Dual Turntable not spinning
I have a Dual CS 505-3 turntable which won't spin when I move the arm acorss the record. Its been a while since its been used and I'm guessing it probably needs cleaning as I can hear the motor going and it tries its best to spin but to no avail!
If this is the case I don't know how and what to clean!
Any ideas ?
  • Anonymous Dec 16, 2008
    Turn table is not turning, I can hear the engine trying to work but it is not turning.  Took off the top of the turn talbe and it looks like it may be the rubber band but I do not know how to adjust it or put it back.
  • philipa53 Mar 08, 2009
    How do you remove the top part of the turntable? I need to get inside but don't know how!
    Thanks
    Phil
SOURCE: Turntable ps-x55 / arm want move stay in lock mode
I have the exact same problem with my TT - a PS-X55. It appears that the motor has failed. Too bad, as I was told the replacement motor part is no longer stocked by Sony. For what it's worth - the part number is 154116500.
Let me know if you manage to find some who has the exact part stocked.
Posted on Feb 26, 2008
  • 5 Answers
SOURCE: Optimus lab 1100 Turntable won't turn!
The mechanics in your arm postion is throwing the switch. A mechanical postion switch has sliped out of postion, a arm from the toner arm post has moved to an encorrect postion, or if your turntable has a multi-album play abilty your 'next to play record' post postion sensor switch is out of postion. Last or first is your belt could fool ya. Your belt may have a weak spot on it in turn no friction underload.
Posted on Sep 18, 2008
  • 4234 Answers
SOURCE: Dual 1228 turntable platter not spinning, the motor will not turn
This particular unit uses an idler wheel to drive the table. Remove the platter and check the rubber wheel. It may be dirty, or just dry and slick. This part may need to be replaced or treated.
Dan
Posted on Dec 19, 2008
  • 42 Answers
SOURCE: sony ps-lx2 turntable clicks when spinning
It seems something may have come loose over time or history, but you will have to delve inside to see what it is. It sounds as though the fault should be obvious.
If you do not want to do this, a repair shop should have no problem. I assume that the deck is working ok otherwise.
Posted on Jan 25, 2009
johncaman
  • 201 Answers
SOURCE: Turntable will not turn (spin)
It would appear this is a belt drive turntable - here's a link to a site where you can order a replacement, although you may be able to find a cheaper one.
http://www.elexatelier.com/panasonic.htm
Hope this helps!
Posted on Mar 26, 2009
The needle arm won't lift and go to the record
Pull the turntable off the mount and look at the loading mechanism, I will bet you will find a broken piece.
Jul 01, 2016 | Audio Players & Recorders
My jensen three speed turntable is not spinning my record
If it is a belt driven model it might have fallen off. If you lift up the turntable matt it should show a hole to view the belt. If the belt is good, it could be that a switch is not engaging when the arm moves out to the record, if it is the type that starts when the arm is placed on the record.
Mar 09, 2016 | Jensen Audio Players & Recorders
When I push start button turntable doesn't rotate
Technics SL-QD33 doesn't turn - Vinyl Engine
www.vinylengine.com/turntable_forum/viewtopic.php?t=28381
Jun 3, 2010 - 15 posts - ‎3 authors
It powers up, lights come on but the platter won't spin. ... However when I press "start", nothing happens and the platter won't spin when ... the arm towards the record without pressing the "start" button. ... SL 7, SL-10... and / or any of the fully automatic Technics turntables using optical record detection......etc Marantz 6300 question...
Nov 21, 2009
Dual CS505 turntable won't auto-start
Aug 16, 2009
More results from www.vinylengine.com
Help!! My Turntable won't spin - AVS Forum ' Home Theater ...
www.avsforum.com/.../1316271-help-my-turntable-won-t-spin.html
18 posts - ‎7 authors
Dec 21, 2015 | Audio Players & Recorders
Detrola record player wont spin, even after moving arm to far right.
I suggest you lift up the turntable matt and see if you can see a belt, which has either broke or come off. You might need a new belt!
Mar 22, 2013 | Audio Players & Recorders
Why does my turntable not spin when I move my Tone arm over?
Hi Daniel, its a bit of a long shot however try this. With the turntable powered of manually rotate the platter approx 12 times to reset the auto operation back to default. John styluscity.com
Nov 30, 2011 | Sony PS-LX250H Turntable
How do you shift to play records. When I turn to phono on dial it turns the unit off. I have a radio cd player with CR24 turntable
Move the tone arm off the rest on to the record and it will start to spin. There is a switch that turns the player off when the tone arm is on the rest.
Feb 25, 2011 | Crosley CR248 Turntable
How do you get the turntable to start turning? We just got a Philco turntable and can't find a switch to get the turntable to turn. We got it used so don't have the instruction manual.
A lot of turntables start moving when the arm is moved to the record start. The turntable should move when you move the arm to the edge of the platter, even with no record. If it doesn't, listen to see if the motor spins. Then lift up the platter matt to see if the belt has slipped off.
May 06, 2010 | Philco (R) 841.205 CD Shelf System
AT-PL50 won't play
take the turntable arm by your hand and place it above the record,then use the up and down lever to lower arm on record!!
Aug 18, 2009 | Audio Technica AT-PL50 Turntable
Hope this helps!
Mar 25, 2009 | Panasonic Audio Players & Recorders
376 people viewed this question
 Grubhead
Grubhead
