Question about Canon LaserClass 2060 Fax
Canon 2060p message check/cover paper
Keeps flashing message to check/cover paper i have done everything i can think of unplugged to reprogram checked paper /jams please email thank you
There is a little white piece of plastic that gets stuck when you put in or take out toner catridges when not in the right position it cause that notification thank you again
Posted on Oct 16, 2008
We have a canon MP490 printer, and it says that there is a paper jam, but there is not. We have tried everything we can think of to fix it, including unplugging it, but it hasn't worked.
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Jan 31, 2011 | Canon MP490 InkJet Printer
My canon faxphone L80 keeps saying check cover. I opened and closed the cover. I removed the ink cartridge and don't see any paper jammed. If I unplug and replug the machine the message temporarily goes...
hi, i think that somone was oppened the cover by force, that can damadge the cover switch. open the front cover, look inside is there any foreign body, is the cover switch looks fine, look at this picture from the user guide page 152: mabroukmedal_6.jpg
Nov 03, 2010 | Canon FAXPHONE L80 Laser
User guide
If you go to this web page, you can download the op manual.
Hope that helps...
Jul 14, 2009 | Canon LaserClass 2060P Plain Paper Fax
How do I get ride of the message "Data Error"?
Unplug the fax. Hold down the red STOP/Cancel key and plug in the power and continue the STOP/ Cancel key until the date and time appears.
Jan 27, 2009 | Canon LaserClass 2060P Plain Paper Fax
Check Cover/Cart Message -
if you open the front cover, there is a little white sensor you can see through a slot to the left. this is the sensor for the cover, i just fixed a machine where that little sensor was stuck down to the cover wasn't pushing it in correctly.
Jul 02, 2008 | Canon LaserClass 2060P Plain Paper Fax
Check document message
It thinks there is a document stuck in the document handler. Check for a small piece of paper, or a stuck sensor.
May 27, 2008 | Canon imageCLASS D340 All-In-One Laser...
Canon fax 2060P not recieving faxes
It seems that the protocol is failing. Just check, by printing a receive report. If there are errors it is after the check frame. If no errors, it is failing before the check frame. In either case, 1st aid is to listen using a handset for noise or static on the line. If the line is clear, then you will have to call service to change the tx/rx attenuation.
Dec 06, 2007 | Canon LaserClass 2060P Plain Paper Fax
Canon laser class 2060p super g3 fax machine
The error keeps flashing and the machine will not work. The error reads, "check cover/cart". We put the cartridge in and out about 10 times and the same error message keeps flashing. the fax machine is still not working. Help!
Apr 24, 2007 | Canon LaserClass 2060P Plain Paper Fax
Canon LaserClass 2060 Fax Logo
95 people viewed this question
old marine
old marine
