I have 2 drives C:\ and D:\ Im trying to reinstall my windows but my c drive would not allow me to do so. Instead I could only do so on D:\ Now I have three options during bootup: c:\Windows, D:\Windows and Set up Windows Xp Now, I have installed windows on my D:\ drive, I would wish to format my C:\ However I am unable to do so because the system says there are setup files on C:\ so Its not possible. Please help. I want to reformat my C:\
    Sergeant:
  • 306 Answers
Assuming that XP is what you are installing first boot from the cd. You can do this by pressing F12 at boot for a one time boot option or enter setup -F2, F1, Delete, F10 (depends on which computer you have). Once you make the cd drive first boot watch the screen for the 'press any key to boot from cd'. When you have bootstrapped to the cd Windows will have several actions to choose from. Select Install.
The next question will be whether to install a fresh copy, repair or exit.
Install a fresh copy. Windows will display a list of partitions. Select C drive. Then it will tell you that you have setup files there and you should continue (the first time you did this you were still using the hard drive -not the cd). Choose the option to delete the partition. That done choose C drive to install Windows on the empty partition. Format options appear. I would choose the full NTFS format. After formatting and setup files are loaded a reboot will be performed. Do NOT boot from the cd at this point or you will be in an endless loop! Either ignore the 'boot from cd' prompt or at setup choose the hard drive for first boot -the setup files are now there so boot from c drive. Windows will now install normally with the product key thing and all setup configuration settings. Again or twice again boot from C drive. After all is done you will find D drive still there with a Windows installation. Now you can drag wharever you desire to retain into the new C drive installatio and use D drive to also provide any hardware drivers that the new Windows on C drive cannot find. Then you can delete or format D drive and keep it as a separate partition or 'grow' your C drive partition with the empty partition by going to Run>type msc>computer management and peruse the console displayed to manage your disk drive partitions.
Posted on Oct 14, 2008
    Genius:
  • 1,250 Answers
Actually YOUR boot.ini file is in the c drive and also its your active partition.
so for formatting the drive c, you have to boot your cd from bootable xp cd, for this go to the bios of your pc and select first booting device cd, save it and exit.
when it boots it will ask for press any key to boot from cd, press any key.
the file loading process will start
Keep your eye on the screen messages for booting to your cd Typically, it will be “Press any key to boot from cd”
Once you get in, the first screen will indicate that Setup is inspecting your system and loading files
When you get to the Welcome to Setup screen, press ENTER to Setup Windows now
The Licensing Agreement comes next - Press F8 to accept it.
in the next screen it will show the previous version of window installation press esc key , the in the next screen it will ask for the drive where you want to install the xp select c drive and press enter, the in the next screen select format option and press enter
please do follows the instruction that comes on screen
for formatting the other partition open the my computer after the installation select the drive rigth click on it , select format
like it or not please do rate
  • 103 Answers
Hello Hugimouse
How about trying this out. When you insert your XP installation CD. Do as though your are going to install Windows again until you come to the part where you can see all your partitions. Then Just click on it and say delete. Then just before the installation begins i.e after deleting the partition force shut down your PC. Restart and Log onto D drive. From there it should be easy to do the formatting.
Good Luck
Regards
Genius guy
  • 81 Answers
Hi.
Insert the xp CD in the drive.
Where it asks you to choose a location to install xp, just delete both the partition. (default button D)
Then make two fresh partition and install xp in the first one (that is C).
This will solve your problem.
Regards
Faraz
My hp pavillion dvd drive just hangs up when I try to reinstall windows
Is the disk your using homemade or a factory made disk? Some drives just won't read 100% of the disks inserted into them. Have you tried another installation disk to see if the problem persisits? Are you able to "SEE" the files on the disk using Windows Explorer? Can you copy those files to your hard drive? If yes, then try installing from the hard drive files instead of the disk. What OS are you trying to install?
Apr 08, 2014 | Pioneer DVR-107D DVD±RW Burner
Bios password
On most Panasonic Toughbook models, when you turn on the power and immediately press the "Esc" key, then a new startup menu will be shown.
Simply choose "CD-ROM Drive" as the boot device and make sure that you have previously inserted a CD-ROM in the drive and then the Panasonic Toughbook should startup or "boot" from the cdrom
instead of from the internal hard disk drive.
I have attached a photo
Good Luck and Regards from:
Richard, Montreal Based Panasonic Canada Authorized Toughbook Dealer since 1989
Jun 17, 2012 | Panasonic Toughbook CF-29 Notebook
Hi im trying to install windows 7 on my aspire 4715z, as im starting to start the instalation when an error appear "a required cd/dvd drive device is missing. if you have a driver floppy disk, cd,...
Hi there !
Your windows operating dvd installer is damage. It just the CD/DVDROM drive cannot read your DVD installer because it have too many scatches in your DVD. Just get new OS dvd installer and repair your windows 7 operating system or reinstall the operating system.
Jan 26, 2011 | Computers & Internet
I have a Toshiba A45-S121 laptop. I upgraded my hard drive from a 40GB hard drive to a 320GB Western Digital. Loaded Windows XP and formated drive in FPTS format. The computer rebooted to the hard drive...
Best possible solution put back your 40GB and try to get an external casing for your 320GB to see if it works.And try windows on NTFS instead of FPTS, so reformat your 320GB and install the Windows XP again.
I hope this solution is helpful.
Sep 26, 2010 | Toshiba Satellite A45-S121 Notebook
I have tried everything Ctrl F11, Ctrl F9, Ctrl F8 and nothing allows me to reset the harddrive
Im not sure that you understood the concept of resetting the hdd...this can be done only by formatting ...and from the windows you can not format but the partitions(drives) that not contain the windows installation ...to be able to format all partitions you have to use a installation cd with the operation system ( a boot-able one ) ..and boot from cd ...by selecting this operation from Bios settings ...and go along with the clean installation not from the recovery partition or cd ...
after you get along with the clean installation and formatted the hdd and remake the partitions ...and finished the installation of the operating system ...than you can use the recovery cd to install the drivers and the factory settings and programs .....
another easy way to do that ..is to hook it on another computer ...and just format it from windows...this will erase it clean ..and you will have to reinstall the OS after that ...
Feb 27, 2010 | Dell OptiPlex GX150 SF PC Desktop
I had to restart my IBM Laptop by shutting down the power manually.now it will not re-start windows even in Safe mode.im getting a ECC Error sectors 53072284 - 53072411 Hard Disk Drive any help would be...
Sounds like a corrupted or damaged hard drive, if u can get to dos instead of safe mode try running one of these to commands to do a hard drive sector check and repair:
chkntfs - dos hard drive check
scandisk - windows hard drive check
Even if these fix the hard drive problem depending on what sector was damaged u may still need to reinstall windows though
Mar 29, 2009 | IBM ThinkPad R40 2722 Notebook
Space on device.
If this problem occurs then your ML648B needs to be formatted.
1. Connect your ML648B to your computer with Windows XP or later.
2. By default your computer will recognize ML648B as GPX MTP Device. Press the POWER button from top of your ML648B, to change it to USB mode connection. You will also see USB on the screen of ML648B.
3. ML648B will now mount 2 drives, one as Tools (as CD-Drive) and second as Removable Disk (Drive) – under My Computer on your Windows Desktop.
4. Right click your mouse and then select the Format option. When the Format Removable Disk window appears select the Start button to start formatting your MP3 player.
-Tha Mp3 Doctor
Feb 10, 2009 | GPX ML648B MP3 Player
I downloaded a copy of windows vista and it expired,im trying to reinstall my hp windows xp recovery cd and its asking me for a password,cant remember if i ever did set up a password for this pc.how can...
At what point is it asking for a password? Has the computer formatted the hard drive yet? It sounds like you might be going in to Recovery Console instead of installing a fresh copy of Windows.
What you want to do is press Enter at the first screen, agree to the license, and then format your hard drive. After that, it will go through the installation without asking for a password. Remember - you'll lose all your data when you format.
Jan 23, 2009 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
Medium changer did not show
Check that the unit is set to random mode instead of sequential mode
(FYI Sequential mode treats the whole machine as a single big tape, while random lets the software say what tape is going to be used.)
Aug 07, 2008 | Quantum ValueLoader SDLT 320 Super DLT...
Windows startup error
I lost my password on windows xp, how can I get back on the administrator screen instead of guest screen.
Feb 17, 2008 | Computers & Internet
Computers & Internet Logo
95 people viewed this question
David Payne
David Payne
