Question about Kenmore 94223 Electric Kitchen Range
Kenmore Elite electric kitchen range, modle: C970-692641
By accident I press the lock button function on the electronic controls. This has left all the other push button functions in the disable state, with the exception of the numeric pad (0 to 9), the start and cancle buttons. I have tried turning on and off the power for a few hours but that did not help.
Is there a manufactures default code or something simple that I am missing?
I read the owners manual and it is my understanding that there is a self clean function that locks the oven. During that time the functions of the electronic key pad are disabled, until the self clean cycle is complete are they restored.
My guess is the electronic board is looking for a cycle complete signal before it remove the lock function. But a self clean command was not instructed so there is no cycle complete.
  • renetard Jan 29, 2009
    accidently locked panel ,can't use oven at all
  • Anonymous Apr 16, 2009
    Unit is in lock mode and cannot be unlocked. Please help!!
  • 5 Answers
SOURCE: Self-cleaning oven doesn't work on Kenmore electric oven
I suspect the timer is involved in this process. It can be set to clean automatically. You need to set the complete time at least 2 hours after start.
Posted on Apr 11, 2010
heatman101
  • 43501 Answers
SOURCE: Kenmore Electric Range model 790 has F9 & F1 code error
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Posted on Apr 21, 2010
blueextc3221
  • 15935 Answers
SOURCE: Self-Cleaning Failuare on Kenmore Electric Range
It appears your timer/main controller/CCU CLOCK has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 25, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore 95024 Electric Range The self clean cycle Door stuck shu
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
blueextc3221
  • 15935 Answers
SOURCE: self-cleaning error message f90
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Posted on Oct 01, 2010
Oven door is locked out - Sears no help
      1. Step 1 Read the display on the electronic oven controls, where the clock and timer normally appear. If the display reads "CLN" while the "Door Locked" light is on, the Kenmore range is in self-clean mode. When the Kenmore range is in self-clean mode, you must stop the cleaning process before the door will unlock.
      2. Step 2 Stop the self-cleaning process by pressing and holding the "Stop/Clear" button for three seconds. The oven lock should disengage after three seconds. In some cases, a malfunction between the control panel and the locking mechanism prevents the door from unlocking.
      3. Step 3 Hold the light switch for several seconds if the "Stop/Clear" button fails to unlock the range door. Engaging the light switch for several seconds resets the entire locking mechanism and overrides the "Stop/Clear" button.
Jul 03, 2015 | Kenmore 30" Freestanding Electric Range...
How do i get the control lock button to turn off?
There is a button on the control panel with a marking under it that says "Press and hold for 3 seconds to lock/unlock control". Look for the said button then press and hold it for 3 seconds or until the control lock light turns off. The button is usually the Auto Dry Level button for Kenmore Elite dryers and the Drain/Spin button for Kenmore Elite Washer. Whirlpool Duet Washers and Dryers use the End of Cycle Button to lock and unlock the control.
Sometimes the problem is due to electronic glitch and unplugging the machine for at least 30 minutes may solve the problem. But if the control cannot be unlocked by pressing and holding the button specified above or by unplugging the machine, the control panel electronics may need to be replaced.
Dec 21, 2010 | Kenmore Elite HE4 Electric Dryer
Keys on the oven are not working so I can not start oven bake
Thanks for posting to Fixya I will be helping you today. You have posted that you have a Kenmore Elite 44173 electric cooktop with a problem. However, you also mention your are having trouble with the oven not working. This post maybe categorized wrong but I will try to answer you question for both a range and oven control.
Sometimes on a cooktop customers will lockout the controls on accident while cleaning. Usually there is a button on the control that you hold for 4 seconds +/- and there is a little simbol of a padlock next to it or you might have to check the owners manual.
Lastly, Ranges may also have a lock out feature that the customer must press 4 seconds too unlock. On select models controls may also be locked out by putting their oven into sabbath mode. Usually the display will indicate a "SAB" to alert that this feature has been set.
*In general the above instructions should help if your unit is locked out.
Happy Holidays!
"Please rate this information "4 thumbs" if you found informational.
Dec 02, 2010 | Kenmore Elite 44173 30 in. Electric...
Jun 27, 2010 | Kenmore 95022 / 95024 / 95029 Electric...
Built-in double oven range is showing code F7 on screen
For error code F7 Stuck Button check if the Function pad button is stuck or Bad clock. Try to free stuck button or Replace Electronic Range Control (ERC).
Aug 27, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
Kenmore Elite oven
Replace the electronic oven control or the sensor
Apr 30, 2009 | Tappan TGF320 Gas Kitchen Range
Control locked
Mine has an "auto dry" button. It says underneath, "Press & hold 3 seconds..." to unlock control. I did it, it worked.
Feb 07, 2009 | Kenmore Elite HE4 Electric Dryer
Lock out
press and hold the lock button until it beeps, this will unlock it for you.
Jun 08, 2008 | Kenmore 46123 Stainless Steel Electric...
Control lock
Press the same lock function continuosly and listen for the beep sound, keep watching the display until you notice the LOC mode disabled.
Mar 08, 2008 | Kenmore 46123 Stainless Steel Electric...
Kenmore Elite Electric Range, Display stuck on LOC
I pressed the lock icon on the panel and held it for a few seconds and the display cleared.
Feb 03, 2008 | Kitchen Ranges
Kenmore 94223 Electric Kitchen Range Logo
301 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
