Magic sing no power no display but supply is good and power chord is good
  • armand1260 Oct 16, 2008
    I am electronics technician, almost 25 years of experience knowledgeable in all kinds of component functions digital to crystal. About my problem in magic sing i need to know what part do I need to change? The supply is good but when i switch on the power sometimes the display will appear then goes out. can you help me? thanks!
  • 165 Answers
Hello how about other display to check it if it do not leaking inside.....or is a dried up filter. usually these cause most funny problems like yours.saludos
Posted on Nov 20, 2008
Magic Sing ET19KV On connecting Magic Sing through RCA Cable, get buzz sound on my speakers Have chked on diff TV's and replaced the RCA cable.The Video is clear, but getting buzz on speaker
Most buzzes are caused by one of two things: "DIRTY" power or a lifted\non-existent ground. Allow me to explain;
"DIRTY" power is just that. It comes in and carries a lot of static with it. Most newer systems have filters built in on the power side of the main board. The fix? Try running your Magic Sing from a wall socket that doesn't have anything else pulling from that particular circuit. You should also invest in a GOOD power strip and not one that cost $5-$10 bucks. All these are good for is getting power to multiple products simultaneously, AND they don't have the resistors and filters to give you a constant 120v AC.
Monster Cable Co. was a very sought after item up to the point to where Radio Shack no longer carried their products.
If you really want to get your money's worth out of the instruments you buy, don't slack on the power strip. This will be the most costly mistake ANYONE can make.
Here is an article that explains what I did and gives you answers on how to fix this issue.
Hope this helps. Dirty Power What It Is and Why You Need to Clean It Up Schneider Electric...
Aug 12, 2017 | EnterTech Magic Sing Et19k Et-19k Et19kv...
I have enter magic sing i put it on a wrong voltage then the power supply regulator got burn how can i replace it. where can i buy iC76A and how much
It is likely soldered into the circuit board. It may be any of several part numbers such as 7805.
Try to read ANY number you can off the IC itself... the last two digits are the voltage... 7805, 7812, 7815 are common ones... There often is a production lot number... see if you can find the number ang et back to me as email.
Jan 21, 2011 | Karcher Enter Tech Magic Sing Mic Et-18kv...
My magic sing microphone stopped working how do i fix it
my magicsing doesnt switch on, neither with batteries nor with a given power supply
Dec 29, 2009 | Magic (ED8000) Professional Microphone
I have connected the Magic Sing to a HD TV and a home theatre system and now get a sound-lag between the voice and the sound on the home theatre. Any ideas?
You need to connect directly the sound wire of your magic sing to your home theather while the video wire of your magic sing directly to your hdtv. If its difficult to do because of distance, buy an rca extension to extend your magic sing wire to make it reach to the other end.
Dec 26, 2009 | Magic Sing Along Consumer Microphone
Change from PAL to NTSC
You need to configure it out.
1. Connect the magic sing in your TV
2. Turn on your TV
3. Magic sing should be Off
4. On your magic sing; Press and Hold "8" then while holding "8" press "power button", count for thre seconds then release both buttons (PAL to NTSC)
or
On your magic sing; Press and Hold "9" then while holding "9" press "power button", count for thre seconds then release both buttons (NTSC to PAL)
Mar 02, 2009 | Magic Sing Along Consumer Microphone
NO BACKGOUND VOCALS
Hi im joe,
Regarding your concern the ET 3000 magic sing does not have background vocals at all. The manufacturer design the magic sing for sing along purposes only but they are now improving there future products to have that feature with background vocals.
Feb 11, 2009 | Magic Sing Along Consumer Microphone
Magic Singalong Song Chips - question please
Not exactly, magic sing comes in different models with different song chip. Old magic sings uses Black with metal song chip, Black song chips, Silver song chips and Gray song chips.
For your Magic sing II (I believed it has four song chips slot) the compatible song chip is the Silver song chip.
Oct 26, 2008 | Magic Sing Along Consumer Microphone
Can't power ON...
See if the microphone connector wiggles. It shouldn't move, but if it does, the legs on the connector can snap inside.
Aug 14, 2008 | Magic Sing Along Consumer Microphone
118 people viewed this question
 Grubhead
Grubhead
