Question about Bosch Refrigerators
Frig freezer bosch kgv3120gb/01 with the thermostat set at no 5 the temperature in the freezer compartment is only minus 5
  • 750 Answers
Hello button7
Welcome,
How old is your unit?
  1. Check if your freezer is packed so full that you have articles covering the air vents found in the rear of most freezers.
  2. This would restrict the cold air from circulating between the freezer and fridge compartments ,thus inconsistent temperatures may arise!
In today's refrigerator / freezers they share the air in a circulation process.
Or you may have this problem
Low refrigerant change
If the unit has a low refrigerant change, the freezer will not reach proper temperatures. This must be checked by a qualified technician due to EPA regulations.
Let me know how you do!
Thank You for using our site,
Huuum
Please remember to leave a rating!
Posted on Oct 14, 2008
  • Neil Golan
    Neil Golan Oct 14, 2008
    Here is a common solution for this problem too!
    If the freezer compartment is no longer reaching the selected temperature
    The freezer compartment door was open too long.
    The evaporator (refrigeration generator) is covered in such a thick layer of ice that
    the fully automatic defrosting system is no longer able to defrost this amount of ice.
    Solution
    take frozen food out of appliance, insulate thoroughly and place in cool location.
    In approximately 12 hours the ice in the refrigeration system has thawed.
    Switch on the appliance again and put back the frozen food.
    Note!
    To prevent loss of refrigeration, do not open the refrigerator compartment door unnecessarily often.
    If fault can not be rectified by these means, please call customer service.
Is there a recall on Kenmore coldspot model# 10671192100 mfg date 01/02? it doesn't keep food in the frig cold.
Check out the self defrosting mechanism on unit. could have a bad defrost timer and/or defrost element. Also check the damper control that sends cold air from freezer into the refrigerator compartment. If set too low your refrig will be warmer. Also check the thermostat setting and operation.
Jun 21, 2016 | Kenmore Refrigerators
GE PROFILE PSW26SGRB SS
If your frig is freezing the food in the chilling compartment as well as the freezer, it means one thing--its thermostat isn't shutting down the compressor when the set temperature has been met. You stated that you had it checked by, I assume, a professional service technician. Being a retired tech myself, I'm surprised that he didn't check this out and discuss it with you. Check the temperature in the freezer! If it is less than 10 degrees F., turn the thermostat to "warmer". If the temp in the freezer is 10 degrees F., leave it alone and go to the temp control in the frig, which is a damper that controls cold air flow from the freezer compartment. Close this damper until your temperature in the upper part of the refrigerator is 38 to 40 degrees F. If these efforts don't shut down the compressor and correct your problem, then the answer is simple. Your thermostat is bad and needs to be replaced. It isn't expensive, and should cost you less than the labor for a tech to install it. Good luck!
Oct 12, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE S-Series Side-by-side refrigerator
you ll change the temperature control unit,since its not performing optimally
.thanks and godbless
Sep 29, 2008 | Refrigerators
My Frigidaire refrigerator is at 60 degrees Fahrenheit and will not cool down
There are a few possibilities. First, Is the freezer portion working okay? If yes, then the problem is blocked air flow from the freezer to the frig. If no, then the cooling fan could be bad or the thermostat could be bad. First check for temperature in Freezer section, should be about 4-8 degrees no more. If it is cold, then locate the cooling fan behind the back of the frig and see if it is moving or listen for movement. If it is moving then rearrange the food in your freezer compartment.and frig compartment away from the vents. If it is not moving, then the thermocouple could be bad. compressor problems and freon leaks are not that common unless the frig has been moved alot. The cooling fan or thermocouple or overstuffed freezer compartment are the usual suspects in 90 % of cooling problems. cooling fans and thermocouples can be cleaned by using canned compressed air to remove dust which will sometimes cause a failure. The parts are inexpensive but labor is about $80. Start with the freezer because all of the cooling for the whole unit starts in the freezer.
Dec 18, 2010 | Frigidaire Refrigerators
Freezer extremly cold, some frost on items. The fridge is also too cold, freezing food in the bottom crisper bin. Kenmore Elite side by side model # 5320902. We have the temperatures set higher to...
The compressor is cycled on/off by the fresh food temperature setting. The freezer setting controls a panel, or door if you will, that allows cold air to be blown into the freezer.
Since both compartments are getting too cold, the most likely culprit is the fresh food thermostat control, since it controls the compressor cycle. Try setting it to a higher setting, even if it's above normal. Use a manual thermometer to check the temperature of the fresh food compartment and compare it to the control setting. The readings should be the same or very nearly the same.
I assume your refrigerator is controlled by a solid state controller (i.e. a printed circuit board). Some of these allow for calibration of the thermostat to coincide with the actual temperature of the fresh food compartment. That would most likely have to be done by a service technician unless you have expertise in the field.
If calibration is not an option, if you can live with the thermostat setting not reflecting the actual temperature, a free fix is to simply set it higher than you actually want it to be, recognizing that the actual temperature is 'X' degrees lower than the thermostat setting.
The freezer compartment temperature will be similarly affected, and can be controlled by the freezer temp setting, which is actually nothing more than setting the position of the panel which allows or restricts air from being blown into the fresh food compartment from the freezer. Again, the compressor is cycled on and off by the thermostat in the FRESH FOOD compartment which gets its cold air from the freezer compartment.
Aug 29, 2009 | Refrigerators
Set tempature on minus 5 unit doen't shot down runs all the time.
It sounds to me very likely that your thermostat isn't functioning properly. change the settings and wait to see if it responds. If the thermostat is working it should shut down the compressor when you increase (rise) the temperature and aversly start it when you drop the temperature. Always let the unit sit for 3 minutes for the pressure inside to equalize before restarting. Good Luck
Nov 19, 2008 | Turbo Air 49 cu. ft. / 1388 liter...
Sub-Zero temperture fluctuation
Just posted this elsewhere and it sounds like the same problem:
As you probably know, the recommended temperature range is between 35-45 F so if your control will not allow you to set this, the sensor or associated regulator has failed.
This seems to be an issue with Sub-Zero.
Aug 02, 2008 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
305 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
