Sony rdr-gx210 only plays cds - Televison & Video
    Sergeant:
    Champion:
  • 331 Answers
Did u check whether the DVD's were ok may be the dvd was corrupted
Posted on Oct 14, 2008
  • Varun Kumar
    Varun Kumar Oct 14, 2008
    also one thing ........
    i got that the dvd mechanism in this model is not of sony....
    and it has a very high faliure rate so u might have to contact sony
    President:
  • 1,952 Answers
What is ur problem
  • 2 more comments
  • mohammed marika thambi
    mohammed marika thambi Oct 14, 2008
    www.askdavetaylor.com/sony_dvd_recorder_dvds_wont_play_elsewhere.html - 34k -
    In order to use the disks on other players the disk must be finalized,
    something that might not be necessary for the Sony player itself.
    Second, most, but not all DVD players will play DVD-R. Look in the
    users manual to see what formats yours will play. .
    If that's the problem, double check whether it can have its firmware
    upgraded
    and then play DVD+-R discs. You could also try
    using DVD+R or DVD+RW disks to see if that makes a difference.
    s he making Video-CD's (VCD) in the transfer process VCDs will only play on certain DVD player equipment.
    Are the disks he is using able to support the recorders write speed
    Using disks that do not support the write speed will cause unreliable
    results. These disks may or may not work on the recorder but will not
    likely work on other devices.
    Will the disks play back in the recorder once finalized if yes and
    it won't play on your player see if you have a friend that can play it
    in their player.
    If all the of the parameters are met, i.e., it's the right right
    speed, format and it is finalized the disk should work in a player that
    supports the format.
    So if it still doesn't work, then you might want to talk with Sony support.
    www.radioandtelly.co.uk/sonyrdrgx210.html - 33k
    use this link..
    http://www.radioandtelly.co.uk/sonyrdrgx210.html
    Discard
    Newest
    Oldest
    Positive
    Negative
    Recommended
    Be the first to Comment!
    Comment Posted, thanks!
    0/500 characters Close
    0/500 characters 0 http://www.radioandtelly.co.uk/sonyrdrgx...
    0
    have ui got clear ur fault
  • 19,396 Answers
When that happens it means you have to clean the lens.
  • Ginko
    Ginko Oct 14, 2008
    The unit only plays CDs because of a lens problem.
    Try claning the lens , first using a lens cleaner, like the ones here.
    If cleaning with a cleaner disk and solution did not work, then you have to clean the lens directly.
    Remove the cover and access the inside of the DVD, unplug power first.
    Use soft cotton sticks and isopropyil alcohol to clean the lens, here is a picture of the lens pickup:
    As usual do the job at your risk, if you want to call for repair you can use the number listed in the owner manual.
    If even direct cleaning does not work, the lens pickup should be replaced,
    after testing that signal from and to lens is OK, but that is a job for
    a technician.
    If you need to call a repairman you can ring the number listed on your owner manual.
When I burn a DVD (R- or R+) on a Sony RDR-GX300 it burns the DVD which plays on that unit only. If I try to play the DVD burned on Sony RDR-GX300 on any other brand or any other Sony DVD player or even on...
On That Type Of DVD Recorder,( RW,R-R+). You Will Have To Finalize The Disk. Finalizing is Necessary When Playing On Any Equipment Other Than This Recorder.Even IF Your Other DVD Equipment IS ( VR ) Format Compatible You Still Need To Finalize The Disk. After Finalizing,You Cannot Edit or Record on The Disk,Make Sure It's In Video Mode.
Aug 11, 2011 | Sony RDR-GX300 DVD Recorder
My Sony RDR-VX530 VCR/DVD player/recorder just stops playing
play a lens cleaner cd in it,,, it will work smoothly
Apr 21, 2010 | Sony RDR-VX530 DVD Recorder/VCR
Cannot play DVD's on different recorder
did you finalize the disc? if you didn't it will not play on other dvd players
Mar 30, 2010 | Sony RDR-VX515 DVD Recorder/VCR
Can't get subtitles to turn off on my Sony RDR-GX330
Push the 'Subtitle' button (It's under the 'Input Select' button right side) on the remote keep pushing it until it gets to Subtitle Off.
Jan 29, 2010 | Sony RDR-GX330
A Sony RDR-GX210 DVD player I can play a CD - no problem but when I try a DVD, the TV screen says - ''loading please wait'' and then it drops back to the TV picture witha message - ''Can't play this disc''...
Hi Allan,
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
In your case the lens does not work on DVD , but only on CDs for the reasons above , that is quite common.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD or Blue ray lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
Sep 08, 2009 | Sony RDR-GX300 DVD Recorder
Sony DVD Recorder
I have a Sony RDR-GX7 That stopped recording & playing DVD's
Feb 17, 2009 | Sony Televison & Video
VHS TO DVD DUB ERROR ON PLAYBACK
Sounds like the DVD is not finalizing or not doing so properly. Check your setup options...
Mar 30, 2008 | Sony RDR-VX555
I have a Sony RDR HX510, can you help me?
Have you finalised the dvd disc in the machine ? you must finalise all dvds before playing them in other machines.
Mar 18, 2007 | Sony DVD-NS530 DVD Player
Televison & Video Logo
266 people viewed this question
Top Televison & Video Experts
Electro Med Services...
