Question about Dell Latitude D600 Notebook
Dell Lattitude D600 Laptop (Secondary Hardrive not found)
Ok our laptop worked Sunday night; Monday morning before work my fiancé turns it on to check email as he always does. He notices it's taking a little longer to come up, so when he comes back to it, it had loaded to the desktop but it's blank. So he restarted it..which leads to that last time we have been able to get to that point again.
Now we turn it on and it makes this clicking noise and says hard disk drive not found we have done the F2/F3 (not sure which one it is at the moment) and F12 to run the diagnostic test which it passes everything but failed DST and it wants us to insert the winxp cd that the laptop came with (which is another problem because we purchased this laptop a year ago from via a company auction (so it's refurbished) and also means it came with no cd's, then also when we do the F12 sometimes it will show 60 gb, kb or whatever the bites are for the computer but then says secondary hard drive not found.
I found where I could download the winxp professional cd to try and fix the problem but then there is the issue where it does not have the ability to fully read anything in the cd/d driver. I read on someone's posting on this site about how sometimes the hard drive can come loose so to check that, and when looking at it it says the hard drive was dated 2004...we have been in the market to buy a backup driver for our extensive collection of music we had stored on the computer and pictures..and well needless to say we didn't come home with anything at this point, so if we are looking at a totally hard drive failure then I guess we will have to take our music and pics as a loss. One thing my fiancé said was that on Sunday night he noticed that the battery felt hot (as if maybe it wasn't cooling down enough and the battery light flashed red, (which the computer was plugged into the wall and wasn't working off battery power). So not sure if it's possible that maybe it over heated and the fan went or maybe if it's possible at all that maybe it's not the hard drive and we can recover our items that we can't get to...also we have another laptop it's a HP and I do have them networked...so not sure if there is any way to, well I guess hope for a miracle. From asking around the clicking noise doesn't sound promising for us, but I'm one of those over kill the problem when it's not the answer I want..and unfortunately since we got the computer for a really good price $$ wise it's not worth paying a ton of money to have it fixed or even at that point purchasing a new internal hard drive if that's what it comes to...Uhhhhhh...Help, sorry about the novel just wanted to put it all out there the first time.!
Do this in the order :
Turn the laptop off
1) Remove the CDROM/DVDROM or combo drive from the Laptop
2) Turn on the Laptop go to bios setup and save the setting
3) Turn Off the Laptop
4) Remove the Harddrive from the laptop
5) Turn on the laptop (It will give you error which is normal)
6) Go to bios again change the boot sequence or something save the bios
7) turn off the laptop
8) Plug the harddrive back in
9) turn on the laptop go to bios again save the bios and exit
10) Turn off the laptop again
11) Plug the CD/DVD back
12) Turn on and the error must be gone
Posted on Mar 10, 2009
    Novelist:
  • 137 Answers
It's much better to have a novel that I can skim than: "computer won't turn on, what's wrong?" which is very common for this site.
Ok, bad news: I can't be 100% sure because I'm not there
Good news: I'm pretty sure that I do know what's going on. Your hard drive is about to die completely.
Bad news: read above, that really was a repackaged bad news thing
Good news: it's not dead yet, so you might get all your stuff off it.
Ok, so if it you hear a lot of clicks, like a metal pen striking a steel stapler (that's what I did to recreate it for my mind). anyway, like metal clicks from the area of the hard drive. AND you have the computer telling you the hard drive is failing by it not recognizing it most of the time. the whole "secondary hard drive" is a red herring. The computer can have a secondary hard drive and that option is probably selected in the startup sequence, but the problem is that your Primary hard drive is failing.
So, a couple options.
1) get a new computer
2) get a new laptop drive. The nice thing is that you can get a decent one on eBay for about $0.50-$0.75 per gigabite which is cheap considering that your computer probably had a 40GB drive. So for about $35 shipped you can get a 60GB drive to replace it.
Then maybe, if you wanted you could get a laptop drive enclosure, which is cheap and will let you attach your "ailing" drive to the computer to **** the good tasty parts out of it if it doesn't decide to die completely by that time.
Your computer is licensed to run a copy of Windows XP, so as long as you don't get it through illegal means, you are fine. You don't have to have the original CD in order for it to be legit. You might have some difficulty installing and validating another copy of Windows, but I'm sure you can get around that. The best/easiest thing would be to eBay a copy of a Dell restore CD for the D600
So $35 for a drive (i'd pick a NEW one, not a used one like the link I sent you)
$8 for the drive enclosure
$ 12-15 for the Restore CD
you should be good as long as the issue is confirmed to be with the hard drive.
This is all work you can do if you are as articulate and process focused as your posting indicates you are. Keep googling for more help or walkthroughs for these tasks and you should find plenty of help. Good luck.
Posted on Oct 14, 2008
Cannot connect My Dell Latitude and Samsung Galaxy S7 via USB
Dell offers technical support via phone and chat. You can reach technical support at 1-800-204-4427. You may also chat with Dell Technical Support representative (U.S.) 6 Am to 6 Am, (24*7 hours) Pacific Time, Monday through Sunday. If you needs a technical diagnosis you can call on our Microsoft technical support team 1-800-204-4427, which is especially open round-the-clock for online assistance.
Dell Laptop Support Phone Number 1 800 204 4427 Tech Help
Apr 30, 2017 | Dell Computers & Internet
Ok I've got a Dell lattitude D600 laptop and I
piece of cake :)
http://code.google.com/p/winsetupfromusb/downloads/list
This program WinSetupFromUSB is very sweet and will make a very good disk for windows installations and much more.
Run the program then select RMPrepUSB button.
3 BOOT OPTIONS
XP/BartPE bootable [NTLDR]
4 FILESYSTEM and OVERRIDES
FAT32 Boot as HDD (C: 2PTNS)
dont change any other values and press the 6 PREPARE DRIVE button
then have your image of windows mounted or the cd in the drive and go back to WINSetupFromUSB.
Select the box for the version of windows that you are installing and browse with the ... button to where the folders on the root of the image or cd and press go.
Enjoy!
Christopher
May 17, 2012 | Dell Computers & Internet
Manual for dell lattitude d600 laptop
Click on link to view manual for D600: http://support.dell.com/support/edocs/systems/latd600/en/index.htm
Sep 27, 2010 | Computers & Internet
Hi, I just started using my dell lattitude e6400 and need to know how i enable the wireless
The little stair step symbol is the Dell Wireless Utility.
If it has an X on it (as in the image above), your wireless is disabled.
Flip the switch on the right side of the laptop to enable it.
When the X disappears, double click on the stairs and it will open the utility.
Mar 03, 2010 | Dell Latitude D600 Notebook
Where is the hard drive located on the dell lattitude laptop
Take 2 screws out of the bottom of the laptop. The hard drive slides out of the side of the unit like the CD Drive would.
Jan 22, 2010 | Dell Lattitude D600 Notebook
Laptop becomes idle after 10 mintues
problem is either motherboard or harddrive
Jun 28, 2009 | Dell Latitude D600 Notebook
Switch monitors between a inspiron 1100 & lattitude d600??
Im not sure if the're compatible. The're the same display type ( TFT active matrix) but that would also depend on your video card. Your best bet is to buy an external 15" lcd monitor as you can find one for under $100.
Jan 11, 2009 | Dell Inspiron 1100 Notebook
No primary harddrive found
Hi there , this does happen with laptop hard drives they will not spin up or detect its just where & tear , the d600 has been around for a couple of years now , most of the time i just buy a faulty laptop just for the ram & hard drive if you need a cheap option this is better just check the specs on the auction before you bid to get a good size hard drive & format it before you use it .
Dec 20, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
309 people viewed this question
Alun Cox
