Question about Sony PlayStation Portable (PSP) Console
Psp lcd how do i remove cover to replace lcd
Psp lcd
    Problem Solver:
  • 5 Answers
When switched on the screen has suddenly developed the appearance of a torn page i.e. the screen looks as if it is torn in half with black , purplish gash ?
Uh oh. Did you sit on it or something? The LCD is cracked. I don't know if sony will cover that under the warranty.. Replace the screen; all it takes is steady hands and a set of electronics screwdrivers. The screen will run you about $25.00. Look up how to do it on youtube. Heres some links to screens:
If you have a PSP-3000:
http://cgi.ebay.com/Replacement-Repair-LCD-Screen-w-Backlight-PSP-3000-/260613635417?pt=Video_Games_Accessories&hash=item3cadc87d59
If you have a PSP-2000(slim):
http://cgi.ebay.com/LCD-SCREEN-REPLACEMENT-PSP-2000-2001-TOOL-BACKLIGHT-/280519692965?pt=Video_Games_Accessories&hash=item415046d2a5 (these ain't cheap)
If you have a PSP-1000(Phat):
http://cgi.ebay.com/BACKLIGHT-LCD-SCREEN-REPLACEMENT-PSP-1000-1001-NEW-/350370971532?pt=Video_Games_Accessories&hash=item5193bcbf8c
Feb 10, 2011 | Sony PlayStation Portable (PSP) Console
No screen is coming on psp
Turn the PSP off and remove the battery and battery cover. Remove the two screws underneath the battery. Remove the other two screws on the opposite side of the battery. Remove the final screw on the bottom edge of the PSP.Grasp the PSP on both sides with each hand and pull the cover off of the PSP. Locate the button bar on the bottom front of the PSP. Use your flathead driver to lift up the left side of the button bar until it pops up off the LCD support. Lift the button bar cable tab upwards to remove the cable and remove the button bar.Insert your flat driver into the small space on the left side of the LCD screen between the the LCD housing and the LCD mounting bracket. Twist the screwdriver slightly and the mounting tabs will pop out. Gently remove the other side of the LCD after popping out the first side tabs. Bend the PSP screen all the way down until you can see the backside of the screen.
Lift up the flex cable connectors and unhook the cables that connect the screen to the PSP motherboard. The tabs are brownish in color; they are very fragile, so be gentle. Lift the PSP screen out of the housing and place to the side.Place your new PSP screen into the PSP, face down like you had the older screen after popping out the mounting tabs. Connect all of the cables from the PSP screen into the motherboard tabs. Fold the screen back into the bracket, snapping it into place. Place the button bar back onto the LCD support, connecting the last cable. Place the cover back onto the PSP and tighten screws to finish.
Apr 15, 2010 | Sony Video Game Consoles & Games
MY PSP WONT ON EVEN YOU WILL CHANGE ITS BATTERY
Apr 12, 2010 | Sony PlayStation Portable (PSP) Console
Nothing on the screen when psp is switched on
Apr 02, 2010 | Sony PlayStation Portable (PSP) Console
How to fix my psp the screen wont turn on
I am trying to change the lcd screen
if it is a 1001 all you need to unscrew is 4 screws on back black ones you will need to remove warrenty sticker inside battery compartment and then remove screw on trim ring. with 2001 remove 4 screws 2 under batery as above one is covered by warrenty sticker then remove one screw on bottom of trim then 2 small screws by usb use small flat head screw drive to release screen from screen mount
May 22, 2009 | Sony PlayStation Portable (PSP) Console
Psp not reading
the memory card is not inserted well.
Feb 20, 2009 | Sony PlayStation Portable (PSP) Console
Cracked LCD
Usually, yes, the LCD is covered under the warranty. If not, it could cost around $400 to fix.
Jul 12, 2008 | Gateway MX6931 Notebook
Cracked psp screen
Youll have to open it up and look if the screen is cracked or the cover, the screen is behind the clear perspex of the outer case.
If its the screen then this will help:
http://cgi.ebay.co.uk/LCD-SCREEN-REPLACEMENT-For-PSP-SHARP-W-BACKLIGHT-Tool_W0QQitemZ200215724197QQihZ010QQcategoryZ127746QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Otherwise you ll need a new case:
http://cgi.ebay.co.uk/SONY-PSP-FACEPLATE-PSP-FACE-PLATE-REPAIR-PARTS-black_W0QQitemZ180232659514QQihZ008QQcategoryZ127746QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Apr 15, 2008 | Sony PlayStation Portable (PSP) Console
Psp distortion
HI Alici,
This can be repaired, however, it will require a purchase of a new LCD screen, and possibly a new shell. I repair this kind of thing at my home.  I run the Playstation Clinic and charge reasonable prices to repair Video game consoles and DVD players.  All together I can replace both the LCD and face cover including return shipping will be $80.  This repair should only be done by a experienced Repair service.  Even knowledgeable repair people that have never disassembled a PSP can damage the psp so badly it will require the replacement of the motherboard as well, if not done properly.  The motherboard costs about $100.  If your willing to get it repaired you can contact me at Repairtech@Playstationclinic.com.  We specialize in PSP repairs.  90 day warranty! The price above is only adding $25 Labor for up to 3 hours of work. Shipping will be about $5.  The LCD screen is about $30, and the cover is about $20. So your Repair would be either $60 or $80 depending on what parts are needed.
Oct 17, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
60 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
