Question about E-Machines eMachines Desktop PC
Cannot open my computer
I have problem to open my emachine T4165. It doesn't have those normal big two screws at the back that help us open the side panel.
    Genius:
  • 1,847 Answers
1. First of all, you need to shut off your computer. To do this press the power button on the front of the computer after you have shut it down from Start> Shutdown on your start menu.
2. Unplug the power cord from your computer. This is the big black/white/grey plug that plugs into the power supply on the back of your PC.
3. Unplug the rest of the wires from the back of the computer.
4. Find a sturdy flat surface on which to work on.
5. Unscrew all screws from the back of your computer except the power supply screws. You will make a mess if you unscrew the power supply screws.
6. Open your computer up by taking the side panel off, or sliding the cover off. It might be difficult but it will come off if you have taken all the screws out.
Posted on Oct 14, 2008
Can not open the case on a emachine t1831
Remove ALL cords plugged into the computer. Lay the computer on it's side with indent facing up and remove two large thumb screws from back. Pull the side towards the back using the indent for leverage. If it is really stuck insert a small flat blade the in the slot between the front cover and side and CAREFULLY twist as you slide the blade from to bottom. The side needs to slide towards the back before it can be removed.
Jan 23, 2014 | Computers & Internet
How do i unplug big blue cord on tower emachine
You do have to unscrew the two screws on either side of the plug to remove the cord. Hope this helps.
Jan 01, 2014 | E-Machines eMachines Desktop PC
My emachine computer doesn't start up
Start in Safe Mode then reboot. Windows 95 & 98 used to this all the time.
Oct 06, 2012 | E-Machines eMachines Desktop PC
Open emachines el1352g-41w
Open the eMachines EL1352G-41W computer case?
Unplug the computer from power. Unplug all cables. Turn the computer tower around so the back faces you.
Look at the Left side. This Side Panel removes.
There is a handle for your fingers, formed out of the Side Panel's sheet metal.
Above the handle along the edge, and towards the Top, there is a Philips head screw. Loosen this screw. (It isn't supposed to come all the way out)
Down below the handle, and towards the bottom, is another Philips head screw. Loosen this screw.
Use the handle in the Side Panel, to pull back on it. Pull towards the back of the computer tower.
The Side Panel may only pull back so far. There may be tabs which stick out of the Side Panel, and go into slots in the computer tower's case.
For this style the Side Panel will only pull back approximately 1 inch, or so.
Then the Side Panel is brought straight out away from the computer tower, and laid aside.
[ NOTE*
Do NOT forget to observe Anti-Static Precautions BEFORE reaching inside your computer, and working on it.
Computer on a table, computer unplugged from power, computer case open.
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
Should you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
For additional questions please post in a Comment.
Regards,
joecoolvette
Dec 02, 2011 | E-Machines eMachines Desktop PC
I have an Emachine ET1331g. How do I open the casing to reveal its inner contents?
The eMachines ET1331G desktop computer uses the eMachines NexGen 3 computer case.
Looking at the computer from the Front, the Left Side Panel removes.
Looking at the back you will be viewing the Right side.
There are two screws to remove, then the side panel is slid Back. (Towards the rear of the computer)
There is a raised protrusion in the middle of the Side Cover on the back. This is where your fingers go to pull back on the Side Panel.
There is one screw coming down from the top, on the edge of the Side Panel, and one screw coming up from the bottom.
(Philips head screws)
Remove them.
Slide the Side Panel back. It will only slide back so far, as there are tabs coming from the Side panel, into slots of the computer case.
Once it stops sliding back, take it straight out to the side. Lay the Side Panel aside.
Here is a photo detailing the back of the ET1331G from eMachines Support,
http://support.gateway.com/emachines/desktop/2009/emachines/et/ET1831/ET1831rv.shtml
The two screws on the Right side, as you are viewing the computer from the Rear, as shown here.
NOTE*
1) Computer UNPLUGGED from power
2) Observe Anti-Static Precautions BEFORE reaching inside the computer, and BEFORE handling hardware parts.
Anti-Static Precautions:
Your body carries Static electricity.
Static WILL fry out (Short Circuit) the hardware components in a computer.
TOUCH the metal frame of the open computer case to relieve your body of Static.
Should you leave your computer in the middle of working on it, be SURE to touch the metal frame again upon your return.
For additional questions please state in a Comment.
Regards,
joecoolvette
Nov 19, 2010 | E-Machines eMachines Desktop PC
How do you open computer to insert wireless card?
There should be 2 screws on the back. The side panel will slide off and then you can insert it into a PCI slot.
If its a laptop get it done professionally
May 20, 2010 | eMachines EL1210-11 PC Desktop
Add in slots
if you are talking about pci cards and all of that you have to open the computer from the side removing the screws on the back and sliding the cover towards the back of the CPU. After you remove the side, check the filler you want to remove and there is just 1 screw that holds each one of them, remove that screw and pull the filler out. that opens the bay for you to install a modem, pci card etc.
if it works for you don't forget to rate me
thx
May 03, 2010 | E-Machines eMachines Desktop PC
I RECENTLY BOUGHT AN EMACHINES ET-1810-01 AND CANT FIGURE OUT HOW TO OPEN TO THE BACK BACK PANEL TO CLEAN OUT THE DUST
you should simplly have to remove to screws on the right rear(looking from the back) and sliding the side cover off.
Nov 15, 2009 | Computers & Internet
Panel removal on emachines model e4036
either unscrew in the back, and slide of side or unscrew and open side
Oct 05, 2007 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
103 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
