Question about Refrigerators
My FFa70 hotpoint freezer will not close unless i take out all the drawers. What is the problem?
The same thing happened to my Hotpoint FFA70.
A huge block of ice has built up behind the back panel. This has made the back panel expand, thus making the drawers jut out too far. Like me, you may not think ice build up is the cause, since you cannot see any ice.
Action: Defrost freezer. Yes, I know its frost free, but wait an see! Take out al drawers, empty fridge and freezer and defrost overnight with doors open. The next morning, unscrew the back panel of the freezer. You will see 4 screws, 2 at the top, 2 at the bottom. These are not normal screws and are in an awkward postion at the top. Use pliers to grip and unscrew. Slide the panel forward and out. There! A massive block of ice! YOu will also see a hole at the bottom. SO that this didn't get blocked with all the water, I plugged the hole up using a ball of tissue wrapped in some plastic from a plastic bag (clingfilm would also do the trick). Use a hairdryer to melt the ice. Do not chip away at the ice as this might do damage. It took mine about 20 minutes to melt until a large block could be safely removed. Once you have dried the inside, unblock hole and screw panel back on. The drawers should now fit and the door close. I found I still needed to give my door a little help with closing it, but it did close and seal fully. All you have to do now is turn the fridgefreezer back on.
Hope this helps :)
Posted on Oct 01, 2009
  • 750 Answers
Hellow ajprow
Welcome
a.How old is the freezer?
b.Did someone give it to you ?
c.Are they the original drawers that came with the freezer when it was new.
d.Is there Ice build up inside the freezer behind the drawers!
Here are some things to look for.
1.You may have ice build up stopping the door clearance that keeps the door from closing.
It has to be a visual thing that only you can see on sight!!
2.If you said, only that the door will not close then it would be a bad door hinge or even a latch if the freezer was very old.
3.Today they have no latches.
4.If you need to remove the drawers to close the door.
You must have some articles inside restricting the drawers from sliding closed all the way.
And restricting the door closure!!!
5.OR there is ice some where blocking it.
6.Ask someone to look at it together with you!
Two heads are better than one for all of us l.
I'm sure that with these suggestions you will now, be able to see and figure out the reason that the door was stuck open!
If you have any more questions , please send them to me.
Waiting your response and to hear you have succeeded.
Huuum
Please remember to leave a rating!
Posted on Oct 14, 2008
  • 958 Answers
There is something wrong with the drawers position. they could have been installed in the reverse position or they could have been in the wrong placement. one could be on top while the other could be at the middle.
try putting the drawers one by one and check each time if the door could be close by then.
tnx 4 using fixya,
drcool
Diverter valve on Hotpoint FFA70 recieves no power, Fridge ok
Bonjour..Your system check (hot cold) is correct. Generally all new refrig/freezers cool only the freezer & bleed cold air off to cool the refrigerator. Most diverter/airflow dampers I have seen are mechanically operated for simplicity & to keep costs down. I would unload freezer and pull the panel off where you see the fan mounted. Go slow, don't drop any screws.You may not get them back. Look at the drain pan under the evap. coil. If it has ice that is built up in layers. Suspect the defrost termination thermostat. If the evap coil is clogged with heavy frost, suspect 1 the defrost timer and 2 the defrost heaters mounted on the evap. coil. Let me know how you make out.
Parts http://www.repairclinic.com/Refrigerator-Parts?s=t-Hotpoint+FFA70-%3d%3da4&z=50
Jul 02, 2012 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint AAf70 how do I turn the auto defrost off
There is no way to do this, the machine requires the defrost timer to function. I don't really understand what the problem your having is.
Jun 06, 2012 | Hotpoint FFA70 Bottom Freezer Refrigerator
Problem with fridge light on Hotpoint FFA70
Did you check the new lamp when you put it in? Did you keep the old lamp? It may well be the switch rather than the lamp itself. Check the lamp has continuity from the middle pin to the outer and the filament isn't broken
May 10, 2012 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hi my freezer door on FFA70 Hotpoint isn't closing. I have taken the draws out and defrosted it. The door closes when none of the draws are in, but doesn't when the draws are placed in their...
Hi, I had exactly the same problem and eventually realised that the panel at the back of the freezer was coming loose. When I removed it I found that all the parts behind the panel were covered in ice, a lot of ice! So I have defrosted this ice using bowls of steaming water (not sure if this is an appropriate way to defrost, but it worked fine for me), I have also read you can use a hair dryer to spead up the process - apparently if you try and chip the ice off it can damage the parts in your freezer. I have now fixed the panel back on the freezer and it is working like new and I have had this fridge freezer for years now.
Aug 02, 2011 | Hotpoint FFA70 Bottom Freezer Refrigerator
My Hotpoint FFa70 - Fridge acting like a freezer!! Freezer ok!!!!
Check your settings. Each compartment has its own and lower settings to at least the half way point from highest.
Jul 02, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint FFA70 - Freezer door will not close properly.
The rear panel can be removed,i have done it.I removed the 4 hex head screws from the top & bottom of the panel,and firmly pulled it forward.The reason i say pulled firmly is that when panel came out the back of the freezer was solid with ice.I have defrosted the freezer,dried any water from the unit and replaced the panel.Fingers crossed,so far,so good.In my case this build up of ice was definately the reason the drawers were not sitting in the correct position,as it caused the rear panel to 'bulge' out.Hope this helps.....
Dec 11, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint ffA71
ffa71 fridge and freezer warm and food defrosted. red light is on. Back of freezer making normal noise. Help.
Aug 27, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint FFA70
Remove the plastic venting box which feeds cold air over the top of the freezer drawers,There are 4 hexagon headed self tapping screws,two at top.and two bottom.Now defrost all ice off rear of freezer and back of vent box.Now replace and door will shut with draws in.Make sure no ice left round fan housing.
Jan 21, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Refrigerators Logo
258 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
