Question about Texas Instruments TI-89 Calculator
Adding and subtracting lengths of measurements
I need to find out how to add and subtract feet and inches......
ie..5'6"-2'8"
  • 24 Answers
You can use the units menu (2nd > 3) to place a unit after some number you want to qualify as being an unit, or you can just type them in like 5_ft + 6_in. Note that you need to add on each part if you are doing mixed measurements; there is no _ft_in combination. So just add each manually - in your case you would do (5_ft + 6_in) - (2_ft + 8_in)
Posted on Oct 04, 2009
How do I change measurement from ins to ft
Divide inches x12 gives feet and a decimal .
multiply the foot answer by 12 subtract the answer from the original number this is the remaining inches now you have feet and inches answer. Don't they teach math any more?
Apr 25, 2017 | Office Equipment & Supplies
I have a 1990 toro wheel horse classic 312 8 lawn tractor, it has a 42 inch side discharge deck, What's the deck drive belt size of this mower, model 31-12K801, I have searched for hours
If the belt is in one piece, put a chalk mark on the back of the belt and measure the length by running a tape measure from one side of the mark all the way around the belt until the mark appears. Take that measurement, subtract an inch for stretch and that number is the number of the belt you need. If it's broken in two, not three, then simply measure the length of the belt.
May 28, 2016 | Garden
My TI-5130 will not add and subtract
It probably uses adding machine logic. Try the following example.
3+
4-
5+
You should get 3, -1, and 4 on the screen, the running total. The tape should show the +3, -4, +5, and finally 4, the numbers that you entered and the total. Think of each entry as adding/subtracting integers on a number line rather than 3+4-5;)
Let me know if you have any questions.
Paul
Feb 04, 2016 | Office Equipment & Supplies
How do I replace a belt on Model no. 110.67032600
The best way to get the correct length belt is to use a piece of string, wrap it around the pulleys. Then measure the string, subtract about an inch to an inch and a quarter. Take that measurement to your parts supply store. By subtracting that sum it will give you good belt tension.
Dec 30, 2014 | Kenmore Elite HE4 Electric Dryer
Luke wants to find the difference 175 - 134. He has subtracted the hundreds and tens so far. What is the sum of the two numbers he has subtracted? How much does he still need to subtract?
SUM means adding not subtracting. so if you were wanting to add the total (the sum) of the amounts of the hundreds and the tens would be 170 plus 130 which would be 300 but the remainder from subtracting 130 from 170 would be 40. That would leave the single units 5 minus 4 of which the remainder is 1. So, the remainder from subtracting 134 from 175 is the reminder of subtracting the one hundred from the one hundred which is zero added to the remainder of subtracting the tens (70 minus 30) which is the remainder of 40 plus the remainder of subtracting the units of 5 minus 4 which is 1. So you need to add the 0 and the 40 and 1 which is the remaining sum of 41.
Sep 19, 2014 | Office Equipment & Supplies
My calculator will add, but after my total and then I want to subtract, it subtracts by the number I added.
If your calculator is more of an adding machine it works a little bit differently than a calculator. For an example: 10 + 5 - 2 on your machine do the addition of 10 + 5, then to subtract the 2 press 2 then the minus sign to get the total of 13. I hope this is helpful.
Feb 06, 2011 | Canon Office Equipment & Supplies
I can't seem to do simple subtraction with my Victor 1208-2. When I subtract say 5-4, I get a negative 9. Is there a setting or do I need to press something different to get simple subtraction to work?
When you want to complete a problem on an adding machine, such as "7 - 3," you would not key in "7," then the subtraction sign, then "3" and then an equal sign. If you do, then you will get an answer of "-4," and you know that is not the correct answer. Again, you have to think like an accountant when you are working with your adding machine. To figure this subtraction problem on an adding machine, you would need to key in "7," the addition sign, "3" and then the subtraction sign; you would get the answer of 4. You are actually working the problem as "7 + (-3)." This would be true on most modern day machines. In order to subtract, you have to add the negative number.
Sep 25, 2009 | Victor 1208-2 Calculator
How big inside (cubic ft.) is the Roper refridgerator
20.9 cubic feet for model # RT21AKXKQ
14 cubic feet for model number RT14BKXKQ05
Jun 07, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Java code for adding octal, hexadecimal subtracting binary,
Hello desireejane,
One method is to do the following
  1. Convert the octal, hexadecimal or binary to decimal.
  2. Add or Subtract the decimal normally
  3. Convert the result back to octal, hexadecimal or binary.
  • Convert the octal to decimal:
public static long octalToDecimal(String octal) throws NumberFormatException {
// Initialize result to 0
long res = 0;
// Do not continue on an empty string
if (octal.isEmpty()) {
throw new NumberFormatException("Empty string is not an octal number");
// Consider each digit in the string
for (int i = 0; i < octal.length(); i++) {
// Get the nth char from the right (first = 0)
char n = octal.charAt(octal.length() - (i+1));
int f = (int) n - 48;
// Check if it's a valid bit
if (f < 0 || f > 7) {
// And if not, die horribly
throw new NumberFormatException("Not an octal number");
} else {
// Only add the value if it's a 1
res
+= f*Math.round(Math.pow(2.0, (3*i)));
return res;
Mar 24, 2009 | Sun Java Programming Language (cdj-275)
Texas Instruments TI-89 Calculator Logo
1,176 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
