Can power up computer, but hard drive do'snt start
    Genius:
  • 1,250 Answers
Check the power connector and bus connections of the hard drive, also check on the bios whether its detecting or not
like it or not please do rate
Posted on Oct 14, 2008
Imation 1TB USB external Hard Drive .....unrecognized in Windows Both in windows7 and XP.
External hard drives are plug-and-play devices used to store music, video and data files. Once the drive is connected, the computer checks its systems for the appropriate drivers, loads them, and the external drive is ready to use. If the computer does not recognize the external drive, plug it into another computer to ensure the drive is not corrupted. If the drive is good, a few simple steps should help re-enable the drive for use.
Switch the power button to "off." Disconnect the power cord from any extension cords or power strip, then re-seat the power cord into the hard drive. Connect the cord directly into an outlet and power up the drive. If the drive is powered and still not working, check the data cable. Power down the hard drive and disconnect the data cable from the computer. Wait 30 seconds to one minute. Reconnect the data cable and power up the drive. If the drive is not detected, power down the hard drive and connect the cable to a different port. Power up the drive. If the drive is detected but not working, check for a missing driver. Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Select "Device Manager" and double-click "Disk Drives." Right-click the yellow exclamation point and install the missing driver. Close the Device Manager. If the drive is detected but not working check to ensure it has an assigned drive letter. Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer. Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Click on "Disk Management," right-click the external hard drive, click "change drive letter and path," and click "Add." Assign a drive letter. Avoid using A, B or C (C is usually assigned to the computer's internal hard drive). Click "OK" close the window. If the drive is detected but not working, check whether the drive is in sleep mode. Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer. Click the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Select "Device Manager" and double-click "Universal Serial Bus Controllers." Double-click the first instance of "USB Root Hub" or "Root Hub." Check for the hard drive. If the drive is not visible, move to the next instance of "USB Root Hub." Continue checking each instance until the hard drive is located. Once located, click the "Power Management" tab and uncheck the "Allow computer to turn off this device to save power" box, click "OK," then close the Device Manager. Power the computer down, wait 30 seconds to one minute, and power the computer back up to ensure the drive is detected. Hope this helps.
Jan 07, 2013 | Imation 1TB Cartridge (IMN27957) Hard...
HOW DO I KNOW THAT MY HARD DRIVE IS CONNECTED
b>
Dec 21, 2012 | Buffalo Technology (HD-PE320U2/WH) 320 GB...
How do I reboot a Sony SNT-V704?
Reset your SNT-V704:
Open it up and press the reset button on the main PCB 5 times while it is on. You can find the reset switch lower right corner when the front facia faces the ground. This worked for me.
I know this is an old question but I haven't found this solution on the net so let me know if it helps anyone.
Feb 25, 2011 | Sony SNT-V704 (SNTV704) Video Server
I want to install gprs settings in nokia 5230 model please give the procedure
If ua usng aircl service,snt a msg to them.hea s wat u hv to snt.."ALL" n snt it to 121..ua intrnt settings wl b delivrd 2 u
Jan 27, 2011 | Nokia 5230 Cell Phone
Its not a problem to begin? I just want to buy 1 rack like for a SATA III 6 gbps Hard Drive. Will it affect the Hard Drive Speed, reducing it to 3gbps? Or is it just a Rack to support the Hard Drive...
As long as the connector and build quality is good, a rack should work fine.
If the connectors are shoddy, or the fit of the connectors isn't good, then you will have speed issues, or even outright failures.
Aug 29, 2010 | Mobile Rack SNT-125 SATA Plastic for...
My portable harddisk snt working anymore after it fell hard
Sounds like it's hooped. Only way to recover data is to try to take it to a data recovery lab.... which can be pricey.
Sep 26, 2009 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
I need to add more hard drives to my poweredge 2600
You'll probably need to get caddies for the drives. You can get them from Dell by plugging in your service tag at http://support.dell.com.
Jan 12, 2009 | Dell PowerEdge 2600 Server
Adding DVD to Poweredge 2600
PE2600 has lots of spare power (unless you are already using all 6 SCSI drive bays) ..
You can fit 3 x SATA drives in the space where the (useless) tape backup unit is sitting [you can even buy a 'proper' enclosure = Icy Dock MB453SPF or I think the SNT-2131 will fit ] .. and you can split the power off the Tape drive (4pin) power socket ..
I've not found a DVD burner (only a combined DVD reader / CD burner = TS-L462C) .. however if you have a spare IDE port you should be able to use an external unit [you will need an e-ide cable & enclosure for the drive]
Dec 11, 2008 | Dell PowerEdge 2600 Server
Sony SNT-V704
If your unit keeps crashing this could be a sign of over heating. There is a way to test if it is an overheating issue and that is as the unit is playing use a hot air gun to raise the temperature and trigger the problem once the bad component is found replace it.
Sep 12, 2007 | Sony SNT-V704 (SNTV704) Video Server
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
