and hit Enter.
Search for HKEY_CURRENT_USER -> Software \ Microsoft \ Windows \ CurrentVersion \ Policies \ System.
Look for: DisableTaskMgr. Click on REG_DWORD. Value: 1=Enable this key (disables TaskManager); Value: 0=Disable (actually enables TaskManager)
Close RegEdit
Reboot your machine.
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
