Question about Canon MP970 Photo All-In-One InkJet Printer
Scanner suddenly disappeared from the Applications folders.
My MP970 All In One is connected to my Macintosh computer, version 10.5.2. The printer works fine, as does the copier. The scanner however disappeared from the list of Applications in the hard drive, and there is no way to open it that I've found.
  • Canon Master
  • 19,396 Answers
First unplug scanner, turn off mac, remove mac battery and unplug adapter, plug everything back , restart and reconnect.
If that did not work, then do the following:
Unplug scanner usb and reinstall scanner/printer software again on your MAC.
Posted on Oct 14, 2008
How do you change the ink cartridge on a pixma mp970
Simply lift scanner bed and watch the cartridge carriage centralise for easy removal.
Mar 30, 2010 | Apple MFC Canon Pixma MP970 Drucker...
How do I enlarge text on my ESP 5 Kodak Printer using a Mac?
  1. Open the Macintosh hard drive icon in the top right corner of your computer screen, double-click on the Applications folder, and then double-click on the Utilities folder. Find the Printer Setup Utility.
Jan 02, 2010 | Kodak ESP 5 Printer
PSC 2175 wont work with print server
Please make sure that the printer is working okay if directlysd connected to the MAC computer. You may try this as well. hope this helps
Description
LPR (line printer remote) is a platform independent printing protocol that is associate with TCP/IP. It works by using LPR client software that communicates to a server running LPR services.
In terms of PSU, LPR printing will become the basis for all network printing while Novell print queues are phased out. Therefore, all Macintosh, Windows, and Unix computers will be configured to print through LPR.
Requirements
· The name of LPR print queue. This can be found by searching the LPR printer database.
· LaserWriter print drivers version 8.5.1 or newer
· The Macintosh must have a working TCP/IP networking configuration. (If the Mac can browse the web then it's working.)
· a server running LPR services or a printer that supports LPR printing. Most HP LaserJet printers support LPR. However, only the following LaserWriters support LPR printing:
- LaserWriter 8500
- LaserWriter 16/600 PS
- LaserWriter 12/640 PS
- Color LaserWriter 12/600 PS
- Color LaserWriter 12/660 PS Procedure
1.Open up the Applications folder from the OS X menu.
2.Open up the Utilities folder
3.Now open up the Print Center
4.If you have no printers installed you will see the following screen. Click on Add.
5.On the following screen, select LPR printing.
6.Now enter printhost.oit.pdx.edu for the LPR Printer's address.
7.Uncheck Use Default Queue on Server option and enter the queue name of the printer.
8.Select the printer model.
9.The completed settings should be similar to the following:
(LPR Printer’s address is the ip of our PRINTSERVER)
10.Click on Add
11.Your printer has successfully been installed. Test the printer by printing something to it.
Mar 29, 2009 | HP PSC 2175 All-In-One InkJet Printer
New multi-function Canon Pixma 310--scanner not working
Step1 Make sure the Mac computer is on, and close all programs. Locate your hard drive icon on the desktop. Generic, non-personalized systems will simply say "Macintosh HD" by the icon; however, if the user or owner has personalized their Mac's space, it may have a different name. Regardless, the icon looks the same: it appears as a small, silver metal rectangle that resembles a piece of computer hardware. Step2 Click on the "Applications" folder once you're viewing the contents of the Mac's hard drive. The Applications folder holds all programs that have been installed on the machine. Step3 Scan the list of available applications to see find the one(s) you seek to uninstall. There are two ways to uninstall the program once you've located it. One option is clicking while holding the Ctrl key once to select the file, a small menu will pop up. Select "Move to Trash". A second option is to locate the file in the Applications folder, select it, and drag it to the Trash on the desktop. Step4 Ensure that you've removed all files associated with the program, in case they all weren't located in the Applications folder. Use Ctrl + F and use the appropriate keywords to search the name of the program. Any findings will disclose the location of the associated files. Located each file in the designated folder, and delete. Step5 Know that you can also install and uninstall programs on a Mac using an actual program called an installer. Recommendations for the best such program, including directions for installing and uninstalling, can be found online.
If that doesn't work, please let me know and will further pursue your issue.
Jan 09, 2009 | Canon PIXMA MX310 All-In-One Printer
Scanner not found
Macintosh: Scanning Software Does Not Open or Stops Responding in Mac OS X V10.4
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01396146&lc=en&dlc=en&cc=us&product=1138342&rule=15414&lang=en
The link will take you to the HP page where the handle for this problem is detailed. I did every step as listed and downloaded updated driver / software for the 4315. It works!
Aug 04, 2008 | HP OfficeJet 4315 All-In-One InkJet...
SCAN STOPS MIDWAY
Are you getting an error/ red light on the scanner button when its on? when scanning from Paint ( File, then from scanners and cameras) does it freeze as well? or only when using epson scan? make sure cable is directly connected from the scanner to your computer, no hubs or anything.. keep me posted.
Have a nice day!!
Jun 12, 2008 | Epson Perfection 4990 Flatbed Scanner
Driver don´t work (MacOSX Leopard
Here are the steps that you need to take to fix your issue:
1. Uninstall the current Wacom driver via the Macintosh HD on your desktop--->go into the Applications folder and then the Pen Tablet folder and click on "remove tablet". Once you have done the removal you will want to run a "repair disk permissions on your Macintosh HD.
2. The repair disk permissions can be done via the utilities folder on your Mac HD. Go to "disk utility" and then run it. In that program select the Mac HD and choose "repair disk permissions".
3. After that is completed you will get a message that says permissions repair complete!
At this time you will want to reboot your computer.
4. After rebooting you will want to go and install the latest driver from Wacom's website, www.wacom.com The most current driver is 5.08-2 for the Graphire 3 tablet.
That should do it!
Paul
May 02, 2008 | Wacom Graphire4 Digital Pen
What do i do
If images cannot be downloaded from the camera to a Macintosh, check the status of the camera and the Macintosh and resolve the problem accordingly.
1) Check the status of the camera and Macintosh.
1. Connect your camera to the Macintosh and turn the camera on.
2. Open the "Applications" folder on the Macintosh HD.
3. Double-click "Image Capture".
* If the "Imaging device not connected" message appears, follow the steps described in [Checking the connection between the camera and PC].
4. Select "Preferences" from the "Image Capture" menu.
5. The procedure for using the Image Capture Preferences window differs depending on the OS version used. Use the correct procedure for your version of Mac OS.
- Mac OS 10.4: Click "General" in the Image Capture Preferences window.
- Mac OS 10.3: Click "Camera" in the Image Capture Preferences window.
- Mac OS 10.2: Simply proceed to the next step.
6. In "Items launched at camera connection", select "FPVBridge" and then click the [OK] button.
* If FPVBridge is not among the displayed items, follow the steps in [Displaying FPVBridge] below.
7. Quit "Image Capture".
If you implement the above procedure up to step 6, FinePix Viewer launches automatically.
* To stop FinePix Viewer from launching automatically, follow the steps in [FinePix Viewer Setup] below.
2) Resolving the problem
1. Plug the USB cable into the camera and Macintosh again.
* If you are using a USB hub, do not connect the camera to the Macintosh via the hub.
1. Select "Other".
2. Click the "Applications" folder.
3. Click the "FinePix Viewer" folder.
4. Select "FPVBridge" and click "Open".
5. Click [OK].
1. Launch FinePix Viewer.
2. Select "Automatic Save Settings" in the Settings menu.
3. Tick the "Auto save images when the camera is connected" checkbox in "Operation Settings When Camera Is Connected".
4. Click [OK] and close the "Automatic Save Settings" window.
5. Exit FinePix Viewer.
6. Turn the camera off and then on again to test whether FinePix Viewer launches automatically.
Apr 28, 2008 | Fuji FinePix S5700 Digital Camera
Canon MP970 Photo All-In-One InkJet Printer Logo
old marine
old marine
