Question about JVC GR-D20EK Camcorder
Camera wont run on batteries
The unit runs fine on mains adaptor but when on battery only, it fires up with a plain blue screen for a few seconds and then shuts down. I have tried two batteries (one is brand new) and I also have a separate charger.
  • 1 more comment
  • mervt Oct 14, 2008
    I have cleaned the contacts as suggested but no use. The contacts must be OK as the batteries charge in the camera when connected to the mains adaptor.
    I think the symptoms would normally be indicative of a very flat battery.
    mervt
    I would think that the cost of repair would be unjustified on this unit. I think I will return to a Sony unit.
    mervt
    I suppose it was the best you could do under the circumstances. I think that Guru 's suggestion is the nearest to the mark.
    mervt
    Sergeant:
    Champion:
  • 331 Answers
Did u check the type of the batteries...............
they might not be compatible
did it ever work with the batterie u mentioned?/
Posted on Oct 14, 2008
  • 958 Answers
The problem could be the socket where you put the adapter in the camera. it has a switch that opens the battery to supply the camera and the power supply would be the one to supply the power, how ever, when you remove the plug from the adapter, the contacts should close back to connect the battery to supply the camera back.
it is very hard to repair that so i think you have to bring it to a technician.
tnx 4 using fixya,
drcool
  • 81 Answers
Hi.
Seeing your problem i would advice you to get the device checked at a repair shop.
Either there is a problem in the wiring or a component inside has got damaged.
Hope this helps
Regards
Faraz
  • JVC Master
  • 19,396 Answers
Try cleaning the battery contacts inside camera battery socket with isopropyl alcohol, if that does not work, then there is a problem on battery wiring inside camera, the camera must be taken apart at a repair shop to fix this.
  • Ginko
    Ginko Oct 14, 2008
    Ensure that it is not the battery, even if you tried two different batteries go to the shop and have a different one tested, or test your batteries on a similar camera.
    If batteries and contacts are ok, then it is the board that connects to the batteries. This has usually few capacitors, diods and one IC to stabilise voltage to battery, and to stop reverse charging when the battery is full.
    Probably one of those component had blown, on board components must be tested with a multimeter, to find the defective one, de solder it from board, and replace it.
    Unless you have done similar kind of jobs before, you risk to reduce your camera to a bunch of bits and screws if you try doing it yourself.
    I suggest calling the service number printed on the user manual, to get details on service, and eventually ask if you can purchase an extended guaranty.
My acer 5920 wont charge or wont work on ac adaptor but the ac adaptor works fine on my friends laptop
Either the AC port on the back of your laptop has a lose connection - if operation without battery is an issue, or if battery charge only is issue - then battery may have to be reseated or it is at end of life. Test by removing battery and running AC alone. if connection port is bad, laptop will power off immediately/unexpectedly. Good luck! btw - batteries for this unit are around $40 on ebay
Jun 14, 2011 | Acer Aspire 5920-6706 Notebook
My S9600 was left unused [batteries left in camera] for several months. Now it will work fine with the mains adaptor, but is completely dead when on battery power. Have tried new batteries [rechargeable...
Sounds like corrosion on the battery contacts. I have seen battery contacts with a thin, transparent coating that came from leaking rechargeable batteries- doesn't look like the usual green crud, but it stops electricity from getting through. Try giving the contacts a scrape- you will need a long thin screwdriver or something of the sort.
Dec 01, 2010 | Fuji Finepix S9600 Digital Camera
The button is on and the lock 9 is on and flashing and the screen is black. It was working fine. I opened the laptop and my screen is black. The A in the lock is blue and the icon next to it. The power...
Hold the power button for 5 seconds or more - does it turn off properly? If so, can you turn it back on afterwards?
Take out the battery and unplug the power adaptor. Let it sit for a few minutes. Now try the power adaptor alone. If this works, try shutting down and running on battery again.
Apr 18, 2010 | Dell Vostro 1510 Laptop
My toshiba satallite p200-1ee laptop is not charging. Battry life left: 40% When on: The Charging light blinks 3 times every few seconds and the screen dims with it. When off (But pugged into mains): the...
If you plug the charger into the computer without the battery and the laptop runs fine, then I would suggest to you that your battery is failing and will no longer accept the charge. On the other hand if the laptop will not stay running or acts strage and the screen dims and gets bright, then I would suggest to you that the charger's built in voltage regulator is failing and will damage the laptop if it continued to be used. A bad charger will also permenently destroy the battery condition.
Dec 01, 2009 | Computers & Internet
Hello sir,my laptop is acer aspire 7520 no charging,no run on main,run on battry only,laptop power adaptor led is damage,
this could be due to the fault in the ac adapter,please try swapping another adapter if it works then you need to replace your adapter.
Jun 20, 2009 | Acer (ACERMOTHERBOARD)
1991 Fzr 600; been sitting for two weeks, it will crank, but wont fire
sounds like your fuel pump has gone check here 1st to see if its putting fuel out
May 31, 2009 | 1991 Yamaha FZR 600
Battery problem
The little silver battery is a back up to keep the clock etc running when the main battery is removed.
If it runs on the mains adaptor it's probably the battery that has failed.
Jan 11, 2009 | Canon MV700i Mini DV Digital Camcorder
TOSHIBA SATELLITE NOT STARTING.
mine does the same thing and is new. you should be fine with what you have for a while, unless you just want to replace the battery, the battery goes bad after a few years, thats what I have heard anyway.
Mar 16, 2008 | Computers & Internet
Camera wont switch on
hte battery LID has not closed properly.
or u must have kept the auto shut down settings very low.
this can be resolved by resetting the camera.
Have you tried a hard reset on their camera by removing the main power batteries for 60 seconds and the reinserting them as if it were the first time power up. This may not fix your particular problem, but when the processor that runs all of the electronic features of the camera gets confused, this is the best way to clear its confusion.
even if problem is not cleared take it to service centre.
Dec 01, 2007 | Samsung L700 Digital Camera
JVC GR-D20EK Camcorder Logo
79 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
