If cleaning with a cleaner disk and solution did not work, then you have to clean the lens directly.
Remove the cover and access the inside of the DVD, unplug power first.
Use soft cotton sticks and isopropyil alcohol to clean the lens, here is a picture of the lens pickup:
As usual do the job at your risk, if you want to call for repair you can use the number listed in the owner manual.
Comments:
Oct 14, 2008
- If direct cleaning does not work, the lens pickup should be replaced, after testing that signal from and to lens is OK, but that is a job for a technician.
Oct 15, 2008
- Nice to know you fixed it, I will be grateful if you can take some time in rating the solution appropriatedly.
When playing CDs, the music playback starts a second or so too late, cutting off the beginning of...
(More)
When playing CDs, the music playback starts a second or so too late, cutting off the beginning of the CD music. Can you help?
On some DVD's, say 50%, there is a almost unnoticeable "flicker" of pause in the video...
(More)
On some DVD's, say 50%, there is a almost unnoticeable "flicker" of pause in the video playback on my CA DVD89. It is only slight, seems to be random and can be from say 5 to 50 seconds apart. Most people don't seem to notice it unless it is pointed out to them. Possible layer transition? Audio sync?? Monitor compatability??? Repair agent can't fault. Anyone else experienced this? Any help on a solution appreciated.
my computer will play cds but will not play dvds, i keep gettin a message that says insert disk...
(More)
my computer will play cds but will not play dvds, i keep gettin a message that says insert disk (emachines)
Hello my warranty just came up. Every once and a while my dvd player has weird markings come up on...
(More)
Hello my warranty just came up. Every once and a while my dvd player has weird markings come up on the players screen it looks weird no spelling what so ever maybe like this EIeiEI and no video or audio works .it' spinning but thats it. I unplug it and turn off and in a few days its working again. Any thoughts?
