Question about Acer Aspire T650 (AST650UC3601) PC Desktop
Acer Aspire Memory problem
Acer Aspire T650-997Z whit two slots for memory 2X512MB-Nanya NT512T64U88A0BY-37 DDR2 DIMM.After trying to change whit 2X1GB Transcend JM667QLG 240pin DDR2 DIMM my PC ,runing WinXP boot BIOS,but going just to screen when asking me how to start Windows-normaly or in safe mode and after i choose normaly, blink blue screen and follows reboot. I try to run it whit old memory module and it works.Both Transcend moduls are working but only in combination whit the old  one-in the first slot 512MB Nanya and in second slot each of Transcends moduls.I'm wondering why this happening,and how to solve it?
  • Anonymous Nov 06, 2008
    hi,
    i have exactly the same problem with the same system...
    with nanya ram 512 pc2-4300 in slot 1 and 1024 pc2-5300 in slot 2 it works. (the 1024 pc2-5300 ram is specially for my system - aspire t650)
    but with 2 x 1024 pc2-5300 it doesnt...
    in the mainboard discribtion i read the board supports pc2-4300 and 5300
    but only at pc2-4300 it works..
    anybody an idea?
  • 4 Answers
The read speed of your new memory is not compatible with your motherboard. It is a higher rate than allowed. The reason why it works when you have one of your old chips installed is because your PC will automatically drop the higher rate chip down to the one that is working. The reason it does not drop both new chips down to a suitable rate is because it has nothing to guide it like your compatible chip does. Always check the MHz on RAM chips and compare that with the acceptable rates listed on your motherboard specs. The good news is you can probably sell those chips and have money left over when you find upgraded compatible memory that is sure to be cheaper since it is slower.
Posted on Apr 11, 2017
CheeseAvengr
  • 57 Answers
SOURCE: memory installation
Most likely it has to do with your chipset. You might also be trying to run the RAM in dual-channel mode. Some systems are extremely finicky in dual-channel. Next time you boot, try looking in the BIOS to check if dual-channel is enabled or not. If it is, try disabling it and putting the chips back in. You can also go to your motherboard manufacturer's website and check for BIOS updates, as they tend to help with things like this.
Posted on Apr 08, 2008
SOURCE: aspire t180 memory problem
check, if you motherboard support 2GB, or else start windows in safe mode with 2GB.
Posted on Oct 17, 2008
  • 909 Answers
SOURCE: Ram upgrade capability
Simply, yes you can. just open the case and put in the new boards. you can buy higher spec. memory(as long as the pins are the same number)
I.E. ddr-sdram boards will fit and as long as the speed is the same (132.8 Mhz) or higher.
I changed from 133Mhz to 333Mhz and the performance was much improved.
The PC3200 is the important bit, should be the same.
after you change the memory ,try running disc clean up in "start, all programs, accessories, disc clean up" this will also speed things up as well as de-fragmennting your drive(s)
Posted on May 02, 2009
anantakumarj
  • 330 Answers
SOURCE: cannot format c:
if you want to format it you have to reinstall the os . Actually all information of the os is sitting in c drive ... in running time of windows you can't format the c drive .....
To format and reinstall the os get a windows(XP,vista,98) botable cd ...boot from cd ... it will start the setup...... in middle of setup it will ask for the format ......
Posted on Nov 16, 2009
  • 2973 Answers
SOURCE: Problem with my Acer Aspire m1100 E1402A.PC came
Most likely the motherboard does not take more than 1 Gb of RAM. If so then you will have to do with 1 GB only. The new RAM is fine as it works alone.
Posted on Nov 07, 2010
Ram for my pc
Yes.
Why?
Hans Pedersen,
http://www.fixya.com/support/t16340342-ram_required_motherboard
http://www.okmemory.com/Foxconn-N_Motherboard_Series-N15235-D27847-memory.html
It IS DDR2 Sdram ram memory.
Has 240 gold plated contact pins. 120 on EACH side.
Has one Locating Notch on the bottom.
It is DDR2 Sdram that operates at a maximum frequency rate ('Speed') of 400MegaHertz.
[400MHz]
Also known as PC2-3200
It is Non-ECC. Your computer USES Non-Error Correcting Control
http://en.wikipedia.org/wiki/ECC_memory
[Also known as Error Correcting Code ]
NO MATTER WHAT, make sure there is a ram memory module ('Stick') in Slot 1. Also known as DIMM 1.
This is the ram memory slot closest to the Processor. (CPU)
For additional questions suggest posting in a Comment.
Not a new product question.
Regards,
joecoolvette
Feb 03, 2013 | Computers & Internet
Can I upgrade my acer 5315 memory to 2GB with two 1GBs in two slots or I can put two 2GB slots adding up to 4GB? Thanks
You can upgrade it to 2GB (MAX) if icon_detail.gifMemory Type: DDR2 PC2-5300, DDR2 (non-ECC)
Maximum Memory: 2GB
Slots: 2
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.
Hope this helps.
Jun 17, 2011 | Acer Aspire 5315 Notebook
Can I use DDR2 in an Acer Aspire T135?
The e RAM specifications for your Acer are -
Memory - DDR 266/333/400 expandable up to 2GB
Jun 11, 2011 | Acer Computers & Internet
I have recently upgraded my brothers Acer T180 computer with approved crucial 2 x 1GB ram ddr2 PC2-5300 667 NON ECC UNBUFFERED CL5 which was scanned by the crucial website and purchased from them. When the...
Some motherboards are only upgradable to their allotted amount that board may only handle up to 2 gigs of RAM which is a shame. But this is the way it is. That is why I always check the board memory capacity before I buy computer boards or RAM for them. The beeps indicate error on the slots for the RAM that is why you can start up when you remove ram one at a time and replace. So use the allotted amount of RAM for that board specification or get another mother board that can handle more than 2 gigs of RAM. Sorry for the loss. Thanks for using FixYa! John
Apr 13, 2011 | Acer Aspire™ T180 PC Desktop
How many memory slots on a aspire x3200 motherboard
It has 2 slots. The memory type is ddr2 with 240 pins
Details:
Acer Aspire X3200-Quad SpecificationMemory Type:
DDR2
Memory Speed:
PC2-6400
Memory Type:
Non-ECC Non-Registered,
Memory Slot(s):
Max. Memory Per System:
4096MB (4GB)
Max. Memory Per Slot:
2048MB (2GB)
Install Memory in Pairs:
Not Required
Mar 22, 2011 | Computers & Internet
What is the maximum memory I can install
Memory Upgrade for Acer Aspire 5630-6760 Notebook (DDR2-533MHz) Laptop, the Acer Aspire 5630-6760 Notebook (DDR2-533MHz) Laptop takes the Memory Type, and comes installed with 0MB of Memory. You can upgrade your Acer Aspire 5630-6760 Notebook (DDR2-533MHz) Laptop to up to a maximum of 4GB Memory, the system has 2 (2 banks of 1) to install Memory, already with 0MB standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Jul 08, 2010 | Acer Aspire 5630 Notebook
Just bought 2 1GB PNY dual Chanel memory modules for my Computer Make: HP Pavilion 061 Computer Model: RJ181AA-ABA a1600n Currently has Memory: 4 slots: 512 MB, 512 MB, empty, empty QUESTION: which slots...
Start off by putting the first memory module in DIMM slot 0 this is the slot nearest the processor. DIMM slot 1 is the slost after DIMM 0.
Regards.
Jun 28, 2010 | HP Computers & Internet
ACER Aspire AX1200-U1510A: What mother board and socket is in this computer? AM2, AM2+, or AM3
you have given the memory chip number and not the computer model the chips you have are 533 MHZ DDR so I would suggest you click on start go to my computer right click on properties and it will list the chip set. here is a web page you can go to to see the memory you have.
acer-aspire-ax1200-u1510a-tower-desktop-memory-1x-512mb-91ad346008-pc2-4200-ddr2-533mhz-unbuffered-dimm-upgrade.html">http://www.memoryupgrade.pro/512mb-acer-aspire-ax1200-u1510a-tower-desktop-memory-1x-512mb-91ad346008-pc2-4200-ddr2-533mhz-unbuffered-dimm-upgrade.html
Feb 11, 2010 | Acer Computers & Internet
Compatability of Memory Upgrade
One or both of your RAMs have developed a fault. Change both RAM. After changing RAM pl format again and than try. Do not insert those faulty RAM again. Get your RAM tested by a software which is available on Microsoft site for free.
Thanks
Bhaskar
Jun 04, 2008 | Acer Aspire™ T180 PC Desktop
Acer Aspire T650 (AST650UC3601) PC Desktop Logo
201 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
