Question about Whynter FX-6SW Free Standing Hot & Cold Water Dispenser with Storage, Microcomputer-controlled LED D
Problems with Black & Decker #900144 TopLoad Water Dispenser: It is dripping water constantly and the item is only 4 mnths old
  • 958 Answers
You have to open it up and look where the water is dripping from. it could be from the rubber hoses that connects the tank to the faucets.
if it's on the hoses, that would be easy to replace, but sometimes the leak would come from the stainless tank whiich would be very hard to replace.
tnx 4 using fixya,
drcool
Posted on Oct 14, 2008
Why is the water dispenser constantly dripping?
If the water is coming from the water dispenser itself then most likely you have a water valve that bis going bad and it will only get worse.
Jul 13, 2015 | GE Refrigerators
Frigidaire water dispenser drips constantly. I have been told there is a main water valve and a second valve for the water dispenser. Where is it and how to replace?
if you are referring to the cold water on the door , then there is a solenoid valve on the bottom back left side of fridge, you will see two there , one is for ice maker and one is for water on door , most times it's a good idea to replace both of them , also there should be a filter inside fridge on bottom middle (cartridge) this should be changed monthly to maintain fresh taste and keep foreign objects out of tubes
Jun 01, 2015 | Frigidaire Refrigerators
Water dispenser drips after use but doesn't shut off completely and drips constantly.
Most likely the water inlet regulator (water valve) is faulty (like a leaky faucet) need to replace the water valve.
Jan 30, 2014 | Samsung RF26XAERS
Inside water dispenser pumps water out really slowly on GE Profile PFS22MISBBB
It is possible that your water filters are getting plugged. Have you changed any filters lately?
The meat pan lever may also be turned to the coldest position and on units that have a low water usage, this will also cause the tank to freeze. You will want to lower the meat drawer setting or use more water from the door. This does not apply to Top Mount water dispenser models, because they do not have a reservoir. Problem requiring service, glass fill time.
View a short video about troubleshooting water dispenser issues :
Play Video
View a short video about slow water dispensing issues:
Play Video
  • Dispenser drips water constantly will be a water valve problem, and should be checked by a service technician. If you would like to schedule a service appointment, please contact GE Consumer Service at 1-800-432-2737 or schedule a service appointment on-line.
  • Dribble as defined as a small amount of water (few drops) that may miss the glass ONLY AFTER USAGE. This is due to a delay in the overall system.
    Dribble can be minimized by the following actions:
    - Purge the tank, by holding down the dispenser for 2 to 3 minutes, to remove any trapped air that may be building pressure and causing the dribble.
    - A few drops is normal, but you can also prevent water from missing the glass and dripping down the cradle area by moving glass slower when removing it from the cradle.
    - You may need to periodically empty the recess grill and clean out underneath it to prevent overfilling and water dripping down the front of the refrigerator.
  • Also, remember the dispenser in the door will not operate unless the door is closed
  • Apr 10, 2012 | GE Refrigerators
    The freezer door leaks water from the water/ice dispenser. The dispenser fills up with water. Items in the freezer door almost seem as if they never freeze. All items in the door are much less frozen...
    Leaky dispenser-------
    Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
    Sep 09, 2011 | KitchenAid KSCS25FKSS Side by Side...
    Just want the cold water - Black and Decker 900144
    I need to do the same thing. Please let me know if you were able to get this done. It would help me out alot. Thanks you.
    May 03, 2010 | Whynter FX-6SW Free Standing Hot & Cold...
    Outside ice despenser is dripping, no ice
    water dispenser -Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
    ice maker - If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
    If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
    Sep 30, 2009 | Amana 22.6 cu. ft. Side-By-Side...
    Drips at water dispenser GE PSC23MGSA BB
    If it's a constant drip then you need a new water valve.
    Jan 03, 2009 | GE Profile Energy Star PSC25MGS Side by...
    The water dispenser is constantly dripping
    hello; your water valve is bad, it;s a dual valve located in the back where the water line comes in to the unit. this is a non-serviceable item and must ne replaced. you can do it yourself, just order the part from your local appliance parts store,(you'll need model, and brand name when ordering.)
    Apr 03, 2008 | Refrigerators
    Whirlpool side-by-side refrigerator - 2 problems
    I would suggest that you get a certified person to come out and look at it you very well could have bent the doors in the move.
    but... if you want to do it yourself.
    click here for a walkthrough
    for your drip:
    Flush air from the water system the first time it is used and after replacing the filter. Air trapped in the water line or filter may slowly travel through the coiled water reservoir to the dispenser, pushing any water ahead of it. This can cause the dispenser to drip. Water needs to completely fill the lines for all air to be cleared.
    • Use a sturdy container to press and hold the water dispenser bar for 5 seconds, then release it for 5 seconds. Repeat until the water begins to flow. Once the water begins to flow, continue pressing and releasing the dispenser bar (5 seconds on, 5 seconds off) for an additional 2 minutes. Repeat if dripping starts again because air can re-enter from the water supply.
    • As air is cleared from the system, water may spurt from the water dispenser.
    • Make sure the refrigerator is connected to a cold water supply.
    One or two drops of water immediately after dispensing is normal. It may be necessary to hold the container under the dispenser for 2 to 3 seconds after releasing the dispenser lever.
    Jan 26, 2008 | Refrigerators
    Whynter FX-6SW Free Standing Hot & Cold Water Dispenser with Storage, Microcomputer-controlled LED D Logo
    1,293 people viewed this question
    Top Whynter Water Filters & Coolers Experts
    Tom Chichester
    Are you a Whynter Water Filter and Cooler Expert? Answer questions, earn points and help others
